08-13-2018, 05:14 PM | #1 |
Rep 165
questions about ohlins R&T
I am currently running KW HAS kit with Ground control camber plate, i am about to purchase a set of ohlins r&t for my m2. Here is the question. When i ordered my camber plate, i chose "stock" as my spring inner diameter because HAS kit has the same diameter as the stock springs. I emailed Ground control, they said i will be needing Spring hats x 2pieces ,spacers x4 pieces. Before i can order the new hardware, does anyone know what is the spring inner diameter for ohlins R&T?
08-21-2018, 08:59 AM | #3 |
Rep 165
65 mm equals to 2.55905512 inches. will 2.50 work?
08-21-2018, 06:01 PM | #4 |
Rep 1,336
GC should be able to confirm 100% for you however the link to purchase some swift springs below are saying they are considered the same same.
http://www.sakebombgarage.com/custom...id-203mm-65mm/
08-21-2018, 07:37 PM | #5 | |
Rep 165
09-01-2018, 12:10 PM | #6 |
3815
Rep 54,307
Drives: F80 M3
