07-12-2017, 09:39 PM | #815 | ||
Rep 1,247
I have bimmerlink and my issue is its all in german. Though you can turn on/off ASD and open/close exhaust valves. I would stay away from it for now. I think the app you would want is OBD fusion. You might also want to check out track addict. |
07-12-2017, 09:48 PM | #816 | |||
Rep 943
Drives: 2012 328i Modern Line
:wave:
07-12-2017, 09:52 PM | #817 |
Rep 1,367
07-12-2017, 10:19 PM | #818 |
Rep 1,011
you can email the developer and he will provide you the German matching values for whatever you want to monitor. he is also working on a full translation of all values. this is for the bimmerlink app.
07-13-2017, 02:10 AM | #819 | ||
Rep 1,247
http://bimmerlink.com |
07-14-2017, 12:13 PM | #820 | |
Rep 1
Sorry for the newb question. Could someone clarify what Werte means? Should it already be there? Do I create a new custom value?
07-14-2017, 01:26 PM | #821 |
BMW DRIVER ///M
106
Rep 317
Wert is the hex number setting for the specific setting you are changing
By the way app is broken on coding NBTEvo in the current BMW ilevel.
Current
Waiting 2022 G80 M3 AWD Comp Brooklyn Grey 2004 E46 M3 White END OF LIFE = 2017 M2 07/16 Build, 2014 M5 05/14 Build, 2008 M3 ESS Supercharged, BMW 2003 M3, BMW 2001 325ci |
07-16-2017, 10:51 AM | #823 |
Rep 64
In coding 'all doors unlock at ignition shutoff' I found only driver's door will unlock. I'm using
> FEM_01 > 3040 CIMaster > CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK = aktiv (0x01) Anyone tried this and able to have both doors unlock - what am I doing wrong? |
07-16-2017, 11:04 AM | #824 |
Rep 236
Drives: 2017 M2 6MT
My notes say all doors will unlock at ignition shutoff if auto lock is active. This coding worked for MY17 M2, same parameters.
07-16-2017, 11:17 AM | #825 |
Rep 64
Thats what I understood as well. I'll try resetting to default and re-code. Auto lock on my (MY17) works fine (never had to code that since it was active by default).
07-16-2017, 01:08 PM | #826 |
Rep 943
I believe the drivers only door being unlocked is just a setting in I-Drive.
:wave:
07-18-2017, 02:56 PM | #828 |
Rep 105
I've already asked 3 times with no response but I guess I'll ask again...
Does anyone know if you can change the car image on the home page when you upgrade to iDrive 6? It shows a 5 series on my M2 when upgrading using Bimmercode. Any help please? |
07-18-2017, 03:29 PM | #829 |
Rep 1,367
Have you looked around in the modules? I believe I saw a way to change the animations and logos on the iDrive module...
07-18-2017, 03:36 PM | #830 |
Rep 31
On the Mx35/40's the ASD was disabled could be reinstated by disconnecting the box in the boot, comms box i think its called. Its silver and looks a little like an external piece of networking equipment, ive not had time to look in the m2 but i assume its the same? On the m135i it was in the cubby hole on the left had side of the boot. Disconnect the multi cable connection and reconnect after a couple of minutes, turn ignition on and bingo ASD returned on the mlites
07-18-2017, 03:38 PM | #831 |
Rep 31
I have the same issue. Being OCD it bugs the hell out of me
07-18-2017, 11:52 PM | #833 |
Rep 3,077
@BimmerCode any insight on the specific of todays update? Was ACSM data was added?
Is comfort seat access and Euro MDM still on your list of improvements?
Follow me on IG
07-19-2017, 03:56 AM | #834 |
Rep 31
I had to revert to idrive 5 as 6 lite with the 5 series (or 3 series?) car graphic was just to much for my OCD to cope with and to be honest I don't really see much, if any benefit. If it has the 2 series car graphic I would've kept it though.
I have coded so far Video in motion - not tested yet Stop Start - remember last setting, so off remains off - Worth the cost of the app and adaptor on its own One touch close folding mirrors Door handle lights on reverse - not tested Head unit off on door opening EDIT: If I code ID6 lite and then change the 'my vehicle' setting to display detailed information the graphic of the car is no more, you just get details of MPG etc, result, I can live with that as actually ID6 with the multi live tiles is an improvement on ID5 for my usage. Last edited by wenklaw; 07-19-2017 at 06:58 AM.. |
07-19-2017, 01:58 PM | #836 | |
Rep 278
According to this post: http://f80.bimmerpost.com/forums/sho....php?t=1122306 All you have to do to get it back on via the app is to change the value for model range from F20/F21 (ASD off) to F87 (value for an M2). |
