04-20-2020, 05:19 AM | #27 |
Rep 744
WHP or crank? seems a bit low for hybrids no? or is the spool OEM like? I love the stock throttle response and dont want to loose it.
04-20-2020, 08:21 AM | #28 | |
Rep 1,322
I don't make hybrid turbos like a truck. |
04-22-2020, 04:29 AM | #29 |
Rep 21
Hi Guys!
First of all sorry for photo quality)) This logs is from dyno and they are from different days, but in any case you can clearly see starting run temp 32 and 36 = 4 deg different middle run temp 26 and 34 = 8 deg different at the end of the run temp 28 and 38 = 10 deg different Later i will add road test logs from 100-200 runs, there is much more different |
04-22-2020, 04:57 AM | #30 | |
Rep 1,322
This week I am going to do tests on a dyno with the original heat exchanger, so we can compare, although with mod turbos it is not useful to compare. |
04-22-2020, 05:52 AM | #31 |
Rep 21
Yeah, mod turbos on 600 hp working in middle of efficiency zone, oem turbos on 550-570 working close to limit of efficiency so produce much more heat. I can imagine what in your case heat exchanger not needed at all.
04-22-2020, 12:15 PM | #32 | |
Rep 1,322
Coincidence but my name is also Oleg |
04-23-2020, 09:39 AM | #33 | |
Rep 21
PS Yep, i have 15+year experience in ECU calibration and starting point was Subaru, EVO and GTR - and on thous cars this topics is much more clear BMW made really great car. |
04-23-2020, 01:41 PM | #34 |
Rep 1,322
04-24-2020, 12:11 PM | #36 |
Rep 1,322
