03-04-2019, 07:27 PM | #1 |
Rep 121
M2 tail pipes.
Can someone please tell me the distance between the tail pipes for the M2?
Also, the with of the two tips. Thanks
Instagram: 709m240i
03-04-2019, 07:57 PM | #2 |
Rep 212
Drives: 2024 M3 Comp xDrive
03-04-2019, 08:42 PM | #3 |
Rep 121
Distance between the two inner tips on the left and right
Instagram: 709m240i
03-05-2019, 08:40 AM | #4 |
Rep 392
Hopefully this is clear. These measurements aren't perfect but they are pretty close (for example- tip diameter is closer to 3 3/16"). You should be able to derive any other measurement you want with this data.
Edit - I fixed the center-to-center from 4 1/4" to 4ish . It's too hard to get an accurate measurement because they are offset. Last edited by CTSean; 03-05-2019 at 12:15 PM.. |
03-05-2019, 04:31 PM | #5 | |
Rep 121
Instagram: 709m240i
03-05-2019, 05:09 PM | #6 |
Rep 1,017
Out of curiosity, are you trying to configure or cut you rear valance to accommodate the M2 quad exhaust for your M240i?
I had a M235i and this is something I had thought about doing. Either way, good luck with your project. |
03-06-2019, 07:55 PM | #7 | |
Rep 121
Instagram: 709m240i
qnet681.50 |
