M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > BMW n55 new pure turbos (pure 500 and pure 750)
      06-28-2024, 08:25 AM   #485
Ice_ken
Ice_ken's Avatar
Belgium
119
and what point do you upgrade the LPFP on M2 N55?
      06-28-2024, 07:51 PM   #486
johnung
johnung's Avatar
Drives: 2015 BMW 335i x-Drive Auto
When to upgrade the stock LPFP on a N55 EWG is usually related to the fuel mix and turbo fuel demands. The stock LPFP is pretty robust. ZM2 has been tracking his TTE460 turbo using E50 and approaching 500whp with a Dorch Stage1 HPFP and the stock LPFP. The same should go for the Pure500.
As soon as you want to use higher ethanol mixes from about E60 to full E85 (and get full performance out of them) you’ll need an LPFP upgrade. Ideally a Precision Raceworks Stage2.5v2 (Walbro 535). It’s rated at 675whp for pump gas and 600whp for E85.
Note: It’s not worth going for the Walbro 450. Capacity is much lower (2.2 vs 3.5 LPM) and the price difference is only $75.
https://precisionraceworks.com/produ...39318067445953
Tip: Order the Walbro 535 and have PR custom wire it for straight through wiring. And connect it to a Stage2 EKP from ET3 Design. It eliminates the BMW problems of overheating, scorching and melting.
https://www.et3design.com/stage%202.html
      06-29-2024, 10:35 AM   #487
VGSON
OG
VGSON's Avatar
Drives: F87 OGM2
my lpfp couldn’t keep up around e55 and around 550hp..went with stage 3 hobbs switch after talking with dorche.
      06-29-2024, 11:57 PM   #488
3t3p
New Zealand
513
Is upgraded tmap going to be needed for say pure 500 and hpfp (DS15) and 98 RON fuel only no ethanol?
Custom or OTS tunes.
Thanks
      06-30-2024, 12:12 AM   #489
Mr_M//
125
Drives: 2017 M2/M3
Thanks
I don’t think so, unless you’re planning to run over 21psi
Speedtech top mount G35|Motive| Reflex plus | Wagner EVO 3 | BMP manifold | Dorch Stage 2 HPFP | PI | Precision Racework stage 4V2 LPFP | BendCalibration Flex Fuel Kit |turner catch can| HRE 20” \Apex 18” wheels| ECUTEK tuned by bendCalibration|ohlins suspension
IG Modded_M2
3t3p512.50
      06-30-2024, 09:35 AM   #490
wheela
wheela's Avatar
520
Drives: 2015 BMW X1 35i M-sport
I agree with this. I don't think you'd want to run over 21 psi with P500 on 93oct/98ron only, and if your boost is spiking above that level, it will still be obvious in the logs as the top of the peak will get clipped off. Seeing the clip should be enough for your tuner to identify and tune out the boost spiking without having to know the specific value to boost spiked to.
3t3p512.50
      06-30-2024, 11:01 AM   #491
AmuroRay
AmuroRay's Avatar
2945
Drives: M235i
It's good insurance to have, boost can change with ambient temps and altitude.
Mods: Yes.
Originally Posted by umizoomi View Post
As long 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
      06-30-2024, 12:54 PM   #492
wheela
wheela's Avatar
520
True, it certainly doesn't hurt
      06-30-2024, 08:20 PM   #493
mledfo2
mledfo2's Avatar
20
Drives: Jet Black E92 M3 mt
For those interested regarding the Dorsch stage 1 HPFP, I'm doing 537whp on my current set up with stock LPFP and 3.5 bar tmap on E50 😁 it flows more than I expected!
      06-30-2024, 09:05 PM   #494
AmuroRay
AmuroRay's Avatar
2945
Drives: M235i
Turbo?
Mods: Yes.
      06-30-2024, 09:08 PM   #495
mledfo2
mledfo2's Avatar
20
Turbo?
I'm running the Bimmerhaus Performance stage 2, it's an amazing turbo, love it!
      07-01-2024, 09:02 AM   #496
CanadianM2
CanadianM2's Avatar
118
Drives: OG M2
Never heard this brand before but I’m not a bmw guy. Checked their website and it seems they don’t ship to Canada :/
      07-01-2024, 10:25 AM   #497
Ice_ken
Ice_ken's Avatar
Belgium
119
Link to high res
Numbers are WHP/WNM torque. Dynojet dyno.
Blue: FBO OTS BM3 Stage 2 (another M2, not mine)
Red: Mine; FBO, Pure P500, Dorch DS15. OTS BM3 Stage 2 Full spec below
Green: Mine; FBO, Pure P500, Dorch DS15. HC Performance custom map.
2017 F87 M2 N55 manual:
Engine upgrades:
-Pure500 turbo
-Turbosmart DV11 divertervalve
-Dorch DS15 HPFP
-FTP inlet pipe
-DO88 intercooler, boost and charge pipe.
-N20 sparkplugs
-N20 3.5Bar mapsensor
-Speed engineering airscoop
-DO88 bigger oilcooler
-Wagner sportcat
-Tune by HCP
Fuel: EU 98 Shell V-Power -> US 93.
Comment by tuner: could use a bigger intercooler. Wagner EVO 2 competition for example.
Overal happy with the graph, looks like it makes tons of torque and power. Now just need to pick the car up.
Appreciate 8
AmuroRay2944.50
Shaq9319.50
Sparky68798.00
3t3p512.50
VGSON357.00
TUDMG40.50
M2guru525.00
      07-01-2024, 10:34 AM   #498
AmuroRay
AmuroRay's Avatar
2945
Drives: M235i
Link to high res
Engine upgrades:
-Pure500 turbo
-Dorch DS15 HPFP
-FTP inlet pipe
-N20 sparkplugs
-Wagner sportcat
-Tune by HCP
Finally!! 25whp on the same tune - and on the custom tune over 430whp at 6500RPPM, impressive stuff.
PS to HP conversion (subtract 2.2% for SAE):
400whp stock turbo
425whp P500
448whp P500 HPFP custom tune
FYI bad advice on the intercooler - Evo2 is actually a lighter/same size intercooler compared to the Do88 (and will perform worse), you would want something bigger like the MAD/VRSF 6" race core.
Mods: Yes.
      07-01-2024, 10:39 AM   #499
mledfo2
mledfo2's Avatar
20
I just texted Dan, the owner and apparently they do ship worldwide! He said he's got a customer in Canada running the same turbo
      07-01-2024, 10:54 AM   #500
AmuroRay
AmuroRay's Avatar
2945
Drives: M235i
Can you post your dyno? Was it on Pump?
Mods: Yes.
      07-01-2024, 11:19 AM   #501
mledfo2
mledfo2's Avatar
20
Absolutely! This was on E50. I'm hoping to start a new thread on this turbo soon also.
AmuroRay2944.50
      07-01-2024, 11:35 AM   #502
BimmerHausPerformance
BimmerHausPerformance's Avatar
525
Drives: F10 S55, E93 M3, E89 N54
2008 BMW e93 M3  [0.00]
2012 BMW Z4  [0.00]
2011 BMW 535i  [10.00]
If you have any questions on his turbo just DM me, I can help. We are currently building a bigger one that will also be hybrid. My personal goal is to break the 600 WHP barrier on a stock manifold with a simple hybrid turbo. I feel like around 600 whp is the reasonable limit of these stock motors and transmissions before you need major upgrades. That is the reason for that goal.
2011 F10 S55 6MT
Website Instagram YouTube
mledfo220.00
      07-01-2024, 11:43 AM   #503
CanadianM2
CanadianM2's Avatar
118
Drives: OG M2
When I enter my address and also my shops address it says they do not offer shipping to this location I’m in Nova Scotia
      07-01-2024, 11:44 AM   #504
johnung
johnung's Avatar
Link to high res
Engine upgrades:
-Pure500 turbo
-Dorch DS15 HPFP
-FTP inlet pipe
-N20 sparkplugs
-Wagner sportcat
-Tune by HCP
Hey congratulations! 455whp using 93 pump gas is fantastic! I marked up your dyno graph (please see attachment) to illustrate the two things that jump out at me. FYI- I updated photo.
First, with the Pure500, you have the same stock turbo torque early on by 2500 rpm. So it’s equally responsive, plus then torque goes much higher.
Secondly, you have a big power increase but more importantly it stays high towards redline instead of dying off like the stock turbo.
Enjoy driving it!
Shaq9319.50
TUDMG40.50
      07-01-2024, 11:48 AM   #505
CanadianM2
CanadianM2's Avatar
118
Drives: OG M2
The P500 compared to the stock turbo graph is exactly what I’ve been waiting for. Looks about a +/- 50whp gain with custom tune and HPFP on 93. Would be a little less on 91 which I would think could leave my car around the 430whp range which would be a nice bump in power for a inexpensive turbo
      07-01-2024, 12:17 PM   #506
AmuroRay
AmuroRay's Avatar
2945
Drives: M235i
Enjoy driving it!
I have Winpep (the dynojet software) the metric horsepower and STD correction produce the "biggest numbers"
The conventional imperial horsepower and SAE produce "lower numbers" I included the conversion factor in my post - its about 5-8hp differences, and can be as much as 10-15whp+ depending on correction factor. I'm only noting this so when people don't get the "huge" numbers they see others get, they know why. Either way, there is about a 25whp difference at peak, and about 40whp difference at 6500RPM.
As for this dyno, the only reservations I have are what were the FBO stock turbo car's mods. Did it have an inlet?
Mods: Yes.
3t3p512.50
