01-10-2022, 10:18 PM | #1 |
Rep 342
Oil pressure—does it come through the canbus?
The discussion around oils in another thread has me wondering why I don't get oil pressure readings on my Aim Solo2 DL. I get a ton of other data (neat if not useful) but no oil pressure. In the S55 technical documents, BMW states the S55 uses a sensor that provides absolute oil pressure reading to the DME but that's it.
So my question is, can you get oil pressure through the canbus and if so, how might I get my Solo2 to log it? I attempted to search this a bit and the search kept failing for some reason. ¯\_(ツ)_/¯ |
01-18-2022, 12:43 PM | #2 |
Rep 342
I was able to confirm that with an OBD dongle and BimmerLink that Oil pressure (as well as a ton more data) does appear to come through the canbus, so I called up Aim to ask them about how to add oil-pressure to logging.
Bad-ish news I spoke with Aim support and they basically said that there isn't an easy method for adding an additional channel to their protocol. It's either use their protocol or use a user-created one (starts from scratch). Good-ish news The person I spoke with said they could look at adding that information to their protocol if I can provide some details about the particular channel I'd like added.
So now, and this is a bit of a side project, I'll see if I can sort it out. It looks like I'll need to figure out how to sniff the canbus and then find the channel for oil pressure to provide the details. There are a couple open-source apps I may be able to use for this and hoping I can either use my enet cable or bluetooth OBD adapter with them. |
01-18-2022, 02:36 PM | #4 |
Rep 1,807
*Technically, nothing needs to be sniffed. BMW has very robust datalogging of all parameters for these ECUs.
For S55, this is the factory logging that can be done with Tool32 or even Testo: Argument: STAT_0x4436_WERT ID: 0x4436 Parameter name: P_oelist_abs (for N55 it's: SWSABMW_pOilAbsltIs) Full Description: Oil pressure actual value (absolute pressure) Data Unit: hPa Unsigned integer (16bit), conversion 1x (no conversion factor)
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 01-18-2022 at 02:50 PM.. |
01-19-2022, 10:24 AM | #5 |
Rep 699
This kit should work https://vargasturbo.com/product/vtt-...ssure-adapter/
2021 M2C HS DCT
2007 Wedge 335i E92 FBO, Stage 2 LPFP,VTT STG 2+, VTT Shotgun E50 w/ Inlets MT-SOLD |
01-19-2022, 10:19 PM | #6 | |
Rep 126
M1500Z423.00 |
01-20-2022, 07:27 PM | #7 |
Rep 1,337
For a pet project I sniffed the bus via the OBD port while a tool was probing the pressure sensor value. From here worked out which parts of the response holds the data.
As OBD is request/response and not raw canbus not sure if this helps as i'm not across how the AIM device gets its data. Keep in mind the OBD port is gateway and don't believe you can get the raw canbus frames from this port. To get the raw canbus you need to tap into powertrain canbus line which can be accessed via the FEM. I have a tap into the FEM to get the raw frames etc for another project. Anyway below is a snippet for the oil pressure via OBD. Line 12 and 13 is the request/response, bold items are the data values and I have highlighted the formula. You will need to check if this is all correct however based on the value on the tool and what my log was showing it appeared correct.
01-20-2022, 09:01 PM | #8 | |
Rep 126
Nice .
Now we need to build an interface and make a oil press display 😁 Quote:
01-20-2022, 09:50 PM | #9 | |
Rep 1,337
01-20-2022, 10:27 PM | #10 | |
Rep 126
You are right, if the refresh rate was much faster it would be a sweet sports display. |
01-24-2022, 06:21 PM | #11 | ||
Rep 342
Arbitration ID Ox4436 Bit order ? Bit Length 2 byte Offset ? Channel gain ? While some of these things can be worked out, they said I do need to get the channel gain before I can get a test protocol made and sent to me. Is that something either of you know how to get? |
01-24-2022, 07:59 PM | #12 |
Rep 1,337
Happy to be corrected by Enabled but I think the ID 0x4436 is the reference ID within Testo DB tables and not a direct correlation to the arbitration ID you are seeking for oil pressure.
EDIT: found some thread that alluded to the ID from Testo which is derived from the prg files does form part of the data request.
M1500Z423.00 |
01-25-2022, 02:22 PM | #13 | |
Rep 342
