08-05-2022, 06:23 PM | #45 | |
Rep 3,696
08-05-2022, 06:53 PM | #46 | |
Rep 7,429
Make sure you do an oil change after running fuel system cleaner, so fill up with fuel system cleaner and run through that tank. Then run through a tank or two of fresh gas before changing the oil.
shaneguags1192.50 |
08-05-2022, 06:56 PM | #47 |
Rep 7,429
It can't hurt anything, so why not give it a try? I would use Chevron techron or the bmw stuff which is supposed to be relabeled techron.
Like with Shane: Make sure you do an oil change after running fuel system cleaner, so fill up with fuel system cleaner and run through that tank. Then run through a tank or two of fresh gas before changing the oil. Afterwards to prevent this issue make sure you run a tank of fresh gas between a few tanks of ethanol mix. Or run top cylinder lube. I would also invest in a fuel filter, because ethanol is a really good solvent so it'll pick up a bunch of junk and bring it through the fuel system and you don't want that to clog injectors.
shaneguags1192.50 |
08-05-2022, 10:32 PM | #48 | |
Rep 1,244
Drives: 2017 Big Turbo BMW M2
08-05-2022, 10:52 PM | #49 |
Rep 7,429
An inline fuel filter that sits between the LPFP and HPFP. Bend calibration sells a really nice kit - the best kit I have ever seen on the platform (best filter and nicest mounting solution):
https://www.bendcalibration.com/shop...e-custom-lines https://www.bendcalibration.com/shop...ilter-only-kit For me I would probably go with my own lines so I would buy the filter byitself. This is detroitm2's install video if you want to learn more.
shaneguags1192.50 ZM22810.50 |
08-05-2022, 11:08 PM | #50 | |
Rep 1,244
08-05-2022, 11:22 PM | #51 |
Rep 7,429
I would say this is absolutely a requirement if you use ethanol blends, because ethanol is a solvent and that means it'll lose up and bring alot of debris through your fuel system. This filter will prevent your hpfp and injectors from potential clogs. That's the benefit you'll get, and again this imo is an absolute must.
08-05-2022, 11:25 PM | #52 | |
Rep 1,244
08-06-2022, 07:04 PM | #53 | |
Rep 7,429
You don't see many people having issues because it's always misdiagnosed or not reported. Look at the m5 community, you'll see those eu6 injectors are stuck frequently when the cars are on e85, why is this the case? Because debris. People also don't like to report issues, either because they either try to claim warranty or don't like to share unfortunate circumstances (which is absolutely understandable). Overall my opinion is this is a critical supporting mod that should be run even on pump gas, my tuning philosophy has always been to do every possible supporting mod and maintenance to mitigate issues as much as possible. This is to minimize my chance of ever running into an unfortunate issue like having an injector clog or stick open damaging the engine. |
detroitm22428.50 |
08-06-2022, 10:37 PM | #54 | ||
Rep 1,244
08-06-2022, 10:45 PM | #55 |
Rep 7,429
Yeah I understand, mods aren't cheap. In the mean time what helps is fuel system cleaner before each oil change. On pump gas you're ok without the filter, on e85 you really should get it.
08-07-2022, 03:07 PM | #56 | |
Rep 2,526
If you plan on running E85, I highly recommend a quality fuel filter. If you plan to just run 93, I'd probably still recommend doing it as "cheap insurance". It's pretty easy to DIY with the bend calibration kit. Someone posted my video above, it took me maybe a couple hours and that was including messing with cameras and a little trial and error since I've never done it, and there wasn't much on the way of videos showing how to do it. I'd imagine it's less than an hour of work with some basic tools and access to a lift. Feel free to PM me here or shoot me a message on Instagram if you need help. |
08-07-2022, 03:33 PM | #57 | |
Rep 7,429
detroitm22428.50 |
08-09-2022, 12:13 AM | #58 | ||
Rep 1,244
08-09-2022, 12:26 AM | #59 | |
Rep 7,429
Unfortunately there are no alternatives for bend calibrations solution (hence the astronomical price as there are no competitors), but I personally wouldn't want alternatives anyways unless they're using the same filter. Because the filter bend uses in their kit is second to none, it's literally the best on the market with a serviceable filtering medium. So unless you want to buy a separate filter and make your own bracket and buy your own fittings there is unfortunately no other way. I know project cars are money pits, but this mod is well worth it imo, and will save you down the line. Also don't forget every few tanks of ethanol run a tank of normal pump gas, or run top cylinder lube if you always want to be on ethanol. |
shaneguags1192.50 |
08-09-2022, 12:30 AM | #60 |
Rep 7,429
But this is also why I do all the supporting mods before I even touch a power mod. so when it's time to focus on power there's nothing else I have to do and nothing to get in my way and halt progress.
08-09-2022, 12:37 AM | #61 |
Rep 1,244
yea true, I just never knew this was a thing until now. we haven't done much driving since installing ethanol. maybe 3 fill ups ? I drove it for 2 days, filled in up to E60 and drop it off at the shop to get redialed in. I'm sure I'm fine for now. the kit will work on Motiv setup tho right ?
08-09-2022, 01:19 AM | #62 | |
Rep 7,429
Well it depends on what flex fuel sensor you have, where its mounted and what fuel lines. You may have to change your setup a bit. But yes the reflex will be able to use the ethanol sensor that the bend kit uses, but again your fuel line setup is probably gonna have to change. You might also have to use bends ethanol sensor if you want it to be inline nice and clean, otherwise it could be mounted else where (I'm not sure why your setup looks like so it's hard to comment). |
08-09-2022, 01:23 AM | #63 | ||
Rep 1,244
08-09-2022, 01:25 AM | #64 |
Rep 1,244
really not sure how the shop installed everything since I obviously wasn't there to see but I'm sure it was done like how most would have done it. I'm really hoping I don't have to buy a new fuel line and sensor
08-09-2022, 01:32 AM | #65 | |
Rep 7,429
Oh you have the short line kit from motiv, I am not sure how far this goes back but if it is just in the engine bay from the HPFP then you should be fine with the bend kit but you will need additional fuel lines and connectors to splice the bend kit into or you will need to get the fuel line bend includes. If it goes further back you will need to modify the motiv lines by either adding connectors or splicing into it. Honestly I think it is better to just buy a full line from the lpfp to the hpfp and splice in connectors for the fuel filter and the current sensor you have now. That's what I plan on doing.
08-09-2022, 01:50 AM | #66 | ||
Rep 1,244
