09-02-2023, 02:11 PM | #463 |
Rep 587
Has anyone considered canards for increased airflow out the wheel well to aid in cooling? My upcoming track day on Tuesday is expected to be 90 degrees or so - warmer than previous ambient temps with my old oil cooler. Canards might be my next step...
09-05-2023, 08:04 AM | #464 |
Rep 3,703
Good luck today. Interested in your results!
09-05-2023, 07:35 PM | #465 |
Rep 4,174
09-05-2023, 07:57 PM | #466 |
Rep 7,473
You'll need CFD to design canards that actually do what you want to do, otherwise it could be useless or even hurt performance.
Extraction from the wheel well really isn't the main job of the camard, that's what cut fenders do. Like what Porsche did on their gt3rs:
09-06-2023, 08:37 AM | #467 | |
Rep 587
Here is a log of one session with the new do88 oil cooler. Seems to have had a 10-20 degree benefit to the oil temp. I haven't looked at it in detail yet, so you may beat me to conclusions... https://www.bootmod3.net/log?id=64f7...729b2b8f4ab396 |
09-06-2023, 09:12 AM | #468 | |
Rep 3,703
Compared to my recent log with similar ambient, my IATs average 20F lower and I’m probably 70whp more and my Vmax was 10mph higher—highlighting the limits of the CSF IC. https://bootmod3.net/log?id=64e7c187c090c66632f032b3 Altho, your coolant temps were much more in check and not as directly trending with oil as mine were. And, your stock main & aux radiators while I’m do88. Still makes me think airflow to the radiator is a big factor for coolant temps. Power is definitely getting pulled for you with the high IATs, so we may be as far as 80-90whp apart. That’s also helping reduce your engine cooling req. Will be very interested in seeing what happens with all your temps once you change IC’s. Last edited by ZM2; 09-06-2023 at 11:00 AM.. |
09-06-2023, 09:14 AM | #469 | |
Rep 7,473
Fender vents won't work at all on this car unless you vent the fenderiner, otherwise it'll just vent engine bay air via the engine bay fender gap.
09-06-2023, 09:23 AM | #470 | |
Rep 4,174
Mods: Yes.
09-06-2023, 09:37 AM | #471 |
Rep 7,473
Haha, i know I just wanted to tag on to it since you commented on the same thing.
09-06-2023, 11:17 AM | #472 | |
Rep 4,174
For someone like ZM2 and his big turbo set up, that will take a little more thought. I still think there is a benefit on his setup to delete the heat exchanger. I don't think it's a coolant airflow issue, as the auxiliary cooler is unimpeded - while the DCT cooler and intercooler blocking the front don't help. Yeah, he's running about 100whp more - and his oil temps have come in line, but that exchanger is likely adding thermal capacity to the oil cooler. The easiest thing to do (less custom work) would be a new intercooler. Unless you HATE VRSF, you can wait on more reviews for the MAD Race intercooler. They both are shorter than the EVO3 by around 3-4 inches, so much so that they are actually behind the bumper cover while the EVO3 sits above it.
Mods: Yes.
09-06-2023, 12:29 PM | #474 | |
Rep 7,473
It's coolant temps that is the unsolvable issue because the radiator lacks surface area.
09-06-2023, 01:14 PM | #475 | |
Rep 4,174
Either way, a new intercooler is going to bring down his IATs - so that's pretty nifty.
Mods: Yes.
09-06-2023, 01:34 PM | #476 | |
Rep 7,473
So none of those factors would do anything for cooling capacity, they would just buy you a few more laps.
09-06-2023, 01:43 PM | #477 |
Rep 587
I had taken a brief/quick look at the oil to coolant temp correlation and didn't come to any quick conclusions. Initially, it does look like the coolant keeps the oil temps up, but I want to look more closely. It kinda seems like it might be a give and take - they keep each other in check and close in number. Anyone have insight before I dig into it?
09-06-2023, 01:57 PM | #478 | |
Rep 3,703
That could tell us the impact of the radiators/coolers and exchanger, good or bad. Edit: Here are the only other two engine temp related channels I found. No idea if they work or would provide us with diff temps in the coolant loop. Last edited by ZM2; 09-06-2023 at 02:07 PM.. |
09-06-2023, 02:12 PM | #479 | |
Rep 7,473
09-06-2023, 02:42 PM | #480 | ||
Rep 4,174
The issue is while the coolant starts this low, it's picking up heat from the oil which starts opening it's thermostat later. So OG's Shark's issue was that his coolant was starting to open up at 195 once the car was already heated up and oil was starting to move through the coolers at 220?F, effectively cutting his headroom by a considerable margin. Quote:
Mods: Yes.
09-06-2023, 08:21 PM | #481 |
Rep 587
Data incorporated onto video:
09-06-2023, 08:36 PM | #482 | |
Rep 7,473
So pretty much in the simplest possible representation peak temps (thermal head room/thermal equilibrium) = max heat output - max thermal dissipation. No where is starting temperature part of this equation, starting temperature only dictates how long it takes to get to thermal equilibrium because the specific heat capacity of the cooling fluid can absorb said energy before it changes temps. Oil and coolant heat interchange also doesn't matter because that will have its own equilibrium that again is dictated by thermal dissipation surface area. Even if you start with temps in absolute zero, it will still not be able to change your head room you'll get more laps but eventually it will reach the limits of your thermal dissipation surface area. An analogy is a bath tub filling with water. If water flows in faster than it drains then it will over flow. Water being the heat the drain is the heat exchanger surface area. If you start at a lower later level (lower coolant temps) then you get a bit longer before the tub over flows. But regardless of what water level you stay at if the draining isn't as fast as the filling you'll over flow. That's an indisputable fact there is no yes or no or maybe, that's just how physics works. Ambient temperatures also play a part, but it's tied to thermal dissipation surface area. It's also something we largely can't manipulate so it's not important to consider. The only important thing that matters is if you have enough thermal dissipation surface area to cool your heat generation.
09-07-2023, 04:27 AM | #483 | |
Rep 587
F87source7313.50 |
09-07-2023, 09:45 PM | #484 |
Rep 581
Came across these guys and thought I’d share.
https://headershield.com/ You ship parts to them which means downtime but the results seem enticing. Having them insulate the turbo, manifold, and downpipe could be one more puzzle piece to the solution. Hell they even do intakes and charge piping. Last edited by ThreeStripes; 09-07-2023 at 10:00 PM.. |
