03-05-2024, 10:22 AM | #1 |
Rep 13
about TPM malfunction
Today when I was driving I got a TPM malfunction warning in my M8c. I was little bit nervous as I was driving on the highway, but it disappear after 3-4 minutes. I just checked the tire pressure they are all good. Anyone has this issue before? Do I need to worry about it?\\THX
btw I installed my winter tire in October last year, but this is the first time warning appear. |
03-05-2024, 11:28 AM | #2 |
Rep 5,548
Was it cold this morning? Sometimes you’ll get the error on cold mornings and then as you drive you continue to build up temperature/pressure, causing the TPMS warning light to disappear. Visually look at your tires to see if the one with the TPMS warning is flat/low on pressure.
Recently my wife was driving and she got a TPMS warning showing one tire was at 24 psi and then just a few seconds later it was 11 psi…she immediately pulled over and found an entire key sticking into the tire! |
4
03-05-2024, 03:21 PM | #3 | |
Rep 13
03-05-2024, 04:34 PM | #4 |
Rep 5,548
Yep. Temperature changed enough from when the tire pressures were first set to cause a TPMS error. One must have been slightly colder and it hit the threshold to throw a TPMS error. You’re good to go.
03-05-2024, 08:01 PM | #5 |
Rep 1,582
Also, I believe that the TPM measures "relative" pressure and not primarily a pre-set pressure. That means that if your last pressure reset was at 33psi then it will look for a -4psi change (just an example number) and it will warn below 29 psi. But if you reset it last time when the tires had 35psi, then it will warn you below 31psi and not below 29psi.
That's why in moderate climates I need to add air when winter comes, and take out air when spring gets here. In your case in Canada: add air in early September and take air out in late June
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
03-05-2024, 09:37 PM | #6 | |
Rep 5,548
fe7565552.50 |
03-11-2024, 04:13 AM | #7 | |
Rep 13
Westside Guy5732.50 |
03-11-2024, 04:21 AM | #8 | |
Rep 13
03-11-2024, 06:48 AM | #9 | |
Rep 5,548
Westside Guy5732.50 jz7.00 |
03-11-2024, 07:43 PM | #11 |
Rep 1,582
If you have Bimmercode or similar, you can set the TPMS to display both the pressure and temperature next to each tire on the screen.
03-13-2024, 01:28 PM | #12 |
Rep 103
03-13-2024, 01:35 PM | #13 |
Rep 1,582
If I remember correctly, it’s not under the advanced function. I think it’s under FEM.
03-13-2024, 10:00 PM | #14 |
Rep 1,582
BimmerCode
“Headunit” HU_CIC control unit • Pressure and temperature in tyre pressure monitor Enable/disable the pressure and temperature in the tyre pressure monitor in the iDrive system. Please note that the car has to be equipped with the required sensors. This option affects the display only and it is not possible to completely deactivate the tire pressure monitoring in the car. Values: o Active o Not active Requirements: o “Headunit” HU_CIC control unit ============================================ Head Unit NBT/EVO: • Tire pressure control The displayed values of the tire pressure control in the iDrive system. Please note that the car has to be equipped with the required sensors to make this work. Values: o Display pressure only o Display temperature and pressure o Not active Requirements: o “Headunit” HU_NBT or “Headunit” HU_NBT_EVO control unit
co_440i108.00 |
03-13-2024, 10:19 PM | #15 |
Rep 6,939
Drives: 2018 M2 AW DCT
My M2 has this display with no coding.
03-20-2024, 02:39 AM | #16 |
Rep 195
I got a low pressure warning and sometimes got it when it got really cold in garage. Now I get it every day. Inflated tires to 35psi in all 4 corners, RESET AND DROVE AROUND UNTIL 100%. Still every time at startup I get low pressure message -- Help please.
Sir, my concern is not whether God is on our side; my greatest concern is to be on God's side, for God is always right. - Abraham Lincoln
03-20-2024, 03:36 AM | #17 |
Rep 1,582
Next morning before you start the car measure each tire manually with a tire pressure gauge. See if there’s any difference of more than 2 to 3 psi between anyone of them.
03-20-2024, 11:57 AM | #18 |
Rep 195
I will do that today, but that has not been the case previously.
