10-17-2019, 04:47 PM | #1 |
Rep 1,973
Drives: BMW M3 2024 Brooklyn Grey SOLD
M3 437's fit M2C?
Hi guys,
Does anyone know if the 437's off an M3 will work on an M2C? I thought they would fit however someone mentioned that they might not. |
10-17-2019, 05:43 PM | #2 |
Rep 1,092
I believe they do even with the optional M Performance brake package. See here - https://f87.bimmerpost.com/forums/sh....php?t=1497066
Habber3393.00 |
10-17-2019, 06:05 PM | #3 |
Rep 548
10-17-2019, 06:08 PM | #4 |
Rep 1,973
Ok that's what I thought but I know lots of you guys have more experience than I did since I'm new to the M2 world.
Thanks for the answers. |
10-20-2019, 09:33 PM | #5 |
Rep 3
Recently bought an M2C. Would like to add to the question. Will 343M rims fit as a winter set? It’s 19” 8.5” wide with +35mm offset. The numbers seem to fit but would like some expert opinions from this forum. Thanks!
10-21-2019, 06:49 AM | #6 |
Rep 1,973
Looks great.
RedSectorA37.50 |
11-23-2019, 09:03 PM | #7 | |
Rep 1,288
Drives: 2014 435iX, FBO
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
07-29-2020, 10:08 AM | #8 |
Rep 436
07-29-2020, 10:17 AM | #9 |
Rep 443
No modifications needed. Even the wider tires fit!
4
07-29-2020, 10:30 AM | #11 |
Rep 4,040
So adding onto this thread, want to confirm the following from forum members:
1) 437M wheels will fit a 2020 M2C (with the larger brakes) without adjustments? 2) 437M wheels with 255 fronts and 275 rears (wider than the OEM PSS) will also fit without issues? Thanks guys! |
07-29-2020, 10:59 AM | #13 |
6626
Rep 4,145
Drives: '18 M2 6MT
I couldn't stand the black, had to get the Ferric Grey.
07-29-2020, 11:01 AM | #14 | |
6626
Rep 4,145
Drives: '18 M2 6MT
2. Yes, those tires easily fit, they are as near as makes no difference, and not worth the change IMO. |
07-29-2020, 11:36 AM | #15 | |
Rep 443
Yes, bought them used. It's a nice change from the black 437s that I still have. Been alternating for winter/summer! |
07-29-2020, 12:12 PM | #16 | |
Rep 4,040
Thanks! |
07-29-2020, 12:53 PM | #17 | ||
Rep 27
Shouldn't they be: 245/25.4 = 9.6" 265/25.4 = 10.4" delta = .8" 255/25.4 = 10" 275/25.4 = 10.8" delta = .8" The tire height measurements are correct, so you'd have .1" more rake. I think its a decent enough upgrade for more lateral and longitudinal grip with near factory level driving dynamics. |
07-29-2020, 01:31 PM | #18 |
6626
Rep 4,145
Drives: '18 M2 6MT
Yes, they are correct. The TW is where the shoulder of the tire sits as measured on the wheel, so if you put the same tire on a wider or skinnier wheel it'll change a bit. On the M2 it's a bit funky, about 8.5 on the front actually, and 9.2 on the rear (but I use tirerack's numbers because they're quotable).
It's one of the reasons I have never understood guys going 255/275, the tires are just taller, the front is almost no wider, and the rear additional width will only add understeer. Beyond that, the rear tire is a pound heavier per corner. The only reason I can see to go 255/275 is for wheel protection from potholes and such. Last edited by VisualEcho; 07-29-2020 at 01:37 PM.. |
07-29-2020, 01:45 PM | #19 |
6626
Rep 4,145
Drives: '18 M2 6MT
Oh, and to make things just a bit more involved, it depends on which exact tire you get. That's the TW in yellow..
07-29-2020, 02:48 PM | #20 | ||
Rep 436
07-29-2020, 02:55 PM | #21 |
6626
Rep 4,145
Drives: '18 M2 6MT
07-29-2020, 02:59 PM | #22 | |
Rep 436
