05-27-2021, 11:20 AM | #1 |
Rep 112
Drives: 2017 BMW M2 - Mineral Gray
Do you need the adapter to use the 3.5 bar TMAP on the N55 M2?
I have a 2017 M2, looking to upgrade to the 3.5 bar TMAP sensor (part # 13627843531). I see there is an adapter harness available as well. Is the adapter needed for my M2? Or is the upgraded 3.5 TMAP plug and play? Thanks!
05-27-2021, 05:42 PM | #4 |
Rep 112
Excellent, thank you guys!
05-28-2021, 07:10 PM | #5 |
Rep 406
Drives: BMW 328xi BMW X5 F15 BMW M2
What does the upgrade do?
05-28-2021, 11:53 PM | #7 |
Rep 7,429
Like others have said it is plug and play on the F series N55, on the N54 you require the pig tail harness adaptor. Afterwards you will require to make a change in your tuning software to accommodate the sensor.
In regards to its function it allows the ecu to see boost levels above 21.5 psi, which is the limit of the stock sensor.
