M2 Technical Topics > Cosmetic Modifications > M2 Competition Painter Grille Center
      01-02-2020, 12:19 PM   #1
HSM2C
HSM2C's Avatar
17
Drives: 19 M2C / 77 Dodge Power Wagon
M2 Competition Painted Grille Center (Split Kidneys)
Anyone ever tried to paint the center of the joined kidney grille on the M2 Competition?
I'm thinking of attempting it myself and was wondering if anyone has any input or ideas that might help me and anyone else who's thinking of doing the same.
The steps I'm going to do are as follows:
1- Remove the kidney grille (not really needed, but it should make it easier to tape up and clean)
2- Wipe clean with water and dish soap, then dry with a microfiber towel
3- Clean with isopropyl alcohol (or wax and grease remover)
4- Tape up the area around the edges of the kidneys using masking tape and mask the grille to avoid overspray (and the surrounding area if the grille wasn't removed)
5- Lightly sand the area that's intended to be painted using 600 grit sanding paper
6- Wipe clean with isopropyl alcohol
7- Apply plastic primer (2-3 coats, wait 10 minutes between coats)
8- Apply adhesion promoter
9- Wait a few minutes, then apply 3-4 coats of paint (again wait for 10-15 minutes between each coat)
10- Apply clear coat (3 coats, wait a few minutes between each coat)
11- Wet sand with 1,500 grit paper (optional to eliminate any unwanted orange peal effect)
12- Remove tape, and reinstall the grille
      01-02-2020, 12:30 PM   #2
MR.
MR.'s Avatar
Yep done!
Workshop at a dealer did it for me.
MR
HSM2C17.00
      01-02-2020, 12:33 PM   #3
jkoral
Drives: 2017 M2 LBB 6MT
IND has them:
https://ind-distribution.com/collect...ed-center-trim
HSM2C17.00
      01-02-2020, 12:34 PM   #4
HSM2C
HSM2C's Avatar
17
Originally Posted by MR. View Post
Yep done!
MR
Looks really nice
How's the paint holding up? Do you know if they followed the same steps above or did they do anything more/less?
      01-02-2020, 12:42 PM   #5
HSM2C
HSM2C's Avatar
17
Originally Posted by jkoral View Post
I'm aware of the IND part. It's a lot of money for a really small painted section. To their credit they're selling a brand new OEM grille + the painted center, but I don't see myself needing a spare grille (fingers crossed it stays that way)
But thanks anyways for your input.
      01-02-2020, 04:39 PM   #6
MR.
MR.'s Avatar
Originally Posted by HSM2C View Post
Looks really nice
No idea if they used that exact process. I wasn't there.
I had it PPF-ed and the paint is holding up quite nicely!
MR
HSM2C17.00
