02-24-2020, 11:05 AM | #1 |
Rep 786
Foot get caught when clutching out?
Hey guys so i have a strange "issue". The issue is that after i press the clutch in and then slowly let off, the tip of my foot (toe area) kinda gets stuck in the upper area right above the pedal. Now my drive style is i generally press the clutch, then anchor my heel to give myself a leverage point in order to maximize clutch control. This mainly happens when i'm in stop and go traffic or if i'm inching forward or backward.
I'm 6'3" and my shoe size is a 12. Now the shoe i tend to wear the most are my Adidas Ultraboost which are a bit wide in the toe area so i'm not sure if this is the reason for that. I do have a few pairs of Asics Onitsuka Tigers which are a thinner running shoe that i can try and see if it fixes that problem. I've also been thinking of getting some driving shoes to fix this problem for extended drives. For reference i drove the same way in my BRZ, S2000, Focus ST, Fiesta ST, WRX, Eclipse GST and never had the foot catch issue. The only car that i seem to have this issue in is the Mazda ND Miata. I'm curious if any of you have experienced the same thing and what your solution to it was. Changing the way my clutch foot works right now is putting more strain on me just driving around that i feel it should, but maybe i just need to get used to it. |
02-24-2020, 11:16 AM | #2 |
Rep 3,842
I tried driving shoes, unfortunately my extremely wide feet won't comfortably fit in them. Try tennis shoes, they are made with less toe space.
02-24-2020, 11:18 AM | #3 |
Rep 786
Do you have the same issue as i do if you wear wider toe area shoes? I'm just wondering if maybe i've actually had terribly driving technique all these years.
02-24-2020, 11:34 AM | #4 |
Rep 3,842
I often have to buy my shoes too big for my feet since my feet are like paddles 😂. It leaves floppy hollow toes at the end that get caught on stuff.
02-24-2020, 12:22 PM | #5 |
Rep 843
I operate the clutch EXACTLY the same way you do - with my heel as an anchor, and my foot feathering the clutch pedal to get max control.
I've tried every conceivable shoe in existence and came to a conclusion. The M2C in 6MT form was never meant to be driven with a left shoe. Socks only, with left shoe removed and placed in the passenger footwell. We need a t-shirt for this. Last edited by MMMBRAP; 02-24-2020 at 12:30 PM.. |
02-24-2020, 12:37 PM | #6 | |
Rep 786
MMMBRAP975.50 |
02-24-2020, 12:47 PM | #7 |
Rep 1,899
I wear ultra boost size 10. No issue here with getting caught anywhere. But I also don't anchor my heel and can control the clutch just fine using the whole leg
02-24-2020, 01:10 PM | #8 |
Rep 786
Yeah i find if i use my entire leg then i dont get an issue getting my foot caught. However in stop and go traffic or parking lots, using my whole leg to adjust clutch control is more effort than it needs to be.
02-24-2020, 01:15 PM | #9 | ||
Rep 843
Also, don't wear any shoes with "studs" on it. I have a pair of driving shoes with grippy studs and using our heel anchor method with shoes like that is a nightmare. I also tried driving with my AirMax's on since it has a relatively smooth bottom but that didn't work out either. Socks bruh. Socks. Quote:
It's MOST likely because I'm 5'7" and have short legs lmao. Using my heel as an anchor helps me a lot. The ONLY car I could wear shoes and drive perfectly was in a new ND MX-5, which was the car I almost bought before deciding it was too cramped for me. The 6MT shifter in the ND is SUBLIME and the clutch is buttery smooth, even with shoes on. Last edited by MMMBRAP; 02-24-2020 at 01:23 PM.. |
02-24-2020, 01:24 PM | #10 |
Rep 1,049
Size 11 shoe, don't have any problems with it getting stuck. I don't use the anchor method, as you described, simply just use my whole leg.
I would look into removing the panel above the pedals. None of my other cars had this panel, and (from what I can tell), it just prevents you from being able to see up into the pedal box. Should give you some more foot room. |
02-24-2020, 01:27 PM | #12 |
Rep 2,288
I've experienced that, i mostly wear Jordans but i've also experienced that with Timbs. However, when i wear dress shoes, there doesn't seem to be that issue. Probably just the way the pedal box was designed. It's not dangerous or anything, just something to be cognizant about.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
02-24-2020, 01:46 PM | #13 | |
Rep 786
02-24-2020, 01:46 PM | #14 |
Rep 8,970
Issue here i think is the heel pivot. Clutches are meant to be used whole-leg just with the ball of your foot on the pedal
Or a slight heel drag at bite point in traffic maybe. But if you put your foot way up then your toes get caught under the dash trim. I'm only size 8 and if i have winter boots on i can't feel the pedal, my foot slides up and sometimes get my toes caught. |
02-24-2020, 01:47 PM | #15 |
Rep 786
I thought about this and spent a good 10 min readjusting my driving position to see if it helps. The best i've been able to manage is get the seat as low as possible and far back enough so that i'm forced to use my entire leg rather than my heel. It works, but its more energy to do the same action that barely took a second thought originally.
02-24-2020, 01:49 PM | #16 | |
Rep 786
02-24-2020, 01:50 PM | #17 |
Rep 1,049
02-25-2020, 03:18 PM | #19 |
Rep 308
Size 12-13 Steel toe, pretty hefty, workboots for winter, and not an issue. I have to say though, my goofy proportions do come as a benefit in this car. 6' tall but 36 inseam and 38 sleeve length have seat all the way back, steering slammed forward, and plenty of headroom
Now, catching brake pedal all the time with my right foot on the gas and wearing boots? That's a thing |
02-25-2020, 06:33 PM | #20 |
Rep 786
I actually adjusted my technique and so far have no had an issue.
For those wondering, i've been clutching in with the pad of the foot right behind the toes. Then lifting back right before the engagment point. Once there i anchor my heel and then release the clutch out as i normally do. If i drive it like that i have zero issues. However due to this it seems like a BMS clutch stop might be in order as the amount of space that i have to move my leg before i anchor my heel is roughly the same distance that the clutch stop is supposed to get rid of. So that might be on my list of first mods. |
02-26-2020, 06:28 AM | #21 | |
Rep 7,594
Drives: '19 M2C
Every MT BMW I have owned I feel like my shoes got in the way. Asics were a great solution due to the more pointed toe area.
www.ReTuneTheDeTune.com
02-26-2020, 07:48 AM | #22 |
Rep 3,288
I'm not sure how these would do for all of you with such big feet, but these are my favorite driving shoes at this point. I have a couple of pairs:
https://piloti.com/ |
