03-10-2021, 12:35 PM | #463 |
Rep 2,526
Nostrum just released updated pricing on their N55 HPFP. Its now $1350, and I'm told there is a lifetime warranty. (They're working on a new website, which should reflect the warranty details).
proTUNING Freaks should have the data they need to add it to the HPFP dropdown on available OTS maps, so it's on them to release an update. https://www.nostrumshop.com/product/bmw-n55-hpfp-kit/ |
F87source7338.50 Raymondo123467.50 |
03-10-2021, 02:52 PM | #464 | |
Rep 176
03-10-2021, 05:38 PM | #465 | ||
Rep 2,526
Raymondo123467.50 |
03-10-2021, 07:36 PM | #466 | ||
Rep 2,526
Raymondo123467.50 |
03-10-2021, 07:38 PM | #467 | |||
Rep 176
03-10-2021, 07:58 PM | #468 | |
Rep 7,510
detroitm22431.50 |
03-15-2021, 05:23 PM | #469 |
Rep 7,510
Updated the main post, I should also mention that spool calculates their flow likely incorrectly for the n55 because they base it on cam lift which only applies to the b58 as the b58 hpfp is driven off the cam. The n55 hpfp is driven off of the back of the vaccumn pump which is timing chain driven. I should double check this.
So that also did mess me up because it led me to believe for the longest time that the n55 was the same way which is absolutely not true.
03-15-2021, 07:01 PM | #470 | |
Rep 3,714
03-15-2021, 07:21 PM | #471 | |
Rep 7,510
Then spool is calculating it correctly. Dorch is clear they are calculating on cam shaft so their data is wrong. "The table below serves as a reference for maximum fuel flow in cubic centimeters per camshaft revolution for various N55 fuel pump options. These calculations are based on the N55 cam lobe. Each engine will have varying fuel flow capacities depending on the lift and number of lobes on the camshaft." Nostrum gives a LPH chart based on rpm but it is unclear how they calculated their numbers or if they give a measurement. So in summary even comparing CC/rev is not accurate because the stroke distance changes if you use the wrong cam profile and thus less volume is pumped so you can't even compare it that way. So yeah now that I am looking into this area more cautiously I see the callous mistake I made before assuming the HPFP is also driven off of the cam shaft like the b58 when it does not, it is driven off of the vaccumn pump which is on the opposite side of the engine compared to the head so there is no way it can be cam driven (it is also driven by a chain so yeah dead give away if I had decided to look at the vaccum pump assembly earlier) - I am kind of beating myself over the fact that I didn't notice that before. Well that's what happens when you don't fully research a topic and just rely on manufacture data I suppose. But what I said about the s55 is still true 2 hpfp's driven off the the chain which again is spun by the crank hub, and a mechanical water pump (I believe is belt driven or might be chain driven I actually never looked) also driven off of the crank hub provides alot more mass (and thus inertia it must overcome to do said speeding up and slowing down) that it has to spin up and slow down might be the reason why the S55 is much more proned to spinning the hub than an n54 and n55.
03-16-2021, 02:33 PM | #472 |
Rep 1,115
If the N55 drives the HPFP off the vacuum pump, is it a myth then that the TU pump will damage anything other than maybe the vacuum pump with its wider spring. People were talking like TU pump would damage the cam over time.
Starting to wonder if it isn't partial misinformation by pump companies that invested a ton of R&D to be leg swept by DIYing an OEM part. |
03-16-2021, 02:58 PM | #473 | |
Rep 7,510
Now on the b58 that's where cam damage becomes a reality because the pump is driven off of the cam. This could be a weakness on the b58, but we will see.
03-16-2021, 04:23 PM | #474 |
Rep 1,115
The myth was around using the TU pump on the N55. It always seemed suspect to me, but it became gospel based on conjecture from so and so who knew a guy that designs HPFPs.
03-16-2021, 04:31 PM | #475 | |
Rep 7,510
Also the way the b58 hpfp has to be modified to fit the n55 looks really sketchy.
03-16-2021, 04:42 PM | #476 | |
Rep 1,115
03-16-2021, 07:29 PM | #477 | |
Rep 7,510
03-16-2021, 09:56 PM | #478 | |
Rep 1,115
Looking at the S55 vs N55, the vacuum pump timing sprocket and timing chain are identical parts, the S55 vacuum pump looks to be similar to the N55, except for the twin HPFP mounting locations. I can't see how the TU pump would damage anything on an N55 other than maybe the vacuum pump cam, it certainly isn't going to add more load to the timing system than a two pump setup. |
03-16-2021, 10:01 PM | #479 | |
Rep 7,510
03-31-2021, 09:30 PM | #480 |
Rep 2,526
Looks like the Nostrum HPFP is available on BM3 now.
03-31-2021, 10:17 PM | #481 |
Rep 7,510
Very nice.
04-02-2021, 10:33 AM | #483 |
Rep 2,526
Whose doing your tuning?
04-02-2021, 12:38 PM | #484 | ||
Rep 147
They know how to tune a car so we will see what they can get out of the setup for me |
detroitm22431.50 |
