10-28-2020, 07:48 PM | #1 |
Monkey
119
Rep 241
M5 rotors on M2C
I keep hearing people say that the M2C's front brakes are the same as M5. Does that mean that I can use M5 rotors on the M2C? I've already seen some pads like Ferodo DS2500 that say they're cross compatible but wondering if the rotors are as well.
10-29-2020, 12:12 PM | #2 | |
Rep 433
I believe 390mm vs 400mm The pads, however, should be cross compatible EDIT - I was wrong about the size of the M5 rotors. See DavidStr's post below regarding the rotors Last edited by 2020M2Competition; 10-30-2020 at 06:47 PM.. Reason: I was mistaken |
10-29-2020, 02:55 PM | #3 |
32
Rep 166
discs have the same diameter, at 400mm and 36mm thick
However center bore between the 2 are different. You can use M5 rotors, but the CB needs to be machined Not sure about the offset though |
2020M2Competition429.00 |
10-29-2020, 05:23 PM | #4 | |
Monkey
119
Rep 241
Hopefully by the time I need to replace rotors FCPEuro would stock M2C ones... |
10-30-2020, 06:41 PM | #5 |
Rep 433
10-30-2020, 11:24 PM | #6 | ||
Rep 916
I sent them an email about m2c Ferodo ds2500 ..... Before it was just listed under the m5 application for the front. Now when you search: « m2 competition » on fcp euro search box, you can find front and rear Ferodo ds2500 and ds1.11 track pads. Very happy about that |
