M2 Technical Topics > Suspension | Brakes | Chassis > Spacer Diameter Preference
      07-09-2018, 10:26 PM   #1
MiStR StEvO
MiStR StEvO's Avatar
Spacer Size
I am on stock wheels and stock height but wondering what size everyone is going with. I currently purchased a 12mm set to test and I have them on the rears. I was told by a vendor I should go with 15mm up front. I was originally going to do 12mm all around but they mentioned the fronts have a higher offset so going with the 15mm would give it a more balanced width. Thoughts??
2010 AW E90 335i M Sport
2012 GTR
2017 STi Limited
2018 LBB M2 DCT
      07-09-2018, 10:39 PM   #2
AGM2
AGM2's Avatar
Drives: M2 LBB 17
Not my car 12mm all around perfect!!!!
      07-10-2018, 01:26 AM   #3
eeyang92
Drives: LBB M2 LCI 6MT
If you plan to lower, 12mm front and 10mm is the max on stock wheels + tires, so 12mm all around is probably a good choice. And from the pic above it looks pretty good!
      07-10-2018, 07:56 AM   #4
MiStR StEvO
Thanks for the input guys. I've decided 12mm all around. Now the question is what suspension setup should I go with? I hear the KW HAS is decent but possible noise issues and stock strut might not last as long going that route. The other option is the V3 but at 3-4x the cost. What are your guys thoughts?
2012 GTR
2017 STi Limited
2018 LBB M2 DCT
      07-10-2018, 12:31 PM   #5
eeyang92
Depends what you want to do with the car - for track definitely coilovers. For street-only, springs are fine.
      07-10-2018, 03:19 PM   #6
MiStR StEvO
No plans for track for me but I have read the stock struts go pretty quick with just springs.
2012 GTR
2017 STi Limited
2018 LBB M2 DCT
