09-04-2024, 10:05 PM | #683 | |
Rep 3,873
09-04-2024, 10:10 PM | #684 | |
Rep 5,038
Do you have an example of someone maxing out the pump on an E30 mix? |
Shaq9316.50 |
09-04-2024, 10:18 PM | #685 | |
Rep 3,873
Sure, a lame mhd or other low power ethanol map will work with the b58 pump, but why then add the p500? That was the whole point of the line of questioning. How many whp have you seen on CA 91 or ethanol with that pump? Either way, a p500 isn’t going to give you hardly anything more than the stock turbo bc you’re fueling limited. |
09-04-2024, 10:26 PM | #686 | |
Rep 5,038
If you want high/full E, you're not going to be running just a Dorch Stage 1 either. Plan what you're doing and run the appropriate parts. If someone is running an E30-50 tune on California crap gas and with their crap regulations, it's a great option. For people in other situations they'll have to figure something else out. |
09-04-2024, 10:37 PM | #687 | |
Rep 3,873
johnung4982.00 |
09-04-2024, 10:44 PM | #688 | |
Rep 5,038
Didn't the P500 make 450whp on pump? Could it make 470whp on e30/40? Is it possible that's "good enough" for some people? The issue here is you're already deciding for everyone what is "enough" for them. I have said I have zero interest in running E85 in any mix - if I upgraded to a Stage 2 turbo, a B58 pump would be perfect to.max out my setup on pump. I could if desired run a little e down the road. I already have a Dorch Stage 1, I already have a HPFP tune. None of what I'm saying is in support of any vendor, it's just being objective. |
09-04-2024, 10:53 PM | #689 | |
Rep 3,873
09-04-2024, 11:01 PM | #690 | |||
Rep 5,038
Did you even see what was asked before you started calling people "dumb" Get a grip, you're easily the most unhinged and childish person on this side of the forum. Let's revisit what was asked: Quote:
Let's move on. Quote:
He didn't ask about you opinions on modding cars, he didn't ask about Dorch, he didn't ask you to critique his build. I answered the questions that were asked, which has me circling around to.... What the he'll are you complaining about? |
09-04-2024, 11:06 PM | #691 |
Rep 3,873
CA guys, add the b58 pump and max out the stock turbo on 91 or ethanol and dyno it.
Then, drop the coin on the p500, install, and supporting mods, and max out the b58 pump and dyno it. Compare the numbers and then come back and tell us who’s crazy. |
09-04-2024, 11:37 PM | #692 | |
Rep 5,038
I have been reading through the B58tu thread all night off and on - a guy put one in his B58 with a EFR turbo and made almost 600whp on a E30.
Different cars, different engines, different turbos - same idea. Quote:
https://f30.bimmerpost.com/forums/sh...&postcount=416 I wouldn't ask a boy to do a man's job, and I also wouldn't ask a Stage 1.5 turbo through a highly restrictive downpipe and ots tune to make me 500whp. We all have opinions on builds. For what it's worth, the HPFP was enough for 20whp+ on 91 for the stock turbo. It's not going to set the world on fire, but it will be a very nice increase over stock. https://f87.bimmerpost.com/forums/sh....php?t=2104220
VGSON334.50 |
09-04-2024, 11:44 PM | #693 | |
Rep 3,873
As I stated, CA guys, add the b58 pump and max out the stock turbo on 91 or ethanol and dyno it. Then, drop the coin on the p500, install, and supporting mods, and max out the b58 pump and dyno it. Compare the numbers and then come back and tell us who’s crazy. |
09-05-2024, 01:49 AM | #694 | |
Rep 1,496
Having said that I really want the Pure 500 AND HPFP and a custom tune. |
09-05-2024, 04:24 AM | #695 | |
Rep 3,873
91 ACN- HPFP alone won’t get you anything. A P500 might get you 20whp over the stock turbo? You might not even need an HPFP upgrade with it, but B58/DS1.5 if you want to be safe bc all our stock hpfp’s are getting older & weaker, logs would confirm if needed. Is a turbo, custom tune, and potential HPFP worth 20whp? 93- HPFP alone might net you 5-10whp on the stock turbo, but you better have really good 93 and a good custom tune—not worth it. We’ve seen a P500 add 40-45whp above the stock turbo. HPFP required. This isn’t a fuel choice for the ACN guys, so might as well skip the b58 pump and go DS1.5. E30-50- 45-80whp above stock with a P500. HPFP required. The B58 pump is going to choke here and won’t hit those gains, it flows a decent bit less than even the older DS1 with the updated BM3 flow settings. With the b58 pump you’ll probably be lucky to get 45whp more than stock. You can actually get pretty close to those gains with the stock turbo, but the P500 gets you a flatter curve up top. The DS1.5 is the obvious choice here to unlock all the gains, while the DS2.5 if you want headroom or to run E50+ later. So, the only scenario at all that makes sense here for the b58 pump are the CA guys that have to pass CA emissions. And then if they want to add the p500, they’re ok running a custom detuned ethanol map that will net a few peak whp more but better top end vs the stock turbo bc they’re still hpfp limited. Adding the p500 & custom tune to a b58 hpfp limited situation is def a good bit more cash & pain for limited gain vs just running the stock turbo and e30-40 with an OTS map. Last edited by ZM2; 09-05-2024 at 04:40 AM.. |
09-05-2024, 08:44 AM | #697 | |
Rep 3,873
Unless NZ checks for aftermarket hardware or software (can flash the stock map with the DS1.5 selected). |
3t3p503.00 |
09-05-2024, 09:13 AM | #698 | |
Rep 5,038
And I do need to verify things myself. If I let people on this forum steer my part selection I would be running a $900 Wagner Evo2 with IATs 30F above ambient, the very restrictive stock F22 airbox, no HPFP because I'm running pump 93 only and have 40whp less than I do now, with a car that is incredibly laggy because of the terrible stock airbox. Anyhow, this idea that power can't be gained on a pump gas tune is absolutely unfounded. https://f30.bimmerpost.com/forums/sh....php?t=1563313 430whp/454wtq Pump 93 stock HPFP 528 whp and 570wtrq Pump 93 (boostane?) XDI HPFP https://f30.bimmerpost.com/forums/sh....php?t=2114401 It was worth 25BHP on the stock turbo here: 424BHP Pump gas stock HPFP 450BHP Pump gas B58TU HPFP Again, no one here (at least not me) is saying the B58tu pump will max a setup out. But depending on your goals the power gain may be enough for you. |
09-05-2024, 09:45 AM | #699 | |
Rep 3,873
The m2 already has the less restrictive airbox and you’re running milvs, so your gains don’t mean anything here. And your first link is to a PS2, not P500. That’s also pointless info that is going to give someone’s hopes up if they get a P500 (which is the point of the question that was asked), which is octane limited compared to the PS2. No one in this thread cares about the PS2 or what the b58 pump will do with it. And, for the second link, M2’s routinely do more power on the stock hpfp & turbo with a bm3 stg 2 93 ots map than that shop did with their b58 pump and custom tune (450bhp flywheel?). So what’s being proved other than go with them if you want a slower car? Last edited by ZM2; 09-05-2024 at 09:52 AM.. |
09-05-2024, 09:55 AM | #700 | |
Rep 5,038
TL;DR You can gain power with any upgraded HPFP Stock turbo or otherwise - pick the right one for your goals. Pump gas and/or low E mix - B58TU/Dorch Stage 1 is ok More/Full E85 - Consider a Dorch Stage 2 or the like. |
09-05-2024, 12:13 PM | #701 |
Rep 6
How much whp are people getting now with stock turbo + fueling? I imagine for those that want to keep low end response it’s probably good enough vs the pure 500 route
09-05-2024, 12:36 PM | #702 | |
Rep 3,873
Adding a B58 or Dorch HPFP to a stock turbo won't provide any more power over the stock HPFP, as you'll already be octane limited to make more power with the stock turbo. I think it's around ~365-70whp, or ~30-35whp more than stock? E40-E50 With the stock turbo, you can hit ~445whp. HPFP required, and you can simply run an OTS map. The P500 with a B58 pump (since you're in CA) would have similar peak whp because you'll be close to its flow limit, altho, it would keep power higher above 5.5k RPM--a custom tune with a good bit of logging and tune revisions would be required for this approach to not overwork the B58 pump and get drop outs, especially in cooler weather. A P500 with a DS1.5 and E50 will hit ~480whp (I've seen higher), but then you have the CA emissions issue. |
socalm2nual1.50 |
09-05-2024, 01:24 PM | #703 | ||
Rep 5,038
380whp ACN 91 408whp 91 HPFP Link here: https://f87.bimmerpost.com/forums/sh....php?t=2104220 Quote:
You won't max out a B58 or a Dorch stage 1 at those levels. |
09-05-2024, 01:48 PM | #704 | |
Rep 5,038
https://f30.bimmerpost.com/forums/sh...&postcount=710
I think a lot of this is overblown. |
