08-13-2016, 07:11 PM | #375 | |
Rep 209
08-14-2016, 11:05 AM | #376 | |
Rep 1,922
Drives: 2011 e91
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
08-14-2016, 12:19 PM | #377 |
Rep 556
I had the the tin can noise as well (February Build). This was the same day, just after I had some sort of shims replaced on my front wheel area (between rotor and hub - it was hitting the brake shields).
Now, what is funny is I heard "the new noise" coming from the rear and knew it was what the F80/82/83 crowd heard as rocks getting stuck in the brake shield. The video directly below was my first issue with a noise, which sounds nothing like the other two videos and was corrected after those shims were replaced (apparently there is a service bulletin out on this issue as well): This is what I heard from the rear or otherwise known as "Rock in brake shield" M3/M4 Videos below: |
08-14-2016, 01:50 PM | #378 | |
Rep 13,138
The ramble noise we are referring to, is significantly different. It's a brief metallic grinding/rambling/cluttering noise. Happens at random and lasts less than a second or so. Always from underneath the car, rear end. Hard to describe how it sounds: as if you got a metallic lunchbox with a fork or knife inside, and you're briefly somehow shaking it sideways: some metal-against-metal rubbing/screeching. If you hear it for the very first time, it startles you as you immediately think that something screwed up. But after a couple of times, you kinda 'get used to it' (similar sound) + no impact on driving. Just a nuisance, except if it turns out to be some car internals (rear differential ?) progressively getting damaged (which we don't know, as we speak).
///M is art ↔ Artemis
08-14-2016, 02:02 PM | #379 | |
Rep 556
08-14-2016, 02:16 PM | #380 | |
Rep 13,138
08-14-2016, 06:53 PM | #381 | |
Rep 1,514
08-14-2016, 07:47 PM | #382 | |
Rep 13,138
"I already had several times a rambling noise, as if I drive over a Cola can or something alike. I personally noticed it, for example when I drive at low speed with open windows through the city. Pedestrians looked back, startled, as if I had driven over something, though I hadn't. I cannot yet pinpoint this, as I don't know where it comes from. I cannot provoke this noise. Happens with cold and warm [engine] circumstances. Has anyone an idea ?"
08-15-2016, 07:48 AM | #383 | ||
Rep 115
Following this I started hearing transmission chatter when idle. It is like a flywheel chatter. Goes away when clutch is engaged or at higher idle -- As in you can head the noise disappear. The chatter was not there on day one (I'm sure because I would not have accepted delivery if I heard this noise in the quiet delivery room). Also it's quieter or louder at times. BMW AU changed the clutch but the chatter was still there. I did suggest to them at the onset that the flywheel needs to be looked at. It like a broken spring Center flywheel. But they insisted clutch. Eventually I was told that the loud transmission chatter noise is normal if mdct. BMW AU also pointed me to the manual that says mechanical engagement noises are common -- I said this is a chatter not mechanical engagement noises. Honestly, I can tell the difference between an engagement noise which I think is a form of engineered art versus a chatter. Overall it sounds like marbles in a tin -- not that loud but obviously noticeable in the cabin. Let's just say I wouldn't drive without music in the background. Pretty disappointing for a rather expensive German car in AU. BMW AU seems to think it's ok hence little effort in continuation. I've also run out of motivation to convince them - I do have other better things to do. I'm just living with it. Waiting for more community feedback. Apart from this tin can transmission, I do love the M2.
Current garage F87 DCT KW-HAS, and F20 N20. Previous E92 N54 FBO 100%-E85, E90 N52, E46, E21.
08-15-2016, 07:52 AM | #384 | |
Rep 2,948
08-15-2016, 07:58 AM | #385 | ||
Rep 115
Much like the HPFP and wastegate issues on my previous n54 motor, there seems to be a difference between BMWNA and AU support. I need something concrete to stand on and present to BMW AU.
M3 Adjuster7909.00 |
08-15-2016, 10:39 AM | #386 |
Rep 365
SI B33 04 16. Service Action: Replace Rear-Axle Differential.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's 1995 Porsche 993 Cab - Mine 2001 Toyota Tundra SR5 Ext Cab - Hay Hauler |
08-15-2016, 04:23 PM | #387 |
Rep 58
I just got notified from my dealer that the parts will be in on Wednesday for the recall. Much sooner than I anticipated. For those of us who already took delivery, they are doing an auto-ship to the selling dealer.
08-17-2016, 04:43 PM | #389 |
Rep 2,948
Well folks, my car has been fixed, picking it up tomorrow.
If anyone is in the situation I was in (and lives in Canada), PM me. |
8
08-17-2016, 05:01 PM | #390 | |
Rep 382
A toast to this post!!!
'01 M Roadster, '24 BSM M2
gmzanatta1823.00 |
08-17-2016, 05:09 PM | #391 |
BMW Newb
582
Rep 903
Mission accomplished...
gmzanatta1823.00 jtodd_fl6703.50 luvmybmmr305.00 Benzima1324.00 kylejdavidson137.50 winterrogue_F87234.50 |
08-17-2016, 05:38 PM | #392 | |
Rep 2,924
BMW ///M Club Montreal
BMW ///M Club Montreal Facebook Page |
08-17-2016, 06:00 PM | #393 | |
2nd Asst to Dept Undersecretary
6704
Rep 1,298
Drives: People crazy
This space for rent.
08-17-2016, 06:08 PM | #394 | ||
Rep 324
08-17-2016, 06:21 PM | #395 | |
Rep 181
08-17-2016, 06:29 PM | #396 |
Rep 2,717
