01-18-2024, 05:32 PM | #1 |
Rep 58
Hey guys I have a 2017 m2 it’s currently full fbo and I just put a b58 tu pump in I decided to try the the bm3 stage 2+ e30 map and it was running perfectly for 2 days I took it to 160mph no problem or hiccup. Today on the way back from work I was racing a mustang and I went 3rd gear and took off after I passed him my car started misfiring high rpm and went into limp mode. This use to happen on stage 2+ 93 I assumed it was the fuel pump at the time… but I just upgraded it. I have colder plugs and also percion race work coils I’ve heard they can cause a problem but I don’t see why.
Unfortunately I didn’t get a log of it happening If anyone can help diagnose or if anyone had a similar problem Mods: Eventuri intake Charge pipe (vrsf) M performance exhaust Catless arm downpipe Arm gold intercooler Turbo to intercooler inlet Precision race work coils Step1 colder plugs 3.5 map sensor B58 tu pump |
01-18-2024, 06:35 PM | #2 | |
@lbb_kev
494
Rep 515
Without any data you'll be just throwing darts in the dark and start randomly replacing items.
01-19-2024, 01:13 PM | #4 |
Rep 249
It's not OTS's problem. You only gonna run more aggressive with custom map. Can't diagnose anything from these misfire codes since they are so common. like @Eidos said, it could be caused by a lot of things. Logs would help a lot.
