04-14-2021, 02:10 PM | #23 | |
Rep 900
Drives: 2018 M3 Competition
My steel brakes have had intermittent squeals and I agree a few hard brakes usually clear it up. |
04-14-2021, 02:20 PM | #24 | |
Rep 433
Also worth noting, BMW uses fiber shims attached to the backing plates of the stock pads to try and reduce brake noise (instead of any grease or lubricant) |
04-14-2021, 03:52 PM | #25 |
Senior 1Addict
5161
Rep 2,426
Drives: BMW iX, Porsche GT4 RS
I'm considering putting in the the CCBs on, is chipping a real issue in every day traffic? Even the steel brakes are very tight.
04-14-2021, 08:44 PM | #26 |
There Is No Substitute
1909
Rep 1,070
I had ceramics on two GT3s, a Turbo S and a Carrera T. For all four cars, the squealing started at the beginning and never stopped. But more important to me, I do not want to get another rock lodged between the caliper and rotor. It is not hard to chip or even crack ceramics and the replacement costs are exorbitant. Losing the brake dust is definitely nice but the performance difference just doesn’t justify these other issues imo. I have been very impressed with the standard brakes and they look gorgeous.
MomoM3984.00 |
04-14-2021, 09:37 PM | #27 | |
Rep 534
I agree though that I prefer steel on my GT3/RS. You don't want to chip them if you're changing wheels and if you track lots the cost of replacement is $22k. |
04-14-2021, 11:00 PM | #28 | |
Senior 1Addict
5161
Rep 2,426
04-14-2021, 11:06 PM | #29 |
Rep 179
I just did my first track weekend with the CCB on my CS. I also ran the same track a year ago with my comp on steels. I did not feel a noticeable difference as far as I could tell.
What I can tell is my car isn't loaded with brake dust after a few hundred miles of hard braking over 2 days. They also do not squeal near as often. To me if I tried to justify adding them after I'd have to really care about dust and appearance. I love detailing my cars and spending hours doing it, the steels are rusted right after it's clean and of course make a mess. TO ME it's totally worth the price and I do not regret the CCB's. Will it be expensive if I have to replace them in the future, sure. That's just the cost of doing business. Different priorities for everyone here, just my opinion.
-2020 M2Cs
-2020 GLS450 |
cncmastr1582.00 cptobvious2531.50 |
04-14-2021, 11:10 PM | #30 | ||
Rep 534
04-15-2021, 08:49 AM | #31 | |
1909
Rep 1,070
Start @ 1:30. |
04-15-2021, 02:29 PM | #32 | |
Rep 4,664
kyrocks1070.50 |
04-15-2021, 06:40 PM | #33 |
Rep 4,093
AFAIK, the steel calipers are the same size as the CCB versions, the rotors are the same or fractionally smaller in diameter, that said, I see no difference between brake options Re stones being caught between caliper and wheel.
Happy to be corrected of course. |
MadBimmeRad7121.50 |
04-15-2021, 06:45 PM | #35 |
Rep 3,842
I hope you can manage to keep the grooves off of your nice gold wheels. I've managed to get the grooves multiple times for no apparent reason.
04-15-2021, 09:14 PM | #36 | |
Rep 569
I’m assuming I soon will have it on all 4 wheels and there is little to be done about it. |
04-15-2021, 09:21 PM | #37 | |
Rep 3,842
04-16-2021, 12:12 PM | #38 |
Senior 1Addict
5161
Rep 2,426
I was told by my parts department that the BMW Retrofit fit kit will not work for the CS (that BMW told them this via a support ticket).
Doesn't seem true to me, wonder if anyone can shed some light on this. |
04-16-2021, 12:18 PM | #39 |
Rep 4,664
It could be the booster and coding. Coding can be done outside bmw. The booster may or may not be necessary. I wonder the the hat offsets could be different.
It could also be garbage info because the retrofit kit would likely not show up in a part search for the CS. |
04-16-2021, 01:00 PM | #40 | |
Rep 464
It was inventory number 3860413, they might be able to give you additional information. For now, booster P/N is the same on 2NH and 2NK M2. Was different on F80's. Even on the F80's the pedal modulation was not vastly different with the new booster (just a little more gradual after the change, but could be driven comfortably with the blue brake booster-34337849876) |
04-16-2021, 01:06 PM | #41 | |
Rep 4,664
04-16-2021, 01:13 PM | #42 | |
Senior 1Addict
5161
Rep 2,426
04-16-2021, 01:19 PM | #43 | |
Rep 464
I don't trust the parts catalog, but will visually verify next month what the booster P/N is on the CS with CCB. Sucks the TIS is no longer open access. |
04-16-2021, 03:46 PM | #44 |
Rep 341
Getting a CS w/ CCBs, but I have a M2C and a M4 GTS. The CCBs are significantly touchier than the steel M2C brakes. Stopping power is likely identical, but I think the lower pedal effort to stop on CCBs add to the stronger braking perception.
Both squeal, CCBs squeal more often. |
cptobvious2531.50 |
