10-01-2018, 11:04 PM | #1 |
Rep 412
M Performance CoilOvers firmness?
Hey guys,
Just got my M Perf Coils installed, they feel great.. had it set to about stock height..and just whatever was standard on the firmness (think it is at 3 all around) Is that the recommended firmness? anyone have experience with it? i feel like i could go firmer, the ride is pretty nice. i think the lower the numbers the more firm? |
10-02-2018, 12:57 PM | #2 |
844
Rep 1,962
No.
The recommended settings are: Front Rebound - 9 clicks open Compression - 6 clicks open Rear Rebound - 12 clicks open Compression 6 clicks open Might want to get it adjusted down into the middle of its operating range too which is: Front - 595mm between the bottom edge of the wheel rim and the wheel arch. Rear - 600mm between the bottom edge of the wheel rim and the wheel arch. HTH. Last edited by M Fifty; 10-15-2018 at 02:50 PM.. Reason: Spelling |
10-02-2018, 06:21 PM | #3 | |
Rep 412
Thank you!! Can I adjust the rebound and compression by hand without needing any tools or jacking the car up? I have no idea what it’s at now lol |
10-03-2018, 07:44 AM | #4 | ||
Rep 4,510
rear - comp easier to access than rebo. wheel off access to rebo much easier
Current '22 X3M LCI.. |
10-05-2018, 12:41 PM | #8 |
844
Rep 1,962
wanofakind01282.00 |
10-12-2018, 12:28 PM | #9 | |
Rep 412
I was going to adjust the settings to that, usually the recommended settings are a little bit more “comfort” oriented.. could you recommend a little bit more of a aggressive setting? Not a track setting, but I want one better for the canyons. Any ideas? |
10-14-2018, 10:49 AM | #10 | ||
Rep 521
10-14-2018, 11:09 AM | #11 |
Rep 412
im not sure, i got it installed at auto talent, all iw as told is its at 3 all the way across. i dont know what that really means since the other poster posted different rebound and compression rates were the recommended. currently it does not feel super stiff. not stiffer than stock
10-14-2018, 01:11 PM | #12 | |
Rep 521
K9GunSlinger93.50 |
10-22-2018, 02:52 AM | #13 |
587
Rep 898
Correct. Rebound makes a HUGE difference on these especially in the rear. Compression helps a bit too around town but not as much as softening up rebound.
10-27-2018, 03:15 PM | #14 |
Rep 448
Hey guys,
I got the MP suspension for my M2C. Does anybody know if the settings on the suspension require any tweaking, or will the factory settings suffice?
- 2021 G82 ///M4C - AW, ZF8, CF Trim - CURRENT
- 2018 F87 ///M2C - HS, DCT, Blue Stitching - SOLD - 2015 F82 ///M4 - AW, CF Trim, DCT, MPE, M Perf Exterior Trims - SOLD - 2008 E92 ///M3 - AW, CF Leather Trim, 6MT - Mods: Black Grills, Black Gills, CF mirrors - SOLD |
10-30-2018, 08:07 AM | #15 | |
Rep 521
If you're talking right out of the box then I couldn't tell you. My kw v3s were new out of the box but were set at one extreme even though I was told it would come at recommended settings. |
10-30-2018, 08:12 AM | #16 | |
Rep 448
My main concern is that I am worried about, is that the MP suspension is setup for the standard F87 M2 and not the F87 M2C. Based on the S55 it is expected that the nose of the car is going to be heavier and would wonder, if rebound and compression would need to be adjusted accordingly. From a ride height that is very straight forward and simple and done to the taste of the owner I guess.
///M Houbi1653.00 |
10-30-2018, 08:44 AM | #17 | |
Rep 4,510
As you say, owners can always get the car tweaked/setup to suit their taste/needs.
11-01-2018, 03:14 PM | #22 |
844
Rep 1,962
Front
Rebound - 7 clicks open Compression - 4 clicks open Rear Rebound - 10 clicks open Compression 4 clicks open Apparently these settings "have been determined for a flat race course"...and..."can be too harsh for street driving, but deliver a more direct feel." HTH |
