09-19-2022, 08:34 PM | #1 |
Rep 1,644
18" Wheel Square Setup DSC and TPMS
Is there a 100% consensus for:
1. Does 18" square wheel setup cause issues with DSC? 2. Does No TPMS sensors cause issues with faults? I.e. forcing into comfort mode like with low pressure |
09-19-2022, 11:54 PM | #2 |
Rep 427
It’s the internet; good luck finding 100% consensus on anything.
But in my personal, first hand experience in a 2018 6MT car; 1) For a while, yes. The car does seem to be able to adapt after 50 or so street miles for the most part. I won’t claim it’s perfect, but it wasn’t significantly worse than with OEM stagger. I’ve run square on both the street and track. It was fun and I saved a fair bit on track tire budget by being able to rotate front to rear. With either staggered or square though, the DSC on our cars is far too invasive, and getting to a point where I’m comfortable with DSC off has made a huge difference. 2) In 4 years, and what must be a couple dozen sets of tires at this point, I’ve never run TPMS sensors in my track wheels. Other than the light on the dash, and a warning at startup, no issues. I was able to use all modes whenever I wanted to without any issues, including DSC fully off. *Full disclosure- I did go back to staggered after installing coilovers. I liked the balance a bit better. |
09-20-2022, 05:22 AM | #3 | |
Rep 1,644
The idea that the car acts a little wonky on the square setup (DSC) at all makes me a little nervous as I would be swapping these wheels on right at the track before the first session. What kind of staggered setup do you run? |
09-20-2022, 08:56 PM | #4 | |
Rep 427
09-21-2022, 06:38 AM | #5 | ||
Rep 1,644
08-05-2023, 06:55 AM | #6 | |
Rep 252
Curious where you landed on the square setup and how it works for you? I'm likely going this direction on my M2c for next season. |
08-14-2023, 06:27 AM | #7 |
Rep 1,644
Was only able to get out to the track once on the square setup so far but it felt great. Can confirm TPMS will force it into comfort mode with low psi as stated on here is various threads. What hasn’t been reported is that at what psi it does this actually varies based on external temp. Makes sense if you think about it. Car expects lower psi when it’s cold out. Morning runs at upper 60s I could run at 27-28 psi no prob. Afternoon in 80s it would throw TPMS fault at same psi.
