04-10-2024, 11:59 PM | #1 |
Rep 71
Getting OG M2 Track Ready for Season
I'm getting the OG (43k miles) ready for track season (6-12 events), and I wanted to see if there are any other recommended service items.
Here's what I've done, or the shop has done so far over the past few weeks: Completed: Ignition Coils and Sparkplugs Belt, Tensioner, and Idler Pulleys Engine Oil and Filter MT Fluid Differential Fluid Air Filter TC Kline Coilovers installed Corner Balance and Alignment New Track Pads Brake Fluid - Motul RBF 600 Michelin PS4S should get me through the season Any other service items worth doing? |
04-12-2024, 06:18 AM | #3 |
Rep 423
Drives: F87 M2 DCT, F15 X5
I agree; please verify the rotor thickness and give the wheels a good tug to check for wheel bearing play (do this before every event, anyway).
How much camber did you get on the front with the alignment? I'd also recommend removing the front brake dust shields to help with brake cooling. You could also put on some Camaro brake cooling flaps. You can see my journey here. https://f87.bimmerpost.com/forums/sh....php?t=2028155
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
04-12-2024, 02:08 PM | #4 |
Rep 583
I think you're a little optimistic with your tire expectations. 6 dry events on PS4S is a stretch, let alone 12.
If your pace is advanced, it's more cost effective to go with track dedicated wheels and a more track specific tire.
2017 BMW M2 5Spd, 2007 VW Touareg, 2023 Yamaha MT09 SP
https://www.instagram.com/dvas99/ https://www.youtube.com/channel/UC2j..._as=subscriber |
DrKevM52276.00 |
04-12-2024, 02:11 PM | #5 |
Rep 423
I ran PS4S last year as an instructor for 4 events. First year with the car. The wear was exceptional, but I can turn them to greasy mush in 3 laps! The compound definitely cannot keep up with advanced driver pace.
04-12-2024, 03:29 PM | #6 |
Rep 71
I do have an extra set of 437Ms I could throw on a new dedicated tire set for track purposes. I’ll also be sure to check out removing the dust vents.
04-13-2024, 12:55 AM | #8 | |
Rep 71
I asked them to put about -2.25 to -2.5 of negative camber on the front, but they didn’t give me an alignment sheet when I picked up the car. I plan to call on Monday and request an emailed copy to confirm exact alignment info. |
04-13-2024, 12:57 AM | #9 |
Rep 71
Thank you sir! I’m actually wondering if my rotors need to be replaced and how much time I can buy before doing that. Tech indicated they were grooved but didn’t indicated how bad. No cracks in the holes, but I need to check for a lip while I do a more through look with the wheels off the car.
04-13-2024, 09:36 AM | #10 |
Rep 350
28.4mm is the front, I can't see from photos online what the rears are. The min thickness is written on the rotor hats, you'll find it easily with the wheel off and can probably even read it with the wheels mounted depending on how the car is sitting.
The rears can last a long time, I'm still on originals after 76k KM, compared to my 3rd set of fronts after a lot of track driving (I've replaced the fronts because of heat stress cracking rather than thickness). |
