M2 Technical Topics > Cosmetic Modifications > Lightweight front lip install?
      05-27-2020, 09:40 AM   #1
ecitizen
Drives: 2013 328i
Anyone install the lightweight front lip on their own without a lift? I have one coming and trying to decide if I give it a go with ramps on the front wheels. Looks straightforward to install but welcome DIY experiences.
      05-27-2020, 10:44 AM   #2
McLaren720s
McLaren720s's Avatar
Drives: 2024 M4 Competition X
I just installed my M Performance front lip and I had to get the front wheels on ramps otherwise I didn’t have enough clearance to drill the screws in.
      05-27-2020, 06:08 PM   #3
mr_lab_rat
mr_lab_rat's Avatar
565
Drives: 2017 M2, 2018 X1
Very easy to do without lifting the car, you don't need much room.
I would suggest using well nuts instead of the provided jack nuts. Two benefits - rubber doesn't rust. The lip on the well nut will act as a spacer to avoid upwards angling of the spoiler.
Bosozoku693.50
      05-28-2020, 01:41 AM   #4
ecitizen
Drives: 2013 328i
Can you show me a pic of a well nut? Not familiar with that.
      05-28-2020, 08:19 AM   #5
SIE_M2
8
Drives: Bmw m2
Thanks for the tip as about to install my lightweight splitter. Did you use well nuts?
      05-28-2020, 09:27 AM   #6
mr_lab_rat
mr_lab_rat's Avatar
565
https://www.amazon.ca/Wellnuts-Motor...016JADPTW?th=1 (the ones I got have a bigger lip, I went for imperial size 1/4inch 20 thread)
The brass thread is only at the tip so as you tighten the bolt the rubber will expand. Motorcycle guys use them for windshields, this forum page shows a diagram of how they work - https://www.kawasakiversys.com/forum...move-help.html
Not at first, I used the supplied jack nuts but one of them didn't grab properly and came out just few months later when I had to temporarily remove the splitter. So I replaced just that one with a well nut but I liked how it worked and also that it fixed the angle issue. So I replaced all of them.
      05-28-2020, 10:02 AM   #7
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Similar concept with a rivet but theoretically doesn't have as high of a load bearing strength. Should be enough tho but I wonder how long the rubber can last before it degrades
      05-28-2020, 10:50 AM   #8
mr_lab_rat
mr_lab_rat's Avatar
565
True, the metal jack nut can theoretically hold a bit more. But ... it has sharp edges so it can still rip through the hole. As far as longevity, looking at the 9 month old jack nuts that came out I'm willing to bet the metal will rust before the rubber degrades.
      05-28-2020, 10:03 PM   #9
Duke Silver
Drives: '17 MG M2
I wonder if you were to use a nylon/rubber washer between the lip and jack nuts it would have the same effect. Did you have to purchase extended hardware when using the well nuts?
I'm looking at installing mine in a few weeks after the ppf goes back on the bumper, I looked into well nuts and they seem almost impossible to get here in Australia.
Weird thing I noticed also that there are three 35mm fixings for the lip and only 1 goes into the central piece along with a 25mm, so I'm not sure where the other two extended screws are to go.
      05-28-2020, 11:55 PM   #10
Kankles
Rear Admiral
Kankles's Avatar
Drives: Bavarian Milk Wagon
2019 BMW M2C  [0.00]
I've done a lightweight on ramps before (F80) and just did my M2 lip on ramps. You don't need a lift.
For my current lip it came with stainless bolts (10mm head) and nyloc nuts for the center section. Self tapping screws and 3m tape everywhere else and overall is holding good.
      05-29-2020, 02:11 AM   #11
SIE_M2
8
Drives: Bmw m2
I noticed this too. I can only surmise that the other two 35mm fixings go into opposite sides of the splitter where the jack nuts have been inserted.
      05-29-2020, 02:15 AM   #12
SIE_M2
8
Drives: Bmw m2
Did you use the rubber spaced provided when you converted to well nuts?
      05-29-2020, 04:49 AM   #13
nioh_lbbm2
nioh_lbbm2's Avatar
1717
There are blind rivets designed specifically for plastics though which have broad flanges. These should be better than a rubber well nut:
https://www.mcmaster.com/blind-rivet...nd-composites/
      05-29-2020, 09:08 AM   #14
mr_lab_rat
mr_lab_rat's Avatar
565
Yes, a washer would help with the lip angle. And yes, I needed to get longer bolts.
My lip didn't come with any spacers other than the centre piece.
      05-29-2020, 01:14 PM   #15
ecitizen
Drives: 2013 328i
Can someone post a pic of these well nuts or washers installed? Still trying to understand if I should go this route or just what it comes with.
      05-30-2020, 10:26 AM   #16
McLaren720s
Self tapping screws have worked just fine for me
      06-03-2020, 10:38 PM   #17
mr_lab_rat
mr_lab_rat's Avatar
565
The problem with that is that you can't remove and reinstall it too many times before the holes wear out. And you need to remove the lip if you want to access the engine from the bottom.
I actually had to take the lip off just to get wheel alignment because it was blocking the laser beam of the alignment machine.
Sorry, I was gonna take a picture of the lip installed with well nuts but forgot. I'll try to get to it tomorrow.
      06-09-2020, 12:26 AM   #18
ecitizen
Drives: 2013 328i
Install questions??
All,
I went to install the front lip, and have a few quick questions.
1) Just to confirm, I need to drill 6 new holes--2 on each outer edge and the 2 in the middle for the spacer, correct? For the outer edge holes, do I drill the 2 closest to the edge of the bumper circled in black or the ones in the rear, circled in red? The ones in front seem so close to the edge of the bumper. What are the 2 extra ones in the rear for?
2) There are a couple of rivets along the edge where the bumper meats the plastic guard on the corners. Do I just remove those or leave them on? They are in between the screws that go in the fasteners provided by Lightweight.
3) I pulled the plastic off of the lip and I must say the finish isn't very clean, sort of swirly like. Was your like that? I suppose I didn't expect much but it's a bit rough.
      06-09-2020, 09:52 PM   #19
Duke Silver
Drives: '17 MG M2
All,
I can't answer this as I haven't tried installing mine yet. But I'm wondering if it's universal with the M2C and it just has different fixing locations.
Will the jack nuts fit in that front holes that you have circled black? I wouldn't have thought there would be much depth in that part of the bumper.
      06-10-2020, 12:49 AM   #20
ecitizen
Drives: 2013 328i
All,
Yes, they go in the front. One stripped out of the hole but all the others did fine so I'm not too worried about the one in the corner that didn't work. It looks so much better with the lip. Install was a pain without a lift and torqued my neck but it's done. It's not difficult just weird angles without a lift. The look is clean and exceeded my expectations.
      06-10-2020, 08:09 AM   #21
2PUTT
Drives: F87
grabbed this picture from the interwebz for reference...
      06-10-2020, 11:17 AM   #22
ecitizen
Drives: 2013 328i
That's a different model car. The lip and factory screw placements are different for the M2. Thanks for posting though.
