07-18-2018, 05:46 AM | #1 |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
battery
I checked the tech spec sheet to determine if the M2C battery is the 69AH lithium from the M4 or the same 80AH of the M2 but did not find any info.
Would like to know if the Lithium CTEK charger is the right one for the M2C. Look at the price difference between the two batteries: https://www.leebmann24.de/lithium-io...218047221.html https://www.leebmann24.de/original-b...217555719.html So if anyone finds out, please share. |
07-18-2018, 11:30 AM | #4 |
4143
Rep 6,926
07-18-2018, 11:32 AM | #5 | |
4143
Rep 6,926
Some info from another thread. M2 at Goodwood had a lightweight battery.
07-18-2018, 02:54 PM | #6 |
4143
Rep 6,926
Seen some Porsche owners buying this battery. Only 11.5 lbs, has a built in restart tech. Eliminates the worry of light weight battery leaving you stranded.
https://shop.antigravitybatteries.co...omotive/rs-30/ |
akkando5864.50 |
08-01-2018, 02:31 AM | #8 |
4143
Rep 6,926
08-01-2018, 03:42 AM | #11 |
Rep 2,856
Hahaha if only you knew BMW is getting more anal in certain countries on any change you make.
I would not be amazed that within a few years time, you loose your warranty when you put a tennis ball on your tow hook as protection or hang an air refresher on your rear view mirror. MR |
///M Houbi1655.00 |
12-06-2018, 07:14 AM | #12 |
Rep 16
I have a few questions
I hooked up my battery charger to the car but in what mode do i need to put it Normal of li ion ? And does anyone know of you van shut the hoofd when the charger is hooked up ? I am afraid to damage the jood with closing it? |
12-06-2018, 08:33 AM | #13 | ||
Rep 54
Something like the CTEK MXS 5.0 (selecting the AGM option) would be OK. Last edited by Abrunho; 12-06-2018 at 08:46 AM.. |
12-06-2018, 06:28 PM | #14 |
Rep 578
Void your warranty because lithium batteries have different charge rates. That's why you need a dedicated lithium charger. Not worth it if you ask me.
2019 M5 - Marina Bay Blue/Silverstone
12-06-2018, 06:46 PM | #15 |
Rep 3,337
The M2C does not have an Li battery. It's a standard AGM battery.
Current Stable:
12-06-2018, 07:04 PM | #16 |
Luxury at the redline :)
9105
Rep 7,563
In an already 3,500lbs vehicle, is the potential of losing 30 - 50lbs really worth the chance of getting stranded..
Hard pass for a daily driver.. Track or weekend car, maybe.. |
12-07-2018, 09:09 PM | #18 |
Rep 7,298
I am not sure about the OEM lithium, but in general lithium ion chemistries tend to perform poorly at low temperatures. I would not want to be stranded in the name of saving 30 lbs that is already over the rear of the car.
Agree w Poochie |
12-30-2018, 06:54 PM | #19 |
Rep 7,429
I don't think the CTEK is compatible with lithium ion batteries, just AGM, because litihum batteries run at lower voltages so the CTEK may over charge them. From what my SA told me the dealers use different chargers for the lithium batteries, so depending on what the M2C has use a respective charger for that battery.
12-30-2018, 07:14 PM | #20 |
Rep 3,968
Actually I just read that the snowflake mode is only for certain AGM battery manufacturers and I don't think the BMW is one of them.
12-30-2018, 08:23 PM | #21 | |
Rep 7,429
Also note: You don't charge directly to the battery, you do it via the terminals under the hood otherwise you damage the IBS. Snow flake mode pushes I believe 13.7V which should be fine with all AGM batteries. The IBS will stop any charging if it's too much and you'll get an error (if done so under hood), that's how you should know if it's over charging. Plus BMW resells rebranded ctek chargers, and so do pretty much all major car brands. I've used a ctek multius 7002 for 2 years no on snowflake mode without any issues whatsoever. |
12-30-2018, 09:02 PM | #22 |
Rep 7,298
All automotive AGM batteries are basically the same, and there are only a handful of manufacturers in the world. I think most BMW AGM batteries are mfg by Varta or Exide. Johnson Controls, Exide, and East Penn (Deka) make almost all the AGM batteries out there. There are some higher end batteries like Odyssey and Northstar which are a bit closer to a deep cycle design, but the fundamental chemistry is identical.
