07-09-2021, 11:51 AM | #837 | |
Rep 4,146
07-09-2021, 12:54 PM | #838 |
Rep 1,389
Car definitely is faster all the time with upgraded IC, it's what I found. But at same time I also had MST V2 inlet done with turbosmart DV so not apples to apples. All those things have 8-9hp peak on Dyno and better top end.
I'm convinced I've felt heatsoak on stock IC even on the road in the UK! Interestingly though three back to back runs on stock IC on Dyno showed very consistent power results. |
07-10-2021, 07:48 AM | #839 | |
New BMW owner
325
Rep 843
I still need to bring my car in to a shop to install the turbosmart DV & MST. It’s just sitting here. I want to install it myself but just scared that it’s as hard as everyone says it is. I rather pay someone then. It’s not the money actually but I feel those guys aren’t as meticulous. Anal. The real power comes around 3500 rpm right? Like the really angry power. Always Sports+. Last edited by vrooooom; 07-10-2021 at 07:54 AM.. |
07-12-2021, 11:11 AM | #840 |
Rep 4,146
I recently had a shop install my MST intake and Turbosmart DV plumb back, in addition to belt change, spark plugs, oil, brakes, and some other stuff - the inlet and DV install was about $300 (he said he spent a few hours on it, but it wasn't too bad, but gave me a break on the labor)
Those alone really sharpened up the throttle response and logs say the car holds boost better, and overall it feels stronger. Just recently, I was planning on selling my MPPK/M2 lower intake, and just use my stock one with the AFE Drop in filter (M235i). In putting on the stock lower box, throttle response was diminished, and the low end felt softer (more lag) until about 3500rpm. It basically took more throttle to make gain the same response before - I'm still thinking it's in my head. I just swapped back MPPK/M2 lower and will do some driving to see if it's purely psychological. Overall, the DV + inlet did help, and especially as a manual.
Mods: Yes.
07-12-2021, 12:34 PM | #841 |
Rep 753
This is very similar to my experience with throttle response after installing the ER intercooler and charge pipe. Wondering if the TIP (turbo intake pipe) and DV will help revert things closer to stock, or should I simply try installing my 300 cell Akra dp first.
07-12-2021, 12:41 PM | #842 |
Rep 4,146
Are you still using the stock filter? And it's absolutely, tangibly better with the TIP and DV.
Mods: Yes.
07-12-2021, 12:50 PM | #843 |
Rep 753
Yeah, stock airbox and filter. Was thinking of throwing a K&N panel in there like all my other cars at some point. DV on the M2 seems like a PITA to replace. My thinking is the higher flow downpipe should compensate for the intercooler with slightly faster spool ...
07-12-2021, 12:57 PM | #844 | |
Rep 4,146
Mods: Yes.
pal433.00 |
07-12-2021, 07:07 PM | #845 |
New BMW owner
325
Rep 843
My car before this is a Subaru Forester XT abd an automatic. So when I first drove this car it was crazy! Instant power and always ready to. I’m not sure if I have just gotten used to it which I’m sure is part of it but now I don’t feel like it’s so “immediate”. Which is why I’m also looking forward to the TIP, DV and DP to try and relive back that impression. I “felt” it after BM3…. which makes no sense. Right? After the CST IC, I didn’t feel any difference but seems more power when it wakes up at around 3.5 rpm.
07-13-2021, 04:14 AM | #846 | |
Rep 1,389
Someone said their idle wasn't quite normal with AFE or something wasn't as smooth, not sure If it was Xutvjet? |
07-13-2021, 04:31 AM | #847 | |
Rep 553
I do clean/wash it every 5-8K km as I do a few country drives and after installing the F80 alloy/carbon bracing I bought a 2nd filter so I always have a clean one on hand. |
07-13-2021, 05:52 AM | #848 | |
New BMW owner
325
Rep 843
07-13-2021, 11:43 AM | #849 |
Rep 4,146
Yes
Stock inlet and DV valve + AFE/MPPK - Good MST inlet and TS DV valve + AFE/Stock lower - ok MST inlet and TS DV valve + AFE/MPPK - Great
Mods: Yes.
07-13-2021, 12:57 PM | #851 | |
Rep 4,146
All M235i have the 330hp N55 variant, but they don't have the lower intake box.
Mods: Yes.
07-13-2021, 10:47 PM | #852 | |
New BMW owner
325
Rep 843
MST inlet and TS DV valve + stock paper filter/MPPK (if stock on M2) ? Does the AFE drop-in add anything to the system? I've read that the stock air intake isn't the bottleneck and opening it doesn't add anything especially on the lower half which makes the most impact for most of us.
07-14-2021, 10:55 AM | #853 |
Rep 5,372
Yes, I've had the AFE for quite a few years and have swapped it back and forth with the OEM air filter. The AFE definitely creates more turbo noises and slightly snappier throttle response, but the engine sounds and feels a little more strained, especially the MPPK airbox I'm running. I also don't like the driveability below 3000rpms with the 6MT and AFE filter. When you first install it, it feels great and then the DME starts adapting and driveability starts to suffer a bit. I got rid of the AFE about 6 months ago. I don't miss it.
07-14-2021, 01:22 PM | #854 | |
Rep 4,146
But the engine does have a huge empty sucking noise at about 50-5500RPM up that makes me feel like the car is just sucking in warm air. It’s there with the stock air box too, but it’s less pronounced and comes on later. My car feels strong AND consistent though. It's punchy, smooth, and drives like normal, and it’s $65 bucks and 3 minutes - I think it’s worth it. Last edited by AmuroRay; 07-14-2021 at 01:30 PM.. |
07-26-2021, 10:51 PM | #856 | |
Rep 553
There are 1 or 2 posters who bag the Wagner but here is my experience. I DIY installed (car up on stands), was straight forward with no mod/cutting required and connecting the inlet/outlet pipes was again straight forward. I've now been on a BM3 custom stage 2 tune for around 25K km. For street I would say it's excellent, I think you'd only want better if you live in a very hot climate. I recently did a 3K km country trip which included a lot of hard mountain driving, constant 50-100% throttle in 2/3/4th gears & IAT's remained 6-10 deg C over ambient, I would say average was 8C over. Low or off throttle (ie steep descents) IATs climbed a little but once back on throttle it was only a matter of seconds for IATs to get back to 8-10C over ambient. I would agree that the Wagner Evo2 is not ideal for tracking in warmer/hot ambient conditions especially if you're going wot into 5/6th gears. Below is a log of the main straight from a recent track day with 20C ambient temp, IAT's were consistent throughout the 20min session. I'm seriously thinking of going to an Evo3 as summer temps get to 30-35+C. https://www.bootmod3.net/log?id=60c9...729b6092da4479 |
07-27-2021, 10:26 AM | #857 | |
24199
Rep 190,807
07-27-2021, 06:56 PM | #858 |
Rep 184
Drives: 2017 BMW M3 Competition (LCII)
Ordered the CSF intercooler at Extreme Powerhouse, shipping and assistance was great.
The intercooler itself looks really nice, however it's a fucking embarrassment that CSF allows such washers and screws to be included in the kit. Would love to have seen proper rectangular washers and proper screws (preferably torx) included. Having said that, the install was a bit of a tight squeeze but I managed to get it done. No logs or anything but the car seems to be running fine. Will post a video later as well. |
Sundinisagod107.00 |
