01-08-2023, 09:58 AM | #1057 | |
24378
Rep 191,194
You won't notice any decrease in the throttle as long as you are running stage 2 boost maps. 2) If someone dyno'd the car afterwards, but did you see any HP/Torque improvements on a stock tune post IC change (this is more general with any of the larger ICs)? The temps rise from your first pull, so the performance increase can easily be noticeable on the dyno or datalog. And the more pulls you do back to back, the more significant the difference in performance will be. 3) Would you say the ER IC was worth it? I know the install is a lot more complicated given you have to take off the bumper and some braces I believe (I'm using my local shop, so will likely have a larger labor bill), but do you think it was worth it/benefit the overall setup? An upgraded intercooler on this car is a must. And ER is the best quality intercooler on the market. It's the only one made in the US, as far as I know. 4) Would you recommend swapping the Turbo Inlet at the same? I already have the ER Charge Pipes installed (was a pain, but I also have gorilla hands) but figured its worth inquiring about the Turbo Inlet if I'm taking it to the shop anyways.[/QUOTE] Upgrading the inlet will improve the airflow to your turbo and improve the performance.
02-09-2023, 09:33 PM | #1058 | |
Rep 14
AmuroRay2316.50 |
02-09-2023, 10:06 PM | #1059 |
Rep 4,177
Logs?
Mods: Yes.
02-09-2023, 11:45 PM | #1061 | |
New BMW owner
328
Rep 845
1) Just want to add, you'll need a performance downpipe to do stage-2. which is probably the reason for not having the lag.
3) I don't think anyone would be able to tell u if it's worth it. I wish there are objective test that compares all the other IC to each other performance-wise.....but none that I'm aware of. if "made in USA" is what's impt to you then this is one of your option (if not the only). I almost bought the ER-IC but I didn't want to mess w/ the car too much. (brackets and removal of bumpers). 4) the FMIC is not connected to the turbo inlet. u also don't need to remove the IC to do the turbo inlet as far as I remember. one thing I'm sure of, if you think the charge pipe was tough, the turbo inlet will give you nightmares. It's easily 2x harder and tighter. I don't know how the others w/ big hands were able to. myb coz I also did the blow-off valve w/ that mod. Quote:
02-12-2023, 01:45 AM | #1062 |
Rep 1,389
I'd I recall correctly I made around 8-9 peak extra HP on stock map just with addition of DO88 FMIC, MST V2 turbo inlet, forge charge pipe and turbosmart DV valve.
Ambient conditions similar but runs were not done on same day. Same tank of fuel though. |
02-16-2023, 09:16 AM | #1063 |
24378
Rep 191,194
03-20-2023, 09:19 AM | #1064 |
Rep 1,430
mike, long while ago you had reco the AA FMIC for my application...never bothered because i thought i would move on to another car but have decided to keep her and plan to make some upgrades.
-live in toronto -no track likely -have FS sport car (purchased from you -love it!) -plan to go bm3 stg 1 and then 2. -everything else is stock but other than maybe a catback exhaust, charge pipe, i dont plan on upgrading turbo etc... what u recommend for a FMIC? And would your answer change if i stayed stg 1? |
03-20-2023, 09:22 AM | #1065 | |
24378
Rep 191,194
The race intercooler is meant for stage 2 but will work well with stage 1. MAD and BMS are the two most popular high-density intercoolers that we offer. If you are staying with stage 1 for sure, you probably want to get a 5" high-density intercooler. It will perform the same as the race on the street, but it's lighter and will cost you less.
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 03-20-2023 at 12:14 PM.. |
Dabozo635.00 |
03-20-2023, 12:14 PM | #1067 | |
24378
Rep 191,194
MAD 5" for the F chassis, part number MAD-1010 MAD 7" for the F chassis, called MAD Race, part number MAD-011 i'll fix my first post to avoid any confusion
Dabozo635.00 |
03-20-2023, 01:48 PM | #1068 | |
Rep 4,177
To that end, something like the MAD and BMS both have the same fin density compared to something like the DO88 (a 6” core) - they will perform about the same. TL: DR Mike is right, get the BMS or MAD. Last edited by AmuroRay; 03-20-2023 at 03:47 PM.. |
Dabozo635.00 |
04-18-2023, 12:24 PM | #1070 |
Rep 446
Looking for IC recommendation for tracked car in the midwest. Goal is just to prevent power loss mainly, stock operated fine under 65F. Plan to add catless dp and a light tune as well
Current: 2018 M2 DCT
Previous: 2011 E92 M3, 2007 E92 328xi Insta: @kmannc |
04-18-2023, 01:16 PM | #1071 | |
24378
Rep 191,194
Thanks to its tube and fin construction, it's lightweight and offers a significant upgrade over the stock version. Considering that you don't intend to increase the power substantially beyond the stock level, a high-density core won't be necessary for your needs.
04-18-2023, 03:12 PM | #1072 | ||
Rep 4,177
The Evo 1 is expensive and absolutely under performs in all objective measures. Quote:
It did even worse in a single gear pull on a JB4 car. It’s not fit for a stage 1 N55 (about par for a M2) and it’s absolutely unfit for any type of track duty. If you don’t want to modify anything, the CSF and the VRSF Competition are the Best Buy’s, but the VRSF is a tighter fit. If you don’t mid pulling the bumper, the VRSF Race. MAD Race and ER are going to be the top of the line. I’m not recommending the Evo 3 because of its price to performance ratio and because it is being claimed to cause coolant issues.
Mods: Yes.
04-18-2023, 03:18 PM | #1073 | |
Rep 4,177
As you can see - it’s a poor performer with just a “stage 1” tune (stock M2) it’s basically as bad a stock by 3rd gear.
Mods: Yes.
04-18-2023, 05:03 PM | #1074 |
24378
Rep 191,194
I know
While I acknowledge that a higher-density core may indeed improve cooling efficiency, considering the power output and the objective to use the car on the track, I believe that the lighter Wagner option could provide greater benefits.
04-18-2023, 06:26 PM | #1075 | |
1973
Rep 5,025
04-18-2023, 06:49 PM | #1076 |
Rep 4,177
It’s on par with all the other 5” cores so it’s not a bad option, especially at its price point(Probably the best deal) the VRSF just has 1.5” of depth, and a denser fin pack (18 vs 16) The difference between all of them is likely small, until you get into the race intercoolers.
Info@mad-us.com1972.50 |
04-21-2023, 11:35 PM | #1077 |
Rep 78
So with me currently running CTS cold air intake, MHD stage 2 and VRSF catless downpipe, would the front mount intercooler be necessary? If so is VRSF a good one for that or do I need other brands
