05-05-2020, 09:06 PM | #1 |
Rep 785
Window trim removal
Does anyone know how to remove the window trim? I looked up the closest video i could find and the person said i should just be able to pull it off. Well i tried that and ended up bending the part closest to the rear.
Does anyone know how to remove the part without bending it or breaking? I'm in the process of wrapping my car and it will make wrapping the door much easier. |
05-06-2020, 02:41 PM | #2 |
844
Rep 1,962
Given the expense of wrapping a car, maybe if you buy the part from BMW you'll be able to see how it attaches and hence reduce the risk of damage? Plus, if you still damage it, you have a replacement ready to fit...
05-06-2020, 04:45 PM | #3 |
Rep 785
well its not too expensive as i'm doing it myself. And i have already bought a replacement part. However i'm curious if anyone knows off hand so i can avoid having to spend more money.
05-06-2020, 07:43 PM | #4 |
Rep 172
05-07-2020, 12:06 PM | #5 | |
Rep 785
05-07-2020, 12:31 PM | #6 | |
Rep 172
EDIT: I actually found it. It seems there's a screw under the weatherstripping where it bent for you. https://www.newtis.info/tisv2/a/en/f...strip/KVVvVhdd |
05-07-2020, 01:06 PM | #7 | |
Rep 785
05-08-2020, 10:25 PM | #8 |
Rep 166
So the trim on the door below the window is called a "belt" moulding. This is very easy to remove. Just roll the window down and pull on it.
Keep in mind.... on bmw the black (chrome for not sport package) is separate from the rubber. Will pull out separate. If this happens. Don't worry. Just slide it back in. Now the trim on the roof rail to where your door closes to... pull the body side weather strip off. There willl be bolts in there. Take those bolts out. And it comes right out. The trim around the qtr panel window. That's all part of the window. So to remove that. Have the window pulled out. You can not remove the trim without removing the qtr glass. It's one piece. |
05-09-2020, 10:19 PM | #9 | |
Rep 785
05-09-2020, 11:13 PM | #10 | ||
Rep 166
When you stick your finders between the glass and the belt mldg rubber. Fish for a lip with your finger tips and pull up. |
