06-04-2018, 11:54 AM | #67 | |
Rep 3,659
Drives: 981 Cayman GTS
06-04-2018, 04:25 PM | #68 |
Rep 489
E46 M3 is a collector ... plenty of old M3 owners write in forums about their regrets when they sold their cars, and yours seems in good shape ... I would rather jump on 2nd hand M2 for my daily, and keep the M3 in garage ...
norMcal284.50 M3 Adjuster7905.50 |
06-04-2018, 05:54 PM | #69 | |
Rep 552
So is the 405hp on the M2C not to the crank? I mean the e46 M3 was listed at 333hp, which is why I figured mine has about 370, with what I did, so not far off from the 405 of the M2C. But you are talking 500 hp now to the crank. I wasn't aware that there is that much potential in them, safely. The weight reduction stuff would be a fun project over time, but as you wrote, costly! Doing the numbers in my head I'm guessing the tune, brakes, seats and exhaust you mentioned would easily set me another $10k back, even if I sell the stock BBK. So now I am looking at a $75k car, still weighing 3450 lbs. But at this point it might actually be faster on track than what I have. At the same time, it would also narrow the gap to the GT3 by another $10k, but still a lot of bang for the buck really. $75k is not bad for that much performance. |
06-04-2018, 07:10 PM | #70 | |
Rep 3,659
chris7197334.00 Threeebowel31.50 |
06-04-2018, 07:20 PM | #71 | |
Rep 7,298
Stock M2 N55, note power at 4k for example: http://www.n54tech.com/forums/attach...1&d=1461367934 Modified E46 M3, headers, cat, and tune: http://alexroyphotography.com/dyno_d...uro200_SAE.jpg S55 is a very strong engine and so there is no way the difference between an S54 and even a detuned S55 is only 40 HP. Car and Driver measured a larger difference on the same dyno comparing an S65 V8 M3 to a new F8x one. The same S55 engine in the M4 CS makes a conservative 453 crank horsepower, so 500 with a tune is not very far off. For the record, I'm not putting the S54 down. It's a better engine than N55 for a sports car in my opinion, but the power and specifically area under the curve cannot compete anymore. |
06-05-2018, 08:21 AM | #72 | ||
Rep 552
I had my M3 on a scale with 1/3 of a tank @3170 lbs when I had it at a track event (FWIW, I do remove a few more things for track days that only take a few minutes, sub-woofer, rear fold down seats). Bottom line, it's pretty close to 3200 lbs with full tank. I know from first hand experience that these modern turbo engines make a lot more usable power than the hp numbers suggest. I've been DD a GTI for 5 years, and even though it is rated at only 200 hp (238 with the tune I have) it feels nearly as fast as my M3, despite looking much slower on paper. That turbo torque is just so much more usable on acceleration than a N/A engine, there is no doubt! On the flip side though. On track, ~80% of the time I am in the peak hp range, even with this N/A engine, and I am always amazed, when I compare to other cars on track that I know have way more power, that they there isn't all that much of a difference. Lightness seems to matter more, which is why I was having doubts about the M2C. Yes, as you suggested before, there are probably ways to get it in the 3400 range, but that is still not light, however with the amount of extra power you are suggesting it makes, it should be reasonably quicker. Quote:
See what I just wrote above regarding the GTI. I see your point and was aware of the difference between the engines for the most part. I can't deny that these new turbo engines have way more potential. That is the downside of the old M engines, not much room left to improve them without FI. If I was using this car 80/20 for street/track, then the decision would be easy, M2 would be the clear choice, but being that this car is really more 80/20 track/street, its not so clear. |
06-05-2018, 10:34 AM | #73 | |
4143
Rep 6,926
E46 M3 tank is 16.6 gallons, 90% full would add another ~55lbs of fuel. Rear fold downs are about ~35lbs, rear bottom cushion another ~10lbs. That is another 100lbs right there. Plus whatever else you remove. You need to factor these things in, if you truly want to make an apples to apples comparison for the track. |
06-05-2018, 10:58 AM | #74 |
Rep 24
Hey peeps, this is the car forum format at it's best, very informative. It's amazing to read level headed commentary instead of gut reaction and hyperbole.
Very enjoyable. |
06-05-2018, 06:54 PM | #75 | |
Rep 7,298
Have you considered a Cayman S/GTS? Either 981 or the new 718. For 80% track it might be just the thing if you want lightness. |
Phil-on-Cars27.00 |
06-05-2018, 10:07 PM | #76 | |
Rep 552
Yes, I could potentially find similar weight savings on the M2, and your point is valid. Reason I hesitate to compare it in such a way, is because I don't know if they will be as easy to do on the M2. The weight reduction has been a process and evolved over time. I just recently started to remove the rear fold down seats for track events, because I realized it is literally one screw that holds them in place. Or the sub woofer for example. takes 2 minutes to remove. I have no idea how difficult these type of things would be in the M2, so I can't really count on them. I honestly lost track where I am exactly with the weight, but I am thinking that even with a full tank I am not over 3200 lbs, or if, not by much at all. In conclusion to all off this, I am leaning towards keeping the e46 M3, but if I were to get an M2, then a Competition almost makes no sense,because it was suggested that the best way to get the weight down is to get lighter seats and a lighter BBK, which are 2 out 3 reasons why I wanted the M2C in the first place. So that only leaves the better engine, which I doubt is worth an extra $10k. It looks to me like getting a lightly used M2 for around $50k, and modify it to my liking would be a better way to go. Yes, actually driven my buddies 981 Cayman S several times on and off the track. Great car, checks most of the boxes. My only complaints are, it's not a 911, has no rear seats and is under powered (or the gears are too tall). I smoke it on the straights and the lighter weight & balance of it, are not enough to make up the difference in the corners. In other words, it is pretty much on par with my car performance wise. But I do like them and would not rule it out as a possibility some day. Last edited by norMcal; 06-05-2018 at 10:13 PM.. |
06-05-2018, 10:22 PM | #77 |
Rep 258
tl;dr - have you decided yet?
06-05-2018, 10:28 PM | #78 | |
Rep 2,787
06-06-2018, 08:11 AM | #79 | |
Rep 552
Excellent input on the S55. Maybe I haven't given it enough credit. Thanks! |
06-06-2018, 08:24 AM | #80 |
Rep 11
I say GT3, you appear to be a track guy and what you have in hand is a known quantity in that regard. The GT3 is also a known quantity. You also seem to have an emotional connection with both of them. The M2C looks great to me, and appears light "enough" for my needs. You sound like you would be happier with the Porsche. I see that as a major save and buy item, you won't do that often so get what you want if you can.
norMcal284.50 |
06-06-2018, 01:45 PM | #81 |
Rep 14
I am on the regret wagon with others, still regret selling my 01 Steel Gray 6-speed M3 and I sold it 15 years ago, best car I ever owned.
Keep the E46, and save up for the GT3. |
norMcal284.50 ///M Houbi1655.00 |
07-03-2018, 12:46 PM | #82 | |
Rep 552
Passing on the M2C boiled down to these 3 factors for me:
The fact that the M2C is heavier, doesn't come in any colors that I really love, and those hideous wheels only contributed to my decision. |
S1monQc223.50 |
07-03-2018, 03:41 PM | #83 | |
Rep 576
I myself decided to go M2C. The large brakes and motor and revised suspension quite an improvement to make the change. I had both the M2 and the E46M3. Both great cars. Last edited by gtr; 07-03-2018 at 07:15 PM.. |
07-03-2018, 05:26 PM | #84 | |
Rep 552
You're right, for that price the GT4 is a better car. I suspect they will be hard to get for MSRP though. |
07-04-2018, 07:34 PM | #85 |
Rep 837
This has to be among the most ridiculous things I've ever read. Why would someone's wife have this much control over their husband's car purchases? Get a divorce. Problem solved.
And yes... I am married and my wife couldn't care less about my car purchases. |
07-04-2018, 10:51 PM | #86 |
Rep 190
This might be crazy, but have you considered a used, dedicated track/race car? This is going to be just a track car, right?
Otherwise, P car all the way. It's obvious that's what you want. |
07-05-2018, 06:35 AM | #87 | |
Gone Fishin’
7318
Rep 12,125
There will be a new M2 in a couple years like some said. There will also be a new GT3. I live by YOLO as long as it's not financially irresponsible. |
07-05-2018, 06:53 AM | #88 |
Rep 7,594
Drives: '19 M2C
YOLO! Agreed. You only get one ride on the merry go around (Depending on Religion)
