08-18-2021, 11:37 AM | #1 |
Rep 267
Turbo is out and I have question.
Hello everyone, I was wondering if I need to do anything special,,Is there adjustments or anything that I should know about.
I would appreciate the help. |
08-18-2021, 04:56 PM | #2 |
Rep 5,477
If you mess with the electronic waste gate arm at all, you'll need to recalibrate electronic waste gate unit using ISTA. Other than clocking the turbo perhaps, I think that's all you can really adjust or calibrate with the turbo assembly.
08-18-2021, 05:15 PM | #3 |
Rep 7,915
You can't clock this turbo at all, otherwise the waste gate actuator arm won't line up. There are pretty much zero adjustments that can be made to this turbo besides the waste gate arm but like you said it'll need to be recalibrated via ista.
08-18-2021, 06:35 PM | #4 | |
Rep 267
Is that what you meant but messing around ? |
08-18-2021, 06:37 PM | #5 | |
Rep 267
I guess I have to recalibrate it? |
08-18-2021, 07:19 PM | #6 | |
Rep 7,915
What we are talking about is the compressor housing and rotating it relative to the exhaust housing - other wise known as clocking a turbo. If you didn't disassemble the two halves of the turbo and move it around to the point where the waste gate arm won't fit then you are fine.
///M TOWN31266.00 |
08-18-2021, 09:59 PM | #7 | |
Rep 267
08-18-2021, 10:34 PM | #8 |
Rep 7,915
08-19-2021, 04:52 PM | #9 | |
@_sunbish
301
Rep 633
Yes, replace it with a bigger one.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
