04-16-2021, 05:24 PM | #45 | |
Senior 1Addict
5166
Rep 2,426
Drives: BMW iX, Porsche GT4 RS
04-22-2021, 06:17 PM | #46 | |
Rep 1,125
04-22-2021, 06:22 PM | #47 | |
Senior 1Addict
5166
Rep 2,426
As far as other components, that i'm still working on determining. |
04-22-2021, 06:25 PM | #48 |
Rep 1,125
I heard you can get substantially reduce the brake dust situation by going with ceramic pads? I have heard some P car folks doing that to their steel optioned car.
04-22-2021, 06:26 PM | #49 |
Rep 1,125
Thank you! Keep us posted.
04-22-2021, 08:25 PM | #50 |
Rep 2,819
Drives: e82 1M, f87 M2cs
That is generally true, but ceramic pads are usually much less effective. With the size of this braking system the performance should still be pretty good, but pedal feel may be less responsive.
04-25-2021, 04:36 AM | #51 | |
Rep 1,348
I’m betting the M2 CS kit will be the M3/M4 kit and will tell you not to use some of the other included parts but at least then you’ll have vendor support for it too. Last edited by ND40oz; 04-25-2021 at 04:42 AM.. |
04-25-2021, 11:20 AM | #52 |
Rep 2,873
I would love to know how much weight is saved with the CCB vs steel, if anybody has that info.
And FWIW regarding the chipping issue, I was just at the Performance Ctr for the M-school and was asking them about the durability issue - they told me they have not ever lost a rotor to damage and there was a good bit of gravel getting flung about. They just use the long stud-rods when changing, so you are sliding the wheel out on that to prevent hitting the rotor. And they could not say enough good things about the CCB's on the M4/5/8. We didn't drive hard/long enough to really get into where the CCB's show big benefits, but they did feel a lot firmer than the steel ones on the M2's. |
04-25-2021, 12:38 PM | #53 | |
Rep 175
https://www.bmwux.com/bmw-performanc...omplete-guide/ |
Maynard3848.00 |
07-29-2021, 01:34 PM | #54 |
1026
Rep 842
Carbon ceramic discs save weight and work great on the street, but if you plan to track your car at all, they are a money pit. We recently published an article on carbon ceramic discs: Are carbon ceramic brake discs better than iron?
In the exotic market (Porsche, Ferrari, McLaren, Lambo, Corvette ZR1, etc.), we have converted a tremendous number of carbon disc cars over to our AP Racing Radi-CAL Brake Kits with iron discs. What many people don't realize is that our AP Racing Brake Systems frequently weigh about the same, or even less than, the OEM carbon ceramic brake systems. How is that possible? Because our AP Racing calipers are so much lighter than the OEM calipers. For example, our AP Racing Radi-CAL Competition Brake Kit weighs about 40 unsprung lbs. less than OEM M2 Competition Brake System! We did a blog article on this a while back: https://www.essexparts.com/news-blog...m2-competition I don't have the M2 carbon disc weights in front of me, but that should put us right in a similar weight range. So what does switching to our system do for you? A whole bunch of things:
What do I do with my OEM brake system? Option A: Shelve it in your garage Our brake system is a significant investment, but it truly is an investment. Our brake packages typically change hands for 65-70% of their original MSRP on the used market. That means when the time comes to move onto your next ride, you can pull our kit from your car and get thousands of dollars for it. You'll have your pristine OEM brake system sitting on the shelf, so you won't have to go out and buy a bunch of OEM brake parts to prep it for sale. The OEM calipers and discs also won't look like they went through war, so you won't have to worry about scaring off potential buyers because your brakes look ragged-out. Option B: Sell your OEM brakes to another M2/M3/M4 owner Not everyone wants the ultimate brake package for their M car. Many just want something big that looks cool, or anything more durable than the base setup. If you pass your giant OEM setup down the road, you'll have several thousand dollars to put towards our brake system. When it comes time to sell the car, you could either leave our system installed (one of the few potential mods that arguably adds value), or sell our kit and pick up a base brake package for peanuts on the used market. Some pics to see what they look like installed: |
2taCoS279.00 |
07-29-2021, 06:07 PM | #56 | |
Rep 51
07-30-2021, 11:49 AM | #57 | |
1026
Rep 842
We'll be here if you have questions or need us. Thanks! |
07-30-2021, 12:18 PM | #58 | |
Rep 3,006
https://www.bmw-m.com/en/topics/maga...nt-brakes.html However, on the racetrack, the brake discs may be subject to oxidative wear. When the discs are repeatedly heated to temperatures of 600 degrees and over, the fibres within the brake disc burn up. |
MadBimmeRad7121.50 |
07-30-2021, 05:28 PM | #59 |
SR-71 Pilot
39
Rep 15
Drives: 2020 BMW M2CS
Garage List 2020 BMW M2CS [0.00]
1973 Datsun 240Z [0.00] 1972 Porsche 911T [0.00] 1969 Alfa GTV 1750 [0.00] 2018 AMG GLE63 (Wif ... [0.00] |
CCB overkill on the Street
Though the $8500 option at purchase now seems like a bargain compared to the $12K in parts alone to upgrade to CCBs - as many have said (and the automotive press as well), the steel brakes already deliver impressive stopping power. IMHO, the CCBs are only worth the extra dough if you're going to take the car to the track... and you're a real hot shoe. You've got to be a pretty consistently fast driver on a track to start feeling fade with the stock brakes on an M2, M3, or any of the Ms. Brake fade comes from hard braking and weight (and the CS is already 92 pounds lighter than an M2C).
And if your steel brakes are squealing from lack of hard use on the Street (a big culprit as someone else has already pointed out), they'll squeal even more if you're running CCBs with far lighter braking than they were designed for. My 911 GT3 pals who opt for the CCBs aren't lacking sufficient braking performance (most NEVER take the car to the track) - they are opting for the weight savings over "iron" brakes and the reduction in unsprung weight at the corners. But how much are you really feeling that weight difference - especially if you're NOT taking it to the track? I got the gold rims and am as anal about visible brake dust as the next guy... but $8.5K as an option; and $12K+ to retrofit is a LOT of money for cleaner wheels with less labor. And don't forget those future brake pad and rotor changes under maintenance. Its like my friends who downshift and use "engine braking" to slow the car to "save the brakes." I hit the brakes hard and heel & toe into 2nd gear (that's 50% of the reason I opted for 6MT) - I don't know what kind of wear and tear one is subjecting the engine and transmission to when using them to aid in deceleration - but I'd rather change the pads more often and clean the brake dust. Besides... SOOOO many other places to spend that $12K and get some real bang for the buck... starting with the MPE - again, IMHO. Last edited by calspyderman; 07-30-2021 at 05:44 PM.. |
07-31-2021, 12:20 AM | #60 |
Rep 534
I drove Bimmercs car a couple weeks ago and it had the CCB. They are definitely grabbier with more initial bite than my steels. Stopping distance/performance is probably the same or very similar.
F87EVO4033.00 MadBimmeRad7121.50 |
07-31-2021, 05:46 AM | #61 | ||
Rep 2,411
Drives: E30 M3 Cecotto, F85, G05, G07,
07-31-2021, 09:00 AM | #62 |
6637
Rep 4,145
Drives: '18 M2 6MT
MadBimmeRad7121.50 jritt@essex1026.00 |
