05-16-2016, 11:20 PM | #45 | |
Rep 2,370
Soon. |
05-16-2016, 11:46 PM | #46 |
Rep 2,200
whats up with these comments? Its not like we did not know the 240 is coming out, we knew about it even before we knew what motor was to be thrown in the F87. Now the real bummer would be if BMW announce that its throwing in the B58 in the F87 for 2017.
05-17-2016, 12:07 AM | #47 |
Rep 2,948
Well, if you thought BMW wasn't making enough M2's, they're now going to probably make less. Not only does it have a now-outdated engine, which wrecks hell on assembly lines, it also has a much closer in nature little brother.
Dealerships will have a much easier time moving people into the M240i as they can in essence say it's comparable performance (same torque, same 0-60 time) but has the added benefit of AWD. Here's hoping those with MY16 M2's don't get screwed over in case of any major changes coming for MY17, like say a new engine but same HP/TQ figures. |
05-17-2016, 12:17 AM | #48 | ||
7906
Rep 11,785
05-17-2016, 12:22 AM | #49 | |
Rep 2,200
05-17-2016, 12:42 AM | #50 | |
Rep 368
05-17-2016, 12:49 AM | #51 |
S0THPAW
8717
Rep 7,846
In real life the M2 puts about 369lb/ft/500Nm on the rear wheels.
In real life it's faster @ Hockenheim short than a lot of way more powerful cars. In real life it has a real limited slip differential and bigger brakes. In real life it sounds better than 'any' stock BMW I've heard since the M3 CSL.(imho) In real life it looks better than 'any' stock BMW I've seen since the M3 CSL.(imho) What exactly do we know about M240i's performance? Only the torque at the crank? M235i is 3 sec slower @ Hockenheim short than M2.... And the engines are 'almost' the same, so the chassis is something else... It's not only about torque on paper it's how they/you use it And B58/N54 are/were midrange pullers, this one you have to rev more. >7000 so to say Cheers Robin |
05-17-2016, 12:49 AM | #52 | ||
Rep 2,200
colors. Plus a higher M240i production output means a lower M2 production output since they share the same factory.
05-17-2016, 12:54 AM | #53 | |
S0THPAW
8717
Rep 7,846
Cheers Robin |
05-17-2016, 01:11 AM | #54 | |
Rep 368
05-17-2016, 01:20 AM | #55 | |
Rep 763
05-17-2016, 01:22 AM | #56 | |
S0THPAW
8717
Rep 7,846
Those engines are 'almost' the same, for M2 fanbois unfortunately. So 240i would have 380/390/400 crank hp irl(EU)? Everything is possible these days... Cheers Robin |
05-17-2016, 01:23 AM | #57 |
Rep 3,659
Drives: 981 Cayman GTS
Sorry, I noticed what you meant a little late and deleted my comment. I agree with you.
05-17-2016, 01:30 AM | #58 | ||
Rep 2,200
05-17-2016, 01:35 AM | #59 | |
S0THPAW
8717
Rep 7,846
That's a 30HP crank difference on paper. Since both B58 and N55 in M2 are underrated there will always be the '30HP' difference am I wrong? Cheers Robin |
05-17-2016, 02:16 AM | #60 |
Rep 1,153
A Pure Stage 2, or even a Dinan kit for masochists, is going to fix all this, if anything needs to be fixed at all. Personally, give me a small car with good brakes, good suspension and a good engine that can be modded for 50-75 ft lbs more, as opposed to a bigger X drive sedan that will need extensive work on all its "systems" to hang with its little brother when the helmets go on, or even just in the twisties.
I've driven a M235, and an M2. Just adding more torque to the former won't give me what I want, of this I am sure. Adding torque to the latter is a much more interesting proposition, but first, I need the car, to tweak if and when I want to. Still want it. |
05-17-2016, 02:43 AM | #61 |
Rep 328
Drives: Ex BMW owner, will return soon
Guys, it has nothing to do with the fact that the M2 isn't meant for straight line speed. We all know very well that the M2 is more desirable, looks much better and handles much better than a M240i but don't you think it's kinda stupid to have a newer improved engine with just as much torque without the need of overboost into a cheaper model in the range while the top of the line model keeps the older out dated engine? I hope the M2 facelift gets the B58 if not then I expect a power bump.
05-17-2016, 03:03 AM | #62 |
Rep 354
I don't see the reason for this amount of "trolling", as it was expected long before that they need to keep up with Golf/S3 range so this power upgrade was expected.
For many of you that got M2 by now, you should know very well that M2 is properly built track day, that after 30-40 minutes of hard session it wont overheat like M235i or M3/M4 which is know that it starts to lose power after just 10-15 minutes. That's why it looks so mean with a good reason and that's why it has those extra coolers at the bottom which M235-240 wont ever have. Not to mention the suspension the rev-matching transmission and etc.. |
05-17-2016, 03:18 AM | #64 |
Rep 328
I hope the engine in the M2 has a better throttle responsive and less turbo lag.
05-17-2016, 03:28 AM | #65 |
#12
516
Rep 475
Drives: Alpina B3 G21 Touring
Guys, please calm down on this. Please drive the M235i (M240i) and let me know your thoughts. The chassis and handling is another stratosphere in the M2. BMW M cars were never about a high amount of torque or hp. It was always about the driving dynamics and the chassis/balance. That is what makes them so special. Both, the Merc AMG and Audi RS cars always have an advantage in hp (and torque as long as we talk about the AMG), but they are not faster as long as we talk about "track-ability". Visit the Nurburgring and see for yourself why most of the guys chose to drive there with a BMW M car - because they are simply fantastic when it comes to high speed in corners and the sheer fun you can have with the car. To argue that the M240i with xDrive is faster, is just stupid (by the way - who wants to have a M car with xDrive?). Drive both back to back on a alpine road or on a racetrack and see for yourself.
2022 G21 Alpina B3 - DG/COGNAC - 8ZF
2019 F82 M4 S55 ZCP - SO/CLOTH - DCT (Sold) 2017 F87 M2 N55 - LBB/LCNL - 6MT (Sold) 2005 E46 M3 S54 - TS/GN5TT - 6MT |
