05-04-2022, 09:11 AM | #1 |
Rep 4
is that log data normal for my m2c?
run the 3 times log data test on road at yesterday,same 93oct fuel
93 stg1 bm3 ots:https://www.bootmod3.net/log?id=6272...729b5cae1fe064 91 stg1 bm3 ots:https://www.bootmod3.net/log?id=6272...90c61dec055971 cs tune:https://www.bootmod3.net/log?id=6272...0b43101e7d2318 all the test at almost same time and as u guys can see...it wont detect knock when my car runing at 93oct map,but it will detect knock at 91map... is that normal and my m2c can running at 93oct map safe? |
05-05-2022, 02:43 PM | #2 | |
Rep 34
05-06-2022, 09:02 AM | #4 |
24384
Rep 191,215
the 91 octane map looks cleaner, I recommend you change gas station and use another 93 then log again. Your turbos are working at 85% capacity which is quite high.
your turbos are also overboosting at 4K causing a throttle closure
