04-10-2021, 02:52 PM | #1 |
Rep 115
Clutch Action (Manual Cars)
Hi!
I'm relatively new to the BMW brand and M cars so I hope I don't get flamed for this post lol. As much as I love the CS, the clutch action on this car feels a little artificial. IMO, It's not linear and I find it difficult to modulate (very springy) compared to the clutch on my GT3. Also, it feels like the ECU is doing some funky things with the throttle as I'm letting go of the clutch from a stop. To some extent, it feels like it's completely ignoring my throttle input. Does the clutch get better as it gets broken in (I only have 250 miles on the car) or are people performing mods to fix this? Other than that, this car is amazing. Sounds great. Drives even better. |
04-10-2021, 03:37 PM | #2 | |
Rep 2,526
Some people installed the ultimate clutch pedal and CDV delete. and it seemed to make it a bit more linear. |
frostyrides311.00 |
04-10-2021, 04:52 PM | #3 | |
Rep 375
What really helped was clutch stop and also driving in sport plus mode. Clutch stop really helps with consistency in clutch engagement point. Sport plus improved the rev hang. |
frostyrides311.00 |
04-10-2021, 05:31 PM | #4 |
Rep 4,668
You're not alone!
As others have stated the clutch stop is very helpful. There is an auto brake feature if on a hill to prevent roll back. Unsure if you are experiencing a little of that in some situations. Sport + was the mode where throttle response seemed to match my style. I've ordered an auto solutions ask. I'll be honest. At 3k miles I'm finding the clutch has worked in very nicely. It's a significantly different feel from new imo. I'm sure some of this is me adapting. Pgltw will attest that the shifter upgrade gets it closer to that GT3 feel you have come to appreciate. There is a built in CDV inside the slave cylinder. I'm replacing this as well. It's decide to prevent drive line shock, but makes it difficult to modulate. The E90 slave cylinder is the same part without the delay valve. Others have used a screw to pull the delay valve out of the factory slave cylinder. |
ptgltw3777.50 frostyrides311.00 |
04-10-2021, 05:32 PM | #5 | |
Rep 4,008
Drives: M235i, 420i, and now the M2 CS
Secondly, congratulations on your choice of M - may your driving joy compound daily and exponentially with your new acquisition. Thirdly, due to political regulations, we've had to stop burning witches at the cross for some time now, so feel safe as there are no fires here Finally, the clutch takes some getting used to; Rev-Matching on top of that. Most importantly, welcome to BimmerPost my friend
M2CS,
The second coming of ///M! |
04-10-2021, 06:39 PM | #6 |
Rep 122
[QUOTE=frostytacos;27456999]Hi!
I'm relatively new to the BMW brand and M cars so I hope I don't get flamed for this post lol. As much as I love the CS, the clutch action on this car feels a little artificial. IMO, It's not linear and I find it difficult to modulate (very springy) compared to the clutch on my GT3. Also, it feels like the ECU is doing some funky things with the throttle as I'm letting go of the clutch from a stop. To some extent, it feels like it's completely ignoring my throttle input. Does the clutch get better as it gets broken in (I only have 250 miles on the car) or are people performing mods to fix this? Other than that, this car is amazing. Sounds great. Drives even better.[/ It took a few weeks for me to get used to the clutch now I love it.... but I can’t compare to the clutch of a Porsche gt3 but in September I will..... |
frostyrides311.00 |
04-10-2021, 09:29 PM | #8 |
Rep 447
DSC off removes rev hang and deleting the clutch delay valve helps tremendously.
2020 M2 CS AW 6-spd
Previous M Cars: M2C, M2, F80 M3, E46 M3, Z3M Coupe, E36 M3...and some other fun rides. |
frostyrides311.00 |
04-10-2021, 09:37 PM | #9 |
Rep 122
frostyrides311.00 |
04-10-2021, 09:40 PM | #10 |
Rep 1,657
The RPM stays up between shifts for a moment and then drops.
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy) |
MadBimmeRad7121.50 windnsea00446.50 |
04-10-2021, 09:48 PM | #11 |
Rep 122
04-11-2021, 10:38 AM | #12 |
Rep 375
Not sure why it does that maybe emissions ? and I also thought it would help with smooth shifts but only if shifting very slowly otherwise under normal or more aggressive driving it makes it allot worse and almost impossible to smoothly shift. Also back to the OPs original post had my 718 Spyder out for a ride this morning and the catch point is allot lower and more direct than the M2CS. The clutch stop on the M2CS really helped. I purchased the BMS and removed one of the discs. Very happy with the results. https://burgertuning.com/products/bm...06-mini-cooper Less rev hang in the sport plus mode and didn't seem to make the throttle too twitchy which I don't usually prefer. |
frostyrides311.00 |
04-11-2021, 11:42 AM | #13 |
Rep 1,668
After owning the OGM2 6MT, with a horrible clutch feeling (sorry to say, but the truth) I've gone the DCT route on the M2CS.
1 The travel far to long 2 No feeling what so ever 3 Engagement to high The MT was very good indeed, precise, direct, no rubbery feeling to me, but the clutch ruined it completely for me |
frostyrides311.00 |
04-11-2021, 12:01 PM | #14 | ||
Rep 115
MadBimmeRad7121.50 |
04-11-2021, 12:05 PM | #15 | |
Rep 115
04-11-2021, 12:07 PM | #16 |
Rep 59
I have zero issues with the clutch or it's action. I've owned many manual BMW's, and as I've told a few others...this is the easiest to drive manual BMW I've ever owned. It's the first one I have ever owned that does rev matching, and I really like it. My size 14 feet have always had trouble doing a well executed heel-toe, so I appreciate any help I can get!
M2 CS
MadBimmeRad7121.50 jdl8r34.50 |
04-14-2021, 01:58 AM | #17 | |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
It will actually start moving on an incline with zero throttle input from the driver. I want to remove the clutch delay valve myself as I hate the non-linear clutch engagement, but I actually kinda like the anti-stall stuff. Makes the car idiot-proof (or distracted-brain proof at least). It also allows you to one-foot drive the car for creeping in traffic - just let out the clutch and it will give you a 1st gear creep, then push it back in again and you coast (and can easily brake), without needing to go back and forth with your right foot. I fear that changing the clutch engagement rate (by removing the CDV) will either totally mess up, or make less effective, the anti-stall system. (Would love to know if other people have done the CDV delete and have experience/opinions on this.)
04-14-2021, 05:37 AM | #18 | |
Rep 4,668
04-14-2021, 08:09 PM | #19 | ||
Rep 2,819
Drives: e82 1M, f87 M2cs
ZPrime611.50 |
04-15-2021, 12:33 PM | #20 | |
Rep 1,418
eric giles129.00 |
04-16-2021, 10:54 PM | #21 |
Rep 447
The CDV removal has no correlation with S55 anti-stall tuning, in other words, that stays.
2020 M2 CS AW 6-spd
04-19-2021, 01:33 AM | #22 | |
Rep 89
this blog post: https://55parts.de/blogs/wissen/das_...kupplungspedal describes mods to fix the issue, it's in german unfortunately but maybe you can use a translator to read it I did those mods expect deleting the cdv and the clutch feels much better, shorter, linear feeling resulting in a better clutch feel, disabling the ASD also helped to get a better feel for the clutch and car in general what i did to the clutch: installed the clutch stop, the new copper bushings and got rid of the over dead center spring |
BoltacoreMD3.00 |
