01-03-2019, 06:38 PM | #67 | |
Rep 7,299
01-03-2019, 06:56 PM | #68 | |
Rep 7,431
but for bmw's we mainly have to worry about AGM, and lithium. I don't think bmw uses gel based batteries.
01-03-2019, 06:57 PM | #69 | |
Rep 3,968
and I seem to remember having a battery in the trunk of my 1995 325i are you saying that was AGM as well? How about my 2000 540ia? Wow!
01-03-2019, 07:02 PM | #70 |
Rep 7,431
Hey man, I don't mean to insult anyone (which is why I have never made an insulting comment directly at you), I just don't want there to be misinformation because like I said earlier that could really mess someone else up down the road.
01-03-2019, 07:15 PM | #71 | |
Rep 7,299
Any car with a non-AGM SLA battery (and even some with) will have a vent to external atmosphere. If they used a non-AGM in the E36 it would have had to be vented. I see ventilation warnings if I select a non-AGM battery for a 1995 325i at O'Reilly. I don't know when BMW made the switch, but for a 2000 540 it may well be AGM. AGM is a safer battery to have inside a car because they emit much less H2S. I do not think there are any modern cars that have a flooded battery under the seat or in the trunk for safety reasons. I will guarantee you 100% that your 1M battery is/was AGM. Here is the overwhelming evidence: 1. Same part number as AGM battery. 2. Same exact CCA and AH ratings - a flooded/wet battery would have a lower CCA rating in the same volume. 3. Same markings, cuts, indentations on the enclosure as the battery with the AGM sticker. Strongly suggests the same factory. 4. Interior battery for a modern BMW that isn't using Li-Ion. Your only counter argument was that the sticker does not say AGM. Well, it's a label. They get revised sometimes. Maybe it was an omission on an earlier lot, maybe regulatory requirements made them add that text later. Last edited by chris719; 01-03-2019 at 07:23 PM.. |
01-03-2019, 11:29 PM | #72 |
Luxury at the redline :)
9105
Rep 7,563
I'm saving up my pennies to get this beauty. It has enough mobile power (2000 CCA), to independently jump start any BMW and can power any electrical device that uses a 12V (Cigarette lighter) outlet..
So far as my battery is concern; 'if it dies, it dies' |
01-03-2019, 11:51 PM | #73 |
Rep 7,299
I would look into a supercap jump starter instead. The lithium ones are fine but you have to remember to keep them charged. Self discharge is relatively high on lithium batteries and if you leave them in your car for a few months they may fail to work when you need it most. Plus, the supercaps won't spontaneously combust on you if you are unlucky like lithium cells will.
Poochie9104.50 |
01-04-2019, 12:03 AM | #74 | |
9105
Rep 7,563
As far is keeping it charged, all BMW trunks have a 12V outlet, I could just snake the cable from the plug to the power pack, if it's located in the battery compartment, to keep it juiced up. The reason I like this Noco unit is because it carries enough power to release the power trunk, giving you access to battery when it's dead. Since BMW didn't add a manual trunk release. Plus, it nice to have mobile juice, never know when it might come in handy. |
01-04-2019, 12:56 AM | #76 |
9105
Rep 7,563
01-04-2019, 12:57 AM | #77 |
Rep 7,431
The m2's middle trunk pass through in the back seat area can tilt down with the lever, so if my battery ever dies I can just open the door with the key, hop into the back seat, open the pass through and I can use a stick to assist in pulling down the emergency trunk release, or use a stick to poke the the back seat release to tilt the rear seat down and then crawl into the trunk to manually pull the trunk release.
01-04-2019, 01:06 AM | #78 | |
9105
Rep 7,563
US spec M2C rear seats: |
01-04-2019, 01:23 AM | #79 |
Rep 7,431
That's weird my 2017 bmw m2 has that pass through, i'm not sure about the m2c though.
01-04-2019, 08:39 AM | #80 |
Rep 3,968
I did what nobody here would do... I emailed Ctek
Q: For the 4.3 charger with a BMW OEM AGM battery, should the snowflake mode be used? The FAQ is not clear on this so I was looking for a definitive answer. A: There are many different battery manufacturers and battery models on the market. Recommendations regarding charging voltage vary a bit. Most AGM- batteries are recommended to charge with normal 14.4V voltage. Some AGM- batteries (and Ca-Ca batteries) require 14.7V (snowflake) for best treatment. Please check with the battery manufacturer to get the correct information for your particular battery. If no information is possible to acquire, use normal charging option, 14.4V It suits most lead/acid batteries, including GEL, EFB, AGM, etc. It is better to charge with a bit too low voltage than too high. Yours, sincerely, Teresa CTEK SUPPORT TEAM
bplewis24188.50 |
01-04-2019, 09:28 AM | #81 | |
Rep 7,299
The advantage is that you can keep it anywhere and don’t have to every worry about charging it. |
Poochie9104.50 |
01-04-2019, 01:36 PM | #82 | |
Rep 7,431
I looked at varata and one of their PDFs (from a dealer, but it was a varata technical document) for their 92AH AGM batteries recommended a 14.8V charge voltage. They don't sell an exact battery that they offer for BMW only 85Ah, and 92Ah, and 95Ah models. I tried looking for more information but their website isn't too good, as a bunch of links were dead. The contact tab lead only to dealers, so the only good info I found was the PDF of the 92Ah battery, which isn't necessarily the same as ours. I'll charge it on snowflake mode because their other AGM batteries can charge to 14.8V, and it's in a cold winter storage which is what snowflake mode is meant for as well. Plus the IBS will stop charging when it's full. Varata's website also says with a good quality charge it's impossible to over charge the battery, so if you guys charge directly to your battery with it removed I guess depending on the storage temp you'd vary between normal or snow flake. Here's some ibs info if anyone is interested: https://bimmerscan.com/bmw-intellige...ry-sensor-ibs/
01-04-2019, 03:12 PM | #83 | |
Rep 7,299
12-29-2021, 01:00 PM | #84 | |
Rep 97
So I figured best to just use the "normal" (14.4V) mode on the CXS 5.0 instead of the AGM (14.7V) mode... |
12-29-2021, 02:31 PM | #85 | |
Rep 7,431
12-29-2021, 02:40 PM | #86 | |
Rep 7,299
The ideal bulk charging voltage is a property of the cell, and many quality AGMs can perform slightly better using 14.7V to reach full SOC. Why does BMW print 14.4V? Maybe the OEM battery is happier there, but I'd guess they are accounting for aftermarket batteries and safety margin. Porsche uses nearly identical batteries, possibly even from the same supplier, and they call for 14.7V. I'd stick to their recommendations I suppose because BMW likes to do weird stuff for no reason. This is also a function of temperature, which is why the AGM mode has a snowflake on other CTEK chargers. Last edited by chris719; 12-29-2021 at 02:47 PM.. |
12-29-2021, 02:56 PM | #87 | |
Rep 3,337
M2Comp battery M2 battery It's application is shown across a zillion other BMW models also.
Current Stable:
CanadianComp125.00 |
12-29-2021, 03:16 PM | #88 | |
Rep 7,431
