05-20-2018, 01:17 PM | #155 | |
Rep 7,594
Drives: '19 M2C
This would explain how the US car got heavier.
www.ReTuneTheDeTune.com
05-20-2018, 01:32 PM | #156 |
Rep 1,086
Correct, but last I saw the number was closer to 25%. As with the brakes, we won’t know until BMW speaks.
05-20-2018, 01:33 PM | #157 | ||
Rep 3,660
Drives: 981 Cayman GTS
M3 Adjuster7909.00 |
05-20-2018, 01:37 PM | #158 |
Rep 1,086
The specs for DCT and 6MT equipped models are listed separately, as they are for CAFE testing too.
Another consideration is the Executive Package, which certainly had a take rate of more than 50 percent for 2018. Now some of those parts are included in the “base” M2C. And, BTW, the sunroof was not available until the 2018 LCI. |
05-20-2018, 02:02 PM | #159 |
Rep 7,594
Drives: '19 M2C
Yes I know the MT/DCT numbers are separate. I meant that it makes sense the sunroof could be in the US numbers.
M-Pilot4861.50 |
05-20-2018, 02:16 PM | #160 | |
Rep 3,660
05-20-2018, 02:25 PM | #161 |
#savethemanuals
2448
Rep 1,981
BMWusa.com has the 6MT weighing more than the DCT for 2018 specs? They obviously made a mistake, but 2018 specs are seen below.
Exterior Dimensions LENGTH / WIDTH / HEIGHT (in) 176.2 / 73.0 / 55.5 CURB WEIGHT – MANUAL TRANSMISSION (lbs) 3505 CURB WEIGHT – AUTOMATIC TRANSMISSION (lbs) 3450 WEIGHT DISTRIBUTION, FRONT/REAR – MANUAL TRANSMISSION (%) 51.9 / 48.1 WEIGHT DISTRIBUTION, FRONT/REAR – AUTOMATIC TRANSMISSION (%) 51.4 / 48.6 GROUND CLEARANCE (in) 4.8 https://www.bmwusa.com/vehicles/m-mo...fications.html Last edited by seis-speed; 05-20-2018 at 02:32 PM.. |
05-20-2018, 02:28 PM | #162 | |
Rep 1,608
Manual transmission heavier than DCT????
Boostm3
05-20-2018, 02:30 PM | #163 | |
Rep 1,086
05-20-2018, 02:32 PM | #164 | |
this is the way
18391
Rep 8,576
Been that way for a while, they crossed the MT and DCT numbers. They are always messing things up, like most recently with the Canadian info stating the 437M wheels showed they had one size wider tires than the 788M wheels, literally a copy paste from M3/4 info. They should be ashamed of the amount of errors they consistently churn out. And where the hell is management in this? They should correct existing mistakes and prevent future ones. Pathetic really. |
05-20-2018, 02:32 PM | #165 | |
Rep 3,660
05-20-2018, 02:36 PM | #166 | |
Rep 3,660
05-20-2018, 02:40 PM | #167 |
Rep 1,086
Every manufacturer is that way - and has been for decades. If you guys keep focusing on the minutiae that's touched by hundreds or thousands of people along the way, you're going to stroke out before you get to start unbolting the road-hugging weight from your M2Cs.
M3 Adjuster7909.00 chris7197365.00 |
05-20-2018, 03:05 PM | #168 |
this is the way
18391
Rep 8,576
There's no excuse for a manufacturer to publish incorrect information on their product, it's literally the primary source for everyone in the world to quote as factual information. Mistakes happen, but where are the corrections? Most go unaddressed. The only one that comes to mind recently where BMW actually addressed it was the misprint (misrepresentation) of the N55B30T0 as having a closed deck. BMW ultimately removed the closed deck reference from their websites and elsewhere. I personally believe this was largely in part, because of multiple threads on the subject by members like us questioning if this was actually true which got their attention.
05-20-2018, 03:08 PM | #169 |
Rep 446
Drives: 2017 M2 6MT, 2022 X7 M50i
Is the curb weight measure without fluids? I found another thread which measured OG M2 DCT on the scales with fluids, 1/2 tank of gas and a 160lb driver: 3609lb
Source: http://f87.bimmerpost.com/forums/sho....php?t=1344984 That's 3609 - 160 = 3449, which is still 56lbs lighter than what BMW claimed. Of course, 3609 was measured after installing KW CS, Apex wheels and BBK — it could have added weight for all we know. I guess the bottom line is that we need to have OG M2 and M2C on the scales to find out the true difference in weight — I wouldn't rely on tech spec sheets. |
05-20-2018, 03:18 PM | #170 | |
Rep 552
Most of what you wrote is true, but I am quite certain you are slightly ignorant to the track performance capabilities of an e46 M3. The M2C will have gobs more low end torque for sure, but on the track that does not make that much of a difference. Horsepower is only up about 40 from where I am sitting, maybe less, and if it is 400 lbs heavier, then it is negligible. But remember, 400 lbs more for braking and cornering isn't. I smoke plenty of new and faster cars in my e46 M3 and sub frame is just fine. For the record, this is not my first M, and not my first e46 M3. I've been around for a while and have had newer ones. I went back to this model because it was the best one BMW ever made IMHO. Was hoping the M2C would change that, but am disappointed IF the weight went up that much. But I will hold judgment until I see what a 6mt, no sunroof, low optioned model can come in at. |
05-20-2018, 03:24 PM | #171 | |
Rep 3,660
05-20-2018, 03:34 PM | #172 | |
Rep 7
Remonster824.00 |
05-20-2018, 03:43 PM | #173 | |
Rep 552
Ja das stimmt ;-) Like I said, I still haven't given up on the M2C. The weight might not be as bad as this thread suggests. If it was, then I will seriously consider a slightly used N55 M2, and use the $15k savings for all the M Performance parts and bring it down to ~3200 lbs. |
05-20-2018, 03:53 PM | #174 | ||
Rep 207
What really grinds my gear and serves as a barometer to BMW's lack of emphasis on weight saving is the non-use of aluminum on the hood, roof and trunk. There are many cars at lower price points - some of which are sold at lower volume than the 2-series - use aluminum on such parts. Some even extend its use to doors. Therefore I can't subscribe to the argument that exercising common weight saving methods would have made the M2 prohibitively more expensive. It's more the case of BWM didn't give enough of a F%~# about light weight from the start, and then try to milk the crap out of owners who want to save the weight that shouldn't have been there to begin with. Non-structural aluminum parts weigh on par with CF, which are typically half of corresponding steel parts. Case in points: -M2 steel hood weighs 39.x lbs; MPerf CF version saves ~20 lbs -Civic steel hood weighs 35.x lbs; aluminum version in TypeR is 17.x lbs -S2000 OEM aluminum weighs the same as its Mugen CF hood, and lighter than other lesser quality aftermarket CF hoods. BMW engineers have done a marvelous feat to make the current M2 dances the way it does even at its somewhat porky weight. I would have loved to experienced how much more fun it would have been if it were xx lbs lighter rather than xx faster while 150 lbs heavier. See, I am knocking my current M2 and the M2C on weight so I am not "hating" the M2C out of envy. I am mildly frustrated with BMW bean counters in general.
Gone but not forgotten:
'14 Corvette Stingray (2014-2017) '05 Boxster S (2005 - 2014) '00 S2000 (2000-2005) |
05-20-2018, 04:02 PM | #175 |
Rep 7
Please BMW, if you're listening. Use all the steel you'd like on every other vehicle you manufacture. But when it comes to the M2, make it (or a version of it) as light as can be. In the words of your brilliant M2 designer Mr. Hussein Al-Attar, "The BMW M2 has always been the closest thing to what our hardcore fans consider a real BMW".
05-20-2018, 05:13 PM | #176 | |
Rep 3,622
