11-25-2018, 12:56 PM | #155 | ||
Rep 798
US car? Date of production? Can you take a video of this? I've still yet to see any videos of the US M2 with this feature enabled to confirm its working as expected. |
11-25-2018, 07:45 PM | #156 | |
Rep 1,466
Read the thread I linked a few posts back, it has all the details of what I did, which changes I made etc.
2018 ///M2 LCI, LBB, 6MT...
11-28-2018, 02:16 PM | #157 | ||
Plenipotentiary
2614
Rep 3,046
Unfortunately there are members who are more interested in creating a false narrative rather than accepting of the truth. 1. No NAR (US/CAN) Bi-Xenon have ever been equipped from the factory with the proper projectors. Anyone who had "coded them" and claims the work correctly is lying. There is a very simple method to verify this and is 100% infallible. 2. Again as you've shown (pasted below) none of the settings for the light emitting elements for VLD or GFHB are present in F87LCI caf files due to their single projector design (the items you marked in red). RoW cars with the full AFS projectors have an additional self contained led matrix driver. Looking at the 72 differences between US and EU FEL ECU Coding, I can see a number of similar line items with the F15. The coding data itself is of course different, but the line items are similar. Below is a list of the first items with lots of hex data, rather than single bytes. In Black are items only found in the F87, in [COLOR="Red"]Red, items only found in F15[/COLOR], and in [COLOR="seagreen"]Green, items found in both[/COLOR]: [COLOR="red"]Stadt_V_IdxSo far a lot of overlap, and nothing additional in F87... And the single byte list with the same colour code: [COLOR="SeaGreen"]HlPrjLabel_HlType[/COLOR]So here there are many more differences, and a lot more differences in F15 than F87. There are a few other differences in F87that aren't reported in the F15 document, but these appear to be power related things, with mentions of current binning, duty cycle etc. Finally, two other differences that may or may not be relevant: LM_ID_LT04The other relevant point to note is that the F15 document says to remove 8S4 and 5AP from the FA, and VO Code BDC_BODY (equivalent to FEM_BODY in F87) and KAFAS (equivalent to FAFAS2 in F87) or KFA depending on which is present, and both FLE. As I stated earlier in this thread, removing 8S4 and 5AP from my FA results in no changes at all in KAFAS2 or FLE, and only differences in FEM_BODY. 2 of those differences appear when removing 8S4 and I can confirm enable VLD, and 1 difference appears when removing 5AP and is therefore related to NGHB. This would indicate to me, that assuming no hardware limitations, changing the 1 item in FEM_BODY and the 34 items in FLE might enable NGHB in the US LCI F87 with adaptive LED and KAFAS2. I guess it might be necessary to also set something in KAFAS2, but I'm unclear why this isn't being indicated by the EU VO coding. Thoughts Almaretto? Care to be the guinea pig ZPrime |
Almaretto2374.00 |
11-28-2018, 11:45 PM | #158 | |
Rep 8,364
11-29-2018, 05:58 AM | #159 | ||
Plenipotentiary
2614
Rep 3,046
11-29-2018, 10:15 AM | #160 |
Rep 101
hello from spain...if somebody is interested on a complet and new pair of bmw f22 adaptive led headlights LHD please pm...i have a complet pair new for sale...thanks
11-30-2018, 12:18 AM | #162 |
Rep 8,364
11-30-2018, 06:56 AM | #163 |
Rep 780
Do you know if these were US or Canadian cars?
12-01-2018, 08:46 PM | #164 | |
Plenipotentiary
2614
Rep 3,046
It's a very ambiguous notation for general production installation (doesn't show when market filters applied). Will know a little more after Monday update. |
Almaretto2374.00 |
12-06-2018, 08:23 AM | #165 |
Rep 959
Ok guys my M2C is coming next week, as you can tell I'm from Saudi. I want to understand if VLD is a specific option on the car or is included part of the options below
S552A Adaptive LED headlight S5ACA High-beam assistant S5ASA Driving Assistant
12-06-2018, 11:47 PM | #166 |
Rep 55
Not to continue and beat this horse to death, but one final post until further notice...
Those of you who claim that coding GFHB on US spec cars has *not* fully worked, check this video out. Things I want to point out: 1. I'm pretty sure this was shot in Europe because of the road signs. It's hard to see, but if you go frame by frame you can see that the car is passing signs that are right-side-up white triangles with a red outline. We do not have this sign in the US, and it is a very common one in Europe. 2. He says in the video title that they are adaptive LED. 3. The feature that several of you have said will *not* work properly on US spec cars is tunneling while following a car, creating a dazzle hazard for the car in front. If you go to ~1:35 in the video you will see them approach a leading car. The headlights continue to stay on full high-beam mode until the leading car is MUCH closer, not until the ~1:43 mark do they form a tunnel. This is similar to what I've seen my car do. It does eventually make a tunnel, but only once the leading car is a lot closer (as in the video) and only if light conditions on the road continue to be just right. Even a brightly lit passing road sign in this situation will kick it back to low-only mode. These things lead me to a couple questions/statements: 1. Assuming this is an EU-spec car driving in Europe, I think it's safe to assume we are seeing full EU-spec GFHB in action. 2. There are only 2 things I see the headlight hardware physically doing in this video. Those things are 1) cycling on/off the "high" set of LEDs and 2) changing the focus (aim) of each projector. I don't see it physically doing anything I have not seen my US-spec lights do. 3. I do not see anything here that appears to be individual LEDs on the projector switching on/off, dimming, being shaded, shuttered, etc. to shape the beam. Even if this were happening, I think the LEDs are too close together, and the projector is too diffused for it to make much of a difference. I think some of you may be imagining that this works somewhat like the Audi "Matrix" LED headlights, but if you look at the shape of those, they have 5 very distinct projectors on each side of the car. I just don't think the BMW adaptive lights are that sophisticated. The emitters are very close together and behind a strong diffusion plate. I tried to peer into the projector using a welding glass to see what the individual emitters are doing, and I can't even make them out. With such heavy diffusion, there is no way these lights can project a sharp enough beam from an individual LED emitter to shape the over-all headlight. 4. Those of you who claim to have had this functionality working on previously owned cars, were all of those Xenon headlights? I think it is possible that the adaptive LEDs just function completely differently than the adaptive Xenons did, and so we just aren't sure what we are seeing yet. And so my final point... Everything I see the above, assumed EU-spec car doing in this video is stuff that my car does with a few coding tweaks. Yes, as others have discovered, it does appear to wait too long to make a tunnel for a leading car. But so does the EU-spec car, and it eventually will do it. Granted, I have not experimented with mine in dense fog like this driver is doing, but if I ever see some I will definitely do so and report back. And if anyone can find a video of another EU-spec car with adaptive LEDs doing something in addition to what we see in this video please post it! |
12-07-2018, 11:05 AM | #167 | |
Plenipotentiary
2614
Rep 3,046
Worse yet, what you claim isn't happening is, and what is happening isn't. |
12-07-2018, 11:06 AM | #168 |
Plenipotentiary
2614
Rep 3,046
AFS+ (VLD)is included in your market with 552.
12-07-2018, 11:10 AM | #169 | |
Rep 959
12-07-2018, 11:11 AM | #170 | |
Rep 55
But again, subjectively speaking my car does everything that this car in the video is doing. My lights move the same way, and they tunnel the same way when light conditions are right. I’m confused by your last comment. What is happening that I claim isn’t? What isn’t happening that I claim is? |
12-07-2018, 12:26 PM | #171 | ||
Rep 798
12-07-2018, 12:54 PM | #172 |
Rep 55
12-07-2018, 01:05 PM | #173 | ||
Plenipotentiary
2614
Rep 3,046
The (UN AFS+) F87 only has a single combined projector on each side which have to handle 15 different lighting modes each (sometimes combined, sometimes independently) so they are of a different type of headlamp category to begin with. The motion is actually limited because they cannot mechanically bend in certain modes and must rely on digital matrix beam shaping (not to be confused with Audi Branding reference Matrix). |
12-07-2018, 01:51 PM | #174 |
Rep 55
Are you saying you think the US projectors are not capable of moving the way the ones in that video are? Because that is just not true with my lights. They move just as much, and with the same range of motion, as the projectors in that video. And anything that moves mechanically like that is going to be stepper motor-driven, US lights included.
Okay, this conversation is just going around in circles. How do we get someone in Europe to record a video of their M2 with GFBH in action? I will try to get a video of mine but it may not happen for a while, because I’d have to drive at least an hour or more outside the city to find a road as dark as the ones in that vid. |
12-07-2018, 02:33 PM | #175 | |
Plenipotentiary
2614
Rep 3,046
Do you know the difference between these beam shapes, the luminous intensity of each, and their modes of operation? Class C Class C1 Class C2 Class E Class E1 Class E2 Class E3 Class E-2 Class E-4 Class W Class W1 Class W2 Class T Class T_x (in combination with the above, when permitted and on which headlamp forward optic types different limitations apply?) Class V1 Class V2 Class V3 Class V4 Class V5 How well does Tourist Mode Class R work on your car? |
12-07-2018, 02:53 PM | #176 |
Rep 55
We’re looking at this in different ways. You are looking at behind the scenes, coding and saying that things cannot be the same.
I’m subjectively looking at what the headlights are actually doing and saying that my lights do those things. I don’t have a coding explanation for how/why/why not/how that is different/etc. I design lighting for a living so I look at beams of light on a daily basis and I can’t see anything in any video of GFHB that I have not seen my own car do. ¯\_(ツ)_/¯ Sorry I don’t have a better explanation. |
