12-20-2019, 10:37 AM | #1 |
Rep 72
HELP! M Performance Trunk Lip spoiler didn't stick on the edges
Last night I removed the stock lip spoiler, removed all adhesive, washed and polished the area to ensure it was perfectly smooth. Applied adhesive promoter. Stuck the wing on. It seemed all good last night, although it was a cold night (50-55 degrees). This AM, I drove to work, parked in the garage and the outer rear edges are ever so slightly separated. You can't really see it, but if I press on it, I can see them move and make sticking noises.
The front edge seems perfectly stuck. It's only the rear ~3 inches on each side that seem ever so slightly separated. Again, not visible unless you press on it. There were 4 separate pull tabs and tape strips, and it seems that the front tape strip and rear tape strip sealed perfectly. I took those off prior to setting the wing on the trunk then used the pull tabs on the outer strips. These outer strips are the ones that don't seem to have stuck perfectly. What can I do? I don't think it will affect the function of the wing, nor will it likely peel off, but I am concerned about water/dust/gunk getting under it. Last edited by Bill in Marin; 12-20-2019 at 01:35 PM.. |
12-20-2019, 05:47 PM | #4 |
Rep 309
Drives: 2018 M2 LBB - 6MT
I think there's a big thread discussing this already. I think it's hit or miss depending on your trunk. You could try reapplying and add more double sided tape to the ends in spots that didn't already have it. Might help.
12-20-2019, 10:55 PM | #6 | |
Rep 2,200
12-21-2019, 11:15 AM | #8 | |
Rep 309
Wasn't as big of a thread as I remember, but nonetheless has people talking about it. Good luck |
12-22-2019, 09:05 AM | #10 | |
Rep 2,856
MR |
