M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Swapped steering wheel...now airbag light
      04-17-2020, 12:29 PM   #1
Subzero88
Drives: BMW M2 Coupé
So i recently swapped/upgraded my steering wheel and now I'm getting the "Passenger Restraint System" fault. Also if I use the horn, it constantly sounds until I unplug the battery.
I did disconnect the battery, maybe not for long enough before removing the airbag? I have double-checked the connection from the airbag to the car and clipped in properly.
I'm really struggling to find out exactly how I can wipe this fault code, I see I need an E-SYS cable...
Does anyone know if this product would work? https://www.ebay.co.uk/itm/133168129641
any help would be really appreciated.
      04-17-2020, 07:04 PM   #2
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
Yes , that's the proper cable for Esys and more than likely you tripped the airbags wire(s). I would take it apart first and double check if anything is kinked.
      04-18-2020, 12:26 AM   #3
eeyang92
Drives: LBB M2 LCI 6MT
Generally this indicates a short or the ground was not properly attached.
I recently watched an install vid here where he mentions the "horn being stuck on" issue:
