M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Help with data logs/ignition timing
      10-15-2021, 05:40 PM   #1
rocket.m2
Drives: 2018 BMW M2
I just recently looked back at my logs and noticed the ignition timing is pulling down to -6 under load at about 5,000 rpm on my Stage 1 BM3 OTS map and my Stage 2 BM3 E30 map. Is this normal or do my spark plugs need to be looked at? I also noticed slight engine knocks every once in a while...
Thanks in advance!
Stage 1 ACN91 Log from Aug. 27, 2021
https://www.bootmod3.net/log?id=6129...90c62f11a3f4ab
Stage 2 E30 Log from Oct. 14, 2021
https://www.bootmod3.net/log?id=6168...729b47bb678ec0
      10-17-2021, 10:01 AM   #2
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
How many miles are on the plugs and coils? It doesn’t hurt to replace the plugs at least
Go OEM at standard Gap. The PTF Recommendation seems to create a bunch of issues
      10-18-2021, 08:34 AM   #3
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
Thanks in advance!
Finally had a moment to look through these, and honestly - I can't tell much from a log of you cruising.
You'll actually have to log a gear pull - 3rd or 4th 2500RPM to 6500RPM(or Redline)
Mods: Yes.
      10-18-2021, 09:22 AM   #4
Wolfman’s Brother
Wolfman’s Brother's Avatar
378
Think of it like a dyno pull. They don’t hit record and then drive around. They hit record and go WOT seconds later. It consolidates the data to just what you’re trying to review.
Ideally you’ll get 2nd, 3rd, and 4th as you can see differences in timing etc in each gear. Just because 3rd looks good, doesn’t mean 4th gear is happy. Happy logging.
      10-18-2021, 10:17 AM   #5
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
For a dyno, it's mostly based on load and gearing . For this I need at least one pull to review, I'm not asking anyone to get arrested.
Mods: Yes.
