05-01-2020, 07:42 PM | #1 |
Rep 76
Will 19x9.5 +25 and 19x10.5 +35 fit ohlins,
Hi, I half made my mind about the setup i would like to run and need some insight if it will work. And i mean no rub if tracked, no femder rolling. I would be down to mildy reshape liners with hear, no cutting.
Looking to get ohlins with a mild drop, 10-15mm or 3/8 to 5/8 inch. With vorshlag camber plates -2 deg of camber front and rear 19 x9.5 +25 265/30r19 michelin 4s 19x10.5 +35 295/30r19 mich 4s. Known closest fitments that i have seen Titan 7 19x9.5 +27 and 19x10.5 +44 Apex 19x9.5 +28 and 19x10.5 +45 Vorsteiner 19x10.5 +42 Richland forge 19 x 9.5 +26 and 19x10.5 +35 Thanks all |
05-22-2020, 09:01 PM | #2 | |
Rep 41
05-22-2020, 09:29 PM | #3 |
Rep 2,700
Might need spacers, I rubbed OEM wheels with 255 front michelin Cup2 tires. Ohlins
05-22-2020, 11:08 PM | #4 |
Rep 309
Drives: 2018 M2 LBB - 6MT
Fronts probably need at least a 15mm spacer. At -2 degrees of camber, I think it'll be close. More camber and you should be fine, but can't get away without spacers.
Rears will rub. People usually run 40 offset or higher on 10.5 or higher widths in the back if they want to run 295s. For some perspective, 437M wheels are 19x10 +40 and people are barely getting the 295s on with stock suspension. The first 3 other fitments you've listed make more sense, rear wise. |
05-23-2020, 05:28 PM | #6 | |
Rep 41
05-23-2020, 05:32 PM | #7 |
Rep 2,700
Only 10mm.
