04-01-2022, 12:57 PM | #397 | |
Rep 309
Drives: 2018 M2 LBB - 6MT
This is a dumb question honestly, but one thing I wasn't sure was what's required in order to swap the 51758061866 piece in.
I definitely wanna DIY this, but this will actually be the first mod that requires me to invest in new torx and e-torx sockets (I know right?), and I wanna make sure I have all the right tools. Unrelated to the partition piece, I guess I'll also need to buy a rivnut tool. I'm still not entirely convinced if I should DIY this simply because I don't know when I'd ever use this tool again lol. Thanks for the help! |
04-01-2022, 01:32 PM | #399 |
844
Rep 1,962
As for the rest: in order to swap the original part for 51758061866 Partition, equipment area, top: I had to remove the aluminium brace - which meant I had to remove all the trim at the bottom of the windscreen, and so the wiper arms had to come off.
HTH |
gphung193.50 |
04-01-2022, 02:21 PM | #400 |
844
Rep 1,962
So yes: You are going to have to remove the wiper arms, the windscreen cowl, the trims that attach to same, the trims around the hood hinges, the rubber covers for the strut tops, the existing strut brace, the strut tops themselves and the bush for the slam panel mounting.
The existing braces at the front are possibly optional, but probably superfluous if you fit the CF brace. HTH |
gphung193.50 |
04-18-2022, 07:40 PM | #401 | |
Rep 1,314
05-09-2022, 11:37 AM | #402 |
Rep 1,314
Tight fit. Needed about 3 spacers in front. And adjusted hood Latch one twist. Foam padding under the brace as they will be touching. Used the same length screws as the ones used on the 2 locations mounting to the aluminum bracket.
05-18-2022, 09:10 AM | #403 |
Rep 309
I tried looking everywhere for this info but failed to find it. Do you guys know what size E-torx I need for the 6 bolts (3 per side) that secure the aluminum brace onto the top hats (31106859809)?
I know I should be getting a full E-torx and torx set, but I just wanna make sure whatever I'm buying isn't missing the one I need. Thanks! edit: Clearly I didn't actually look everywhere. It just hit me Farkle makes really amazing in-depth videos and he says E12. Last edited by gphung; 05-18-2022 at 09:54 AM.. |
05-18-2022, 12:27 PM | #404 |
844
Rep 1,962
I'm not sure that's the right part number...
Edit: I think you want 31106859809 - Torx screw with collar. But mine currently uses a regular Hex bolt with captive washer. Which is strange - as the pics of the original install I did show 31106859809... Last edited by M Fifty; 05-18-2022 at 05:01 PM.. |
gphung193.50 |
05-18-2022, 11:35 PM | #405 | |
a coffee drinker
96
Rep 162
Parts list As I recall, a forum member posted a recent list on Google Docs. |
05-18-2022, 11:37 PM | #406 |
Rep 309
Yup you're right, I accidentally copied the wrong part from my parts order invoice. I indeed meant 31106859809 and I have 6 qty of that. Edited my post to hopefully prevent confusion. Thank you!
06-16-2022, 02:47 PM | #407 |
a coffee drinker
96
Rep 162
BMW (51-61-8-061-631) - Price Drop
This mod has gotten much more interesting (price-wise). Whether on purpose or by accident, BMW has lowered the price of the Carbon Fiber Strut Brace by $1K.
MSRP ~ $800. New may be found @ 20% off or close to $625. Used ought to see prices drop to 50% of that. Guessing all the parts, including new trim, if desired, may be found for less than $2K. Used prices were all over the place. Thinking this mod is overdue for me. Strut, CFRP - Front End - BMW (51-61-8-061-631) Last edited by Zeese; 06-16-2022 at 03:50 PM.. Reason: Clarifying price info |
06-16-2022, 03:34 PM | #408 | |
844
Rep 1,962
06-18-2022, 06:03 PM | #409 | |
Rep 97
I can also confirm that the prices for the carbon fiber brace significantly dropped, I was able to order the full parts list brand new for roughly $1700. The aluminum strut brace is back-ordered though, the dealership estimated 2-3 weeks for it to come from Germany. |
07-27-2022, 01:04 PM | #411 | |
844
Rep 1,962
I think it might just be the fender panels that are different? Last edited by M Fifty; 07-28-2022 at 01:17 AM.. |
07-27-2022, 01:08 PM | #412 | |
844
Rep 1,962
08-16-2022, 03:46 PM | #413 | |
Rep 488
Next time I pull it apart, I might get some large hex bolts, so that in future I can just use a ball-ended hex bit at an angle, and save undoing the bodywork. WT |
08-19-2022, 03:31 AM | #414 | |
Rep 553
Was thinking of doing my own cut-out on the guard but a panel beater mate recommended against it saying that removing the half-round edge will weaken the panel. |
widetyres279.00 |
01-03-2023, 11:16 AM | #415 |
Rep 1,244
Drives: 2017 Big Turbo BMW M2
looking to install this soon but just had questions about the parts, do I need to run all the plastics or is it optional ? I seen some run without it but not sure if that causes potential risk for water damage
01-07-2023, 10:30 AM | #416 | |
Rep 221
I do not run the bolts requiring the rivnut tool. Aluminum brace alone made a significant difference |
shaneguags1192.50 |
05-04-2023, 03:28 AM | #417 |
Rep 867
Drives: OG M2
Does anyone know what other intakes will fit with the carbon brace besides OEM and Eventuri? I'm wondering if I can get this done with my current CTS intake...
05-05-2023, 01:40 AM | #418 |
Rep 867
Drives: OG M2
Okay so just confirmed that this retrofit will not work for the CTS turbo intake for anyone wondering! Does everyone else have the issue with the aluminum brace pushing down on the battery terminal? I put a few layers of electrical tape around the area but I'm wondering if there's anything else I need to do to ensure I won't have any issues?
shaneguags1192.50 |
Tags |
bmw m3, bmw m4, carbon fiber strut conversion |
