08-13-2020, 07:40 PM | #1 |
Rep 278
I prepped the M2 today to paint the ugly hanging exhaust. A painting drop cloth (plastic backed paper), cardboard, plastic sheeting and a roll of masking tape covered everything that did not need to be painted. I put the car cover on for good measure while spraying.
30 minutes of sanding with a scotchbrite pad and 400 grit emery paper and the muffler was shining. Cleaned with alcohol and dried with a paper towel. Used a full can of high temp grill paint in multiple light coats. I used one that recommended no primer as it was self priming. Satin black. I would consider this an essential Black Sapphire modification.
FLYIN'
'20 BMW M2 Competition '20 BMW M550i '21 BMW X5 45e M Sport |
08-13-2020, 08:42 PM | #2 |
Rep 6,930
Drives: 2018 M2 AW DCT
Nice improvement in appearance.
08-13-2020, 10:15 PM | #4 |
Rep 278
And the final result. My sense of aesthetics is now in balance.
Second photo is with the flash so it's really a dark satin black.
FLYIN'
08-13-2020, 10:28 PM | #5 |
Rep 3,069
bobert858.50 MadBimmeRad7121.50 |
08-14-2020, 08:51 AM | #7 |
Rep 140
It looks much better.
Did you have to lie on your back to spray that? |
08-14-2020, 09:36 AM | #8 |
6634
Rep 4,145
Drives: '18 M2 6MT
Looks fantastic.
Please do me a favor and keep your mileage and when any of it starts to flake, and how much flakes. I'd love for you to prove to all the guys on this board wrong that say that BMW could NOT have done this effectively without a billion warranty claims because of major flaking. If it's prepped right, and the right materials used it'll last a LONG time, and it looks like you did it proper. If and when it does start to flake it'll be due to an area where you weren't able to Scotch-Brite perfectly because of access. |
08-14-2020, 10:22 AM | #9 | |
Rep 786
VisualEcho6633.50 |
08-14-2020, 10:40 AM | #10 | |
6634
Rep 4,145
Drives: '18 M2 6MT
In this case, it was scratches provided a Scotch-Brite pad, which is fantastic for this sort of thing. So basically his paint has something to hold onto whereas yours doesn't. I expect his paint to last at least 5 times as long as yours does for this simple fact. And don't listen to anyone that tells you the paint bites without prep, it doesn't, they are confusing it with clear, which bites, and needs no prep. This is why you don't sand a freshly painted car before clearing. But why you always sand a primered car before painting. |
FLYIN'202.50 No_curebimmer637.50 |
08-14-2020, 10:48 AM | #11 |
Rep 843
Not gonna lie, mine is still bone stock.
I actually got used to it, lol. Eventually I'll just swap out for a different exhaust, so it doesn't really bother me. |
GarageMadness665.50 wibmag0.00 |
08-14-2020, 12:29 PM | #12 | |
Rep 786
08-14-2020, 12:34 PM | #13 | |
Rep 786
VisualEcho6633.50 |
08-14-2020, 12:36 PM | #14 |
6634
Rep 4,145
Drives: '18 M2 6MT
Sorry, that came off wrong, wasn't preaching! Sometimes you can get away with a spray for quite a while, and if you're not keeping the car, no need for the extra work.
08-14-2020, 02:02 PM | #15 | |
Rep 278
The grill paint I selected is one that recommends not to be primed. It can withstand 1200 degrees but does not need to be heat cured. Some automotive high temperature paints need a primer and need to be baked or heated to cure. It will have a couple of days to fully set up before I drive the car so hopefully it will last a while before it flakes. Even then it would be the same process again to touch it up I'm hoping I don't need to for a while.
FLYIN'
VisualEcho6633.50 jason.seki54.00 |
08-14-2020, 06:27 PM | #17 |
Rep 278
Oh yeah. I think it was actually easier to spend the time sanding it by lying down. Ideally spraying it would have been easier if it was on a lift but that did not take long. Maybe 15-20 minutes with about 4 light coats of paint.
FLYIN'
08-14-2020, 07:37 PM | #18 | |
Rep 151
08-15-2020, 11:00 AM | #19 | |
Rep 292
VisualEcho6633.50 IcewaterPete2133.00 |
08-15-2020, 06:34 PM | #20 |
Rep 140
For those of you who have painted the muffler, are you concerned at all about the extra heat emittted? Any worry of damaging or melting nearby plastic or rubber pieces?
08-15-2020, 09:31 PM | #21 | |
Luxury at the redline :)
9105
Rep 7,563
Like for instance; the bracket for one my headlights was broken, so I mixed some Epoxy and fixed it back myself.. Fast Forward a year later, the headlight inner pivot adjustment went bad, so they had to replace the headlights but when they discovered I had glued back the tabs, they called me back and started bitching, saying BMW wouldn't pay to cover it, labor hours already accumulated - blah, blah, blah.. They basically didn't want replace the headlight, under the warranty, on the off chance that BMW might charge-back the payment, if they later discover my "modifications" i.e. some adhesive - to the original headlight tabs.. It was bunch of back and forth but I finally got them to cover it. So Caveat emptor - concealing the nut sack with paint might get you into warranty problems down the line.. |
08-16-2020, 10:52 AM | #22 | |
Rep 151
There should not be any extra heat emitted. It's just like painting an old grill. It's not any hotter or colder, it is just painted. |
