04-09-2020, 04:50 PM | #1 |
Rep 1,286
Re-dyno: Stock M2C - HUGE discrepancy
First dyno - 425 whp, car in dyno mode, notice the bad power curve with huge drop off after 5500rpm, fan was not on the first run
Second dyno - different shop - 377whp, car NOT in dyno mode, notice the nice smooth power curve without drop off after 5500rpm I don't know which dyno result to trust now. 50whp difference between dyno runs is a lot but much healthier power curve at the second shop and on par with other dyno results i've seen in terms of curve.. Does it matter that for the second dyno the car was not in dyno mode? Brian from Kies Motorsports was saying in one of his videos that if the car is not in dyno mode, it "may" limit power due to the car "freaking out" being on rollers with wheels spinning at different speeds. I also did get a bunch of errors during the run.
04-09-2020, 06:49 PM | #3 |
Rep 1,286
Agreed, only reason I got a second one is because the power curve on the first one looked really bad and wasn’t sure if the car has issues or it was the dyno.
infinitekidM2C4205.50 |
04-09-2020, 08:38 PM | #4 | |
Rep 186
Mustang dyno Car on dyno mode Untuned |
CSBM52716.50 |
04-10-2020, 11:39 AM | #5 |
Rep 3,075
Hasn't it been proven that the M2C has a flat line after 5500 just to make sure it doesn't break big brothers legs?
You tune and that flat line goes away..
Follow me on IG
04-10-2020, 11:58 AM | #6 |
Rep 1,200
It's best to use the same dyno for delta comparisons. Also Dynojets "IMO" are the best as they can't be easily manipulated like a mustang. Dynocom read higher from most I've seen. Regardless it's just a tool.
See my dyno comparison before/after tune at the end of this vid:
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder |
tom @ eas8107.50 |
04-10-2020, 12:36 PM | #7 |
Rep 210
I can concur Dynocom's read very high. I won't waste my time on those anymore.
DynoJet is a good "standard" for comparison. Just make sure the numbers are displayed in SAE calculations. STD calculations tend to fluff numbers slightly due to the correction factor.
2020 X3MC, 2019 M2C
'14 F-150 Tremor, '99 Mustang Turbo |
04-10-2020, 01:37 PM | #8 |
24083
Rep 190,614
+1
04-10-2020, 03:15 PM | #9 |
Rep 1,286
But the point was, would the car not being in dyno mode lower the reading?
04-10-2020, 03:27 PM | #10 |
Rep 855
05-03-2020, 12:17 AM | #13 |
Rep 2,577
Different dynos read vastly different.
There is absolutely no value to do any other dyno than dynojet if you don't do before and after. Dynojet reads high albeit not the highest, but the point is it reads most consistent across different conditions, by far. M2C puts down 370-380whp stock on dynojet (DCT on the higher end), which sounds correct.
Lemania 2320
05-06-2020, 12:47 PM | #14 |
844
Rep 1,962
Any dyno that gives consistent results is useful in tuning an engine. You do a Before, make an adjustment, then do an After. Iterate until happy.
Everything else is just Bragging Rights. OP, that first plot just looks like the ecu was backing things off as the temperatures rose. The blue and green traces look good. |
