12-31-2018, 04:50 PM | #45 | |
Rep 3,968
Because www.smartcharger.com is the website for Ctek and that is where my post came from. I'm sorry you feel it is poorly informed - maybe you should reach out to them? Wait, don't they make the charger? Maybe you should switch chargers if you feel they are poorly informed? I'm still laughing at this whole thing.
12-31-2018, 06:34 PM | #46 | |
Rep 7,298
You know, the current flat plate style AGM batteries have existed since the mid 1970s. I think there are some people that might understand them. Got any facts? Or more "butbutbut the website said" bs. You're safe to charge any automotive AGM battery that fits in your BMW at 14.7V max, which is the AGM mode of the Ctek. Last edited by chris719; 12-31-2018 at 06:43 PM.. |
12-31-2018, 06:57 PM | #47 | |
Rep 7,429
The BMW M tech at my dealer also confirmed they use ~13V for lithium, and ~14-15V for all lead acid AGM batteries. You do realize ctek can't make a guide for all batteries right? They just mentioned a few AGM exceptions that shouldn't be used with snowflake mode, I don't know how you got BMW as one of those. Otherwise snowflake mode is the only one sufficient for trickle charging any AGM battery, the other modes will under charge it or over charge it. So I'm not sure what you would have used. Plus ctek makes the oem BMW part for their battery chargers with snow flake mode, that should be the final straw in saying it's safe to use. Last edited by F87source; 12-31-2018 at 09:04 PM.. Reason: Quoted wrong post |
12-31-2018, 07:12 PM | #48 | |
Rep 7,298
12-31-2018, 09:02 PM | #49 |
Rep 7,429
01-02-2019, 04:22 PM | #50 | ||
Rep 537
I actually disconnected my 335i battery before using the Ctek to see who the manufacturer was, just to make sure. Quote:
Yup, those "higher end" manufacturers are likely the ones Ctek is referring to for Snowflake mode.
Brandon
01-02-2019, 04:39 PM | #51 | |
Rep 7,298
01-02-2019, 05:22 PM | #52 | |
Rep 3,968
The quote is "It depends. Optima and Hawker recommend snowflake mode. If there is no indication on the battery, use car mode for batteries over 14Ah or "MC mode for batteries under 14Ah." The real question is what do they mean by "indication" ?
01-02-2019, 05:25 PM | #53 | |
Rep 537
Just to provide a source for what I found, this was in the manual of the product I purchased (Ctek 4.3):
Brandon
01-02-2019, 05:57 PM | #54 | ||
Rep 7,429
01-02-2019, 05:59 PM | #55 | |
Rep 7,429
01-02-2019, 06:34 PM | #56 | |
Rep 7,298
In reality, the differences between the two modes are small. You won't make an AGM battery explode (or sulfate, on the other side) in the wrong mode. It's not like the desulfation / reconditioning mode that applies a much higher voltage. |
01-02-2019, 09:44 PM | #57 | |
Rep 3,968
What he quoted is similar to the FAQ I posted from Ctek's website... ...and when you are taking advice from a "BMW M tech" that's funny too (I guess you have not been around on the boards very long to hear some of the malarkey some of them preach - like how they "unlock" your car after the 1,200 mile service). Do note, that there are plenty of them that know what they are preaching, and plenty that don't (so not making your guy/gal out to be uniformed, just pointing out that they might not be the right source). Anyway, let's clarify a couple of things... 1. Neither my M3 or my 1M has an AGM battery. So I won't be using the snowflake mode on either car (heck, I don't think my Lithium Ctek charger has any modes....) 2. I'm simply pointing out what Ctek says from their FAQ. While I don't know who writes for them and I'm not sure I agree that an intern or a schmuck wrote it, but I do know it was from Ctek. The funny part is that you and Chris are getting all upset when it is probably best that you email or contact Ctek on the matter because I have continued to only point out what they print (or their intern writes on their "poorly informed webpage "). So no need to get frustrated with me, I'm not the bad guy here
01-02-2019, 10:43 PM | #58 | |
Rep 7,298
01-02-2019, 11:56 PM | #59 | |
Rep 7,429
The only way you would not have an AGM battery is if you replaced it with an aftermarket lithium, or sulfate based battery which would require alot of coding... So there's another mistake you made, funny how you call me a "beginner or noobie".... Yeah the lithium charger for the m3 should only have one mode, although I'm not sure, but yes the lithium batteries charge at a lower voltage (somewhere in the 13v range) like I said earlier, so yeah you can't use snowflake mode if it were present. In the manual, which clearly overrides the FAQ section as that is mainly where manufacturers post email questions that pop up alot, and can be answered by any rep, says that the snowflake mode is recommended for AGM batteries. If you are not sure contact the battery maker, not CTEK as they really can't answer that question for you, and since the manual already stated that snowflake mode was for AGM batteries there wouldn't be much of a benefit to call. The only reason why we are frustrated is because you keep pointing out false information, FAQ aren't a reliable source of info compared to an instruction manual which also refers to speaking with the battery maker, and in this case bmw. |
chris7197334.00 |
01-03-2019, 04:17 PM | #62 | |
Rep 7,429
Dang batteries weigh too much right? But since they're in the rear lighter ones will shift the weight balance to the front, who do I complain to?
01-03-2019, 05:14 PM | #63 | |
Rep 3,968
Mine does not and no, it was not replaced. https://www.1addicts.com/forums/show...1334779&page=2
01-03-2019, 05:17 PM | #64 | |
Rep 3,968
chris7197334.00 |
01-03-2019, 05:41 PM | #65 | |
Rep 7,298
BMW would NOT put a flooded battery in the trunk. You are welcome to put a flooded battery inside your car and see what happens after a few years. Honestly, Sherlock, I don't know who pays you enough to afford a BMW with those reasoning skills. |
01-03-2019, 06:16 PM | #66 | |
Rep 7,429
Just because it doesn't say AGM doesn't mean it isn't, bmw sometime doesn't label everything as they refine their stickers. That's probably why the later model batteries included it. It's funny how you can ask you SA in the thread but when someone else does it then they're gullible. If the part numbers don't change or the battery wasn't superceded then it is the same battery but with different stickers......
