09-09-2018, 05:20 PM | #1 |
Rep 112
Style 225 19, will that fit?
Looking for a winter setup and find a used set of style 225 19 wheels. I realize that its only 8x19 and 9x19. Will that still fit on a M2C properly? Is that too narrow? Thanks
09-09-2018, 05:50 PM | #2 |
Rep 1,092
The rears will be 13mm deeper into the wheel well compared to stock, the fronts would be 20mm so to make it look right you should use spacers.
I happen to have exactly the spacers you would need (20mm and 15mm) and will be most likely selling them as soon as I make a final decision about my winter setup. |
09-18-2018, 08:10 PM | #3 |
Rep 614
My winter setup is 225/40/19 on 8.5x19 ET35 437M replicas square setup. I went with narrower tires to cut better in snowy conditions. The Nokian Hakkapeliitta R2s were inflated to 41 during winter. Front looks fine. The rear is a little tucked in but not much.
https://f30.bimmerpost.com/forums/sh...9#post22416709 |
