02-22-2018, 10:13 AM | #23 |
Rep 177
Drives: Long Beach Blue M2
I'm on standby to get the Eventuri intake. I'm need to double check with my service center/dealer to make sure it doesn't void my warranty. But I'm sold on it already, only one that has the style that I'm looking for.
02-26-2018, 01:00 PM | #24 |
Rep 105
1. Factory airbox flows just fine. I'm willing to bet there's no bottleneck here with a drop in filter even with PS2.
2. Any negligible gains to had from an intake usually don't equate to a net gain overall due to turbulence over MAF. This is not to say ALL intakes have this problem, but it's common. Sometimes this turbulence is a pain in the ass for tuners to work with. 3. Heat soak will only occur when sitting at a dead stop. Once you move, the air will cool down rapidly. Unless you're drag racing and need that extra .0001 seconds, you're not going to notice a loss in track times. 4. A turbocharger RAPIDLY heats up air molecules. This is the directly result of friction. "Cold Air Intake" is a misnomer on a turbocharged car. Doesn't matter if the IAT at the filter is 10* warmer, the direct result on charged air temp is almost non-existent. This is why you have a *hopefully* functioning intercooler/heat exchanger. Buy an intake because you want sound, looks, or both. Open element or closed element really doesn't matter unless you're a stoplight-stoplight racer. Open element will provide more turbo noises, closed will have marginally better throttle response (if any at all) in stop & go traffic. As others have stated, if you're looking for functional performance gains, intercooler is going to be the best investment in terms of charged air temps, and you can buy 2-3 of any intercoolers on the market for the price of some of these intakes out there. |
02-27-2018, 01:30 AM | #25 | |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
So yeah, you get a bit more sound, but you're also sucking in more dirt. Into your engine. Dirt and grit, which can increase wear and potentially break stuff. Oh, and it's going into the turbo compressor wheel first, so one more thing to damage, and something that is balanced to within a few thousandths of a gram IIRC. Seems like a great idea to suck tiny pieces of "dirt" (which could include hard material like quartz or steel bits) into a precision-engineered turbine and hope that nothing goes wrong. If there really was a gain to be had with aftermarket filters and intake tubes, wouldn't the manufacturer already engineer that into their own product? Like others have said, intakes are for sounds only, and be aware that you are probably shortening the life of the engine.
qnet684.50 |
02-27-2018, 02:44 AM | #26 | |
Rep 4,526
http://www.2addicts.com/forums/showp...2&postcount=34 Hence, based on my experience with fettling my M135i's intake, my plan for my M2's intake is :- OEM intake with AFE dry drop in + ER CP and TIC pipes + Pure hi flow pure and then either wagner evo 2 comp or CSF FMIC.
Current '22 X3M LCI.. |
NO_USER_537.50 |
02-27-2018, 07:45 AM | #28 | |
enthusiasm > practicality
4027
Rep 2,247
Drives: 987 CS | G35x
02-28-2018, 05:33 AM | #29 |
Rep 166
Drives: M2 LCI BSM
I got the Eventuri 2 weeks ago and I want it off my car asap. So much noise, not good noise. Hollow, whistle/ howling sounds at low rpm. It only sounds good when you are driving at full intensity, otherwise it's embarrassing for me to seen/heard driving with it.
I'd noted this on various YouTube clips and queried but the owners said the howling noise (like blowing in a bottle) wasn't so noticeable from the cabin... but it is. |
M2RAW121.00 |
02-28-2018, 07:43 AM | #30 | |
Rep 4,526
Anyone got any views on AFE Momentum GT intake ???
ZPrime611.50 |
02-28-2018, 11:59 AM | #31 | |
756
Rep 2,149
Dinan was my #1 choice, now I have to rethink. Every other intake I've seen is either too expensive or too ugly. |
02-28-2018, 12:13 PM | #32 | |
756
Rep 2,149
http://stratifiedauto.com/blog/the-e...rged-vehicles/ |
02-28-2018, 01:09 PM | #33 | |
24350
Rep 191,156
Dinan intercooler needs cutting because it is dual core versus single or stepped core. I would not go with Dinan intercooler unless you are going with larger turbos (larger than Dinan turbo). a high density 6" intercooler like Wagner will a better option
02-28-2018, 02:25 PM | #34 | |
756
Rep 2,149
02-28-2018, 03:41 PM | #35 |
24350
Rep 191,156
My pleasure, please let me know if you have any other questions.
03-01-2018, 12:16 AM | #36 | |
Rep 752
Still the best intake IMO...if one were to get an intake. PS have you seen their new filter? I have it sitting at home right now, gonna make an install guide perhaps that might change the low load whistles you speak of? We’ll see...but to me the sound is in the carbon tube because it sounds really hollow if that makes sense. |
specka71.00 |
03-01-2018, 11:58 AM | #37 | |
756
Rep 2,149
@3:24 in this video |
03-01-2018, 07:12 PM | #38 |
Rep 1,835
Drives: 2020 X4M CS
All open air intakes have cosistantlly dynoed at 5-10whp reduduction is high RPM range...really common sense...
However, The BMS which i had made that turbo scream, and the dinan I had looks beatiful and at least takes advat=ntage of the flawless stock airbox. Like many said drop in filter can give a few ponies...and k&N and BMS supposedly filter just aas well as stock... u can make a filter flow more without sacrificing filtering ability...so whoever said the opposite is not theoretically correct...
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 Last edited by DKX4///M; 03-01-2018 at 07:48 PM.. |
03-01-2018, 07:33 PM | #39 |
Rep 752
No it's not that sound, that's "normal" of the Eventuri...that little whistle at the end (reminds me of like a submarine radar LOL) isn't as pronounced with my 2nd Eventuri. But those sounds in the video are why people get intakes...for that sweeeeet induction noise
03-02-2018, 08:45 PM | #40 |
Rep 166
Drives: M2 LCI BSM
Yeah the sound is very noticeable in that clip, and any clip. Its not the induction sound - im fine with that, its the sound when you let off the throttle, or when you are just cruising in traffic at a constant low rpm it is constantly there. I've had intakes on my other cars before that do not suffer this effect. I don't like it, as its not proportional to any kind of throttle that's being applied. I find the car just sounds noisy all the time. Granted when you really hammer it, the sound is good.
tehboost I'd be keen to hear if the new filter makes any difference. I agree that it's the carbon tube and probably the open filter design that create this sound. Expensive mistake - they're over 2k down here in Australia! Ill have a Fabspeed Sportscat and a M Performance exhaust on the car within the month so will probably keep it on the off chance that helps conceal it or balance it out aurally.
M2 LCI - DCT - BSM | BM3 Stg 2 | Eventuri Intake | Fabspeed Sportscat | Wagner Evo 2 FMIC | Ohlins R&T | Rays | Recaro Sportster CS
03-03-2018, 05:15 PM | #41 |
Rep 1,835
Drives: 2020 X4M CS
Its only because we have recirculating blow off valves...meaning excess boost is released back into intake tract after MAF sensor on shifting or letting off throttle...As opposed to "Open Air/atmosphere" releasing into atmosphere...
Changing without adjusting programming, causes and a super rich AFR on shifts or letting off, and will cause stalling and msses.... Itd be cool if Bootmod3 had an option to switch over so we could keep our efficient stock intake or use a DINAN intake but get that blow off like BMS or AFE
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
03-03-2018, 11:12 PM | #42 | |
Rep 752
http://f87.bimmerpost.com/forums/sho....php?t=1472425 Changed the sound lol... |
05-29-2018, 11:58 AM | #43 |
24350
Rep 191,156
