04-16-2021, 06:33 PM | #3 |
Rep 1,366
Drives: 2020 X3MC
Probably a low battery if everything is faulting
04-17-2021, 07:40 AM | #4 |
Rep 901
Drives: 2018 M3 Competition
Maybe you can do the break in service early? I hope it's just the battery.
04-17-2021, 09:28 AM | #6 |
Rep 1,802
I'm not sure it's the battery if the engine is running fine, and essentially having a system voltage over 14V.
04-17-2021, 09:36 AM | #7 | |
Rep 464
Some faults will still show and need to be cleared via OBD. |
04-17-2021, 04:35 PM | #9 |
Rep 2,819
Drives: e82 1M, f87 M2cs
Please let us know what you find out
04-18-2021, 02:08 PM | #10 |
Rep 155
Loose fuse(s).
I learned that my ODBII scanner does not scan this car, but on a hunch I dug out the fuse diagram with the intention of checking for a blown fuse, however a cursory check revealed that a few of the fuses did not appear to be 100% seated, so I pushed all of them in and most of the errors went away on the next start. The CEL took a bit longer but it too cleared. This is good news for me because I was dreading the visit to our local dealer. BMW of Denver is a terrible dealership and the one down south is even worse. Gephardt up in Boulder, while not great, is where I have had the best experience and intend to take the car for servicing. |
killerdeck354.50 Moflow2484.50 |
04-18-2021, 05:32 PM | #11 |
Rep 2,819
Did you try to hook up your code reader again after fixing the fuses? I would expect that any reader should be capable of communicating with the ECU, even if it is not able to read BMW specific codes.
