07-01-2024, 11:17 AM | #507 | |
@lbb_kev
535
Rep 557
AmuroRay2887.50 |
07-01-2024, 11:59 AM | #508 |
Rep 5,038
just because it's not at "full spool" doesn't mean it's not making power.
07-01-2024, 04:11 PM | #509 | |
Rep 970
Drives: 2015 BMW X1 35i M-sport
07-01-2024, 08:59 PM | #510 |
Rep 1,464
Drives: F10 S55, E93 M3, E89 N54
Unfortunately it is just my site that cannot calculate shipping charges. Please reach out to me and I can quote directly. Also, if you need anything else, I am able to do package deals for a discount. I can do HPFP, b58 coils, turbo smart BOV, for example.
07-02-2024, 02:16 AM | #512 | |
Rep 4,353
Good numbers , I'd be happy with those. Was hoping to fit mine this Saturday if the rest of the bits I ordered arrive. May have to switch to 100% meth until I can fit a Dorch.
OG M2 7sp DCT Masata FMIC -Masata Boost Pipe - Cobra Catless DP -
Powervalve Exhaust - Devilsown Methanol Injection Turbosmart BOV BM3 Stage 3 Halim custom map Pure 500 |
3t3p503.00 |
07-02-2024, 06:29 AM | #513 |
Rep 1,496
Great data and the custom tune wow Vs OTS.
You'd really be leaving a lot on the table going OTS but it's still an option the car will run better than before. So pure 500 literally does make 500 bhp on pump fuel with a custom map. Amazing thanks again for the info and dynos. Please keep sharing thoughts on driving and anything else related! |
johnung4982.00 |
07-02-2024, 11:22 PM | #514 |
@_sunbish
307
Rep 633
Full e85 through an automatic, not a DCT or manual.
Owner hasn’t responded with the full mod list.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
07-05-2024, 08:32 AM | #515 |
Rep 666
For those with a Pure750, can you take a picture of your wastegate adjustment nuts? I had to adjust mine recently to near the end of its adjustable range (closest to the actuator) and am wondering if this will be a problem soon (i.e., I won't be able to adjust it any further). Thanks!
07-05-2024, 09:31 AM | #516 | |
Rep 5,038
Is it possible Pure sent out another defective unit? I can't imagine this is supposed to be normal. |
07-05-2024, 09:35 AM | #517 | |
Rep 5,854
Drives: 2015 BMW 335i x-Drive Auto
07-05-2024, 10:30 AM | #518 | |
Rep 5,854
I’m involved with the tuning of my N55 EWG Pure500. It began by using the OTS Bootmod3 Stage2+ MultiMap FlexFuel tune as a base to start. The Pure500 on the OTS tune was immediately responsive with no delay/lag compared to the stock N55 EWG turbo. There was a definite increase in power, and that power seemed to sustain much longer towards redline. The stock N55 EWG is known to die off at high revs. With each subsequent tune revision those positive attributes increased. The responsive torque seemed to increase. The same for horsepower as it seemed to increase and sustain towards redline. Of course these are the impressions of my butt dyno as I drove each revision and collected engine logs. As the tuning process progresses and boost levels are increased, the capacity of the turbo gets closer. Those positive attributes begin to diminish/disappear. The most obvious change is to the horsepower curve. Ideally the horsepower curve should look like a high flat plateau that sustains its power towards redline. This is absolutely ideal for daily driving and for tracking, a very strong broad power delivery. So a sharp tuner pushes the tune as close to the turbo capacity as possible while keeping things consistently strong. It’s usually obvious when a tuner has gone too far if the horsepower curve no longer looks like a high flat broad plateau. Instead it looks like a peak that quickly drops off. I call it a bragging rights tune. It totally sacrifices drivability just for a horsepower number. This tune is being designed in an OTS manner. By that I mean that we don’t care about achieving a high horsepower/bragging rights number. It will be responsive and quick, with high power increase that sustains towards redline. It will be safe and reliable. A FlexFuel tune for a Pure500 that’s designed to be drivable and fun as a daily driver, or a as weekend track car. First dyno of the latest tune revision next week. Anxious to see the graphs and values, and go from there with the tuning. |
07-05-2024, 10:54 AM | #519 |
OG
335
Rep 443
07-05-2024, 10:56 AM | #520 |
Rep 5,038
I didn't take the photo, but I believe he's looking from above, just based on what I'm seeing.
https://f30.bimmerpost.com/forums/sh....php?t=1652190 |
VGSON334.50 |
07-05-2024, 11:02 AM | #521 |
OG
335
Rep 443
07-05-2024, 11:13 AM | #522 |
Rep 5,038
Ignore the red circle in the picture, it's actually slightly to the right of it. What you're looking for is that whole arm area and seeing how much it's been adjusted on the screw. The screw is what allows more/less range of movement of that lever and arm.
Edit: |
07-05-2024, 12:55 PM | #523 |
Rep 666
It was challenging to get a good picture of it with my phone. It's from above. This is the area of interest:
The threaded rod is actually much longer than what can be seen in that shot shared above. This is a pic from Bimmerworld's website of the EWG and the actual length of the threaded portion. I haven't contacted Pure yet because I am just starting to do research. Trying to figure out what my positioning looks like relative to others. This will be the next step. |
07-05-2024, 03:34 PM | #524 | |
Rep 5,038
There is a reason why Halim offers tunes, because the OTS is not a catch all for all situations. I posted a dyno from WG Motorworks that showed a substantial gain under the curve versus a OTS tune. My car made the same power as a FBO N55 with 2psi less in "Comfort mode" on the dyno. The Sport+/DSC off tune makes more power. |
3t3p503.00 |
07-05-2024, 08:23 PM | #525 |
Rep 1,496
Thanks for info re OTS, it's really great to know I could use my MHD license to get something out of a turbo upgrade.
Am I right in thinking that as it is more conservative reliability could or would be better than is pushed too far into the turbo's efficiency range? How does OTS tune allow more power to redline when currently on MHD at least, it drops off a bit ? Is it dropping off because DME is sensing parameters or is it actually built into the tune? If the latter why does a turbo upgrade suddenly let it sustain power for longer? And it sounds like as good as a custom tune is, when pushing things further spool is more noticeably as higher boost pressures are generated? On posted graphs it looks 150-200 rpm later than stock? Blue line Vs red |
07-07-2024, 03:09 AM | #526 |
Rep 4,353
OK all fitted and ready to go. Standard turbo vanes looked ropey so a good time to upgrade I guess also the turbo boost pipe is deteriorating so need to fit a after market one. ( any suggestions ) ?
When I remap it with the Bootmod3 do I have to do anything for the 3.5bar map sensor?
07-07-2024, 06:56 AM | #527 |
Rep 4,353
What abusing your turbo does.
