04-06-2021, 07:45 AM | #24 |
Rep 4,666
Is this a US door sticker. Mine says 32 PSI on the door. I assume this is cold pressure. The michelin app specs 38PSI hot. This works out correctly with a warm ambient temp, but in colder weather the tires won't get warm enough without extended driving.
04-06-2021, 10:55 AM | #25 | |
Rep 3,842
Chasing tire pressure on the move is very difficult. I sometimes start out at sea level around 72 degrees F, head east to the mountains at around 5000 ft. elevation, then meanwhile the temperature has climbed to 100 degrees F and the tires are super heated from the twisties. I've seen the pressure go from 35 to 42. Come to think of it maybe the Connect app could be useful after all. |
MadBimmeRad7121.50 |
04-06-2021, 12:40 PM | #26 | |
Rep 4,666
04-06-2021, 07:30 PM | #27 | |
Rep 3,069
Post your sticker. (But not with that invisible camera that you use from time to time ) |
04-06-2021, 08:49 PM | #28 |
Rep 4,666
Wow, recommended tire pressure is really high for the over 100mph guidance in the manual. Door sticker is for under 100mph.
04-06-2021, 09:01 PM | #29 |
Rep 855
Crazy how much lower the E46 is. And how the 2 series is the size of the old 3!
04-06-2021, 10:04 PM | #30 |
Rep 3,069
How odd. I don't have any info in either the printed manual or the online one other than consult tyre placard. The one you have seems to be fitted locally I'd say as there is no BMW branding on it. Seems strange that they would give different info for different markets?
04-07-2021, 01:16 AM | #31 | |
Rep 4,008
Drives: M235i, 420i, and now the M2 CS
M2CS,
The second coming of ///M! |
04-07-2021, 03:01 AM | #32 |
Rep 1,231
Drives: BMW F87 M2 CS (6MT)
At first , i wasnt really a fan of gold wheels , but i risk it . Now , i am in love with gold wheels , gives a nice presence . And the frozen gold colour matches great with the misano blue
Sometimes, the simplest recipes, done well, with quality ingredients, are the tastiest, - evo Car of the Year 2020
2020 BMW F87 M2 CS - 6MT - Misano Blue Metallic |
04-07-2021, 05:51 AM | #33 | ||
Rep 3,069
04-07-2021, 06:07 AM | #34 | |||
Rep 4,008
M2CS,
04-07-2021, 09:00 AM | #35 |
Rep 4,666
First picture is the door sticker. Pics 2 and 3 are from the US owners manual, and pics 4 -5 are from the Michelin track connect app.
The track connect app recommends a tire pressure of 38psi hot. However, you can see there is a range for what it considers ideal. 38psi seems to be the avg. With outside temps above 60F and a cold pressure of 36psi it seems to warm up to 38psi around town driving and 40psi on hwy. Tire temps get to about 120F on hwy. I would assume tire temps would get to 180 - 200F on track and require a cold fill temp to closer to 32F. The manual recommends a cold pressure of 41psi if going over 100mph. This would likely be closer to 44psi when on the hwy and towards the high end of ideal for the track connect app. I'm unsure what Pressures bmw used on track. Higher pressure could lead to a more tail happy nature. I have mine filled so that when warm and running at higher speed the pressure settles at 40 to 41psi. Anyone else running something they like. Sorry, this tire porn might not be as favorable. |
Davil6523.00 |
04-07-2021, 05:18 PM | #36 |
Rep 48
A quick bit of math & the ideal gas law indicate that tire pressure increases by 1.0 psi for every rise in tire temp of 15 degrees F (or 8 1/3 degrees C). If you know what your running (hot) tire temperature is, you can use this relationship to determine what your starting pressure should be at your actual ambient ("cold") fill temperature.
04-07-2021, 08:11 PM | #38 |
Rep 855
04-08-2021, 05:00 AM | #41 |
Rep 1,657
People still steal wheels? How pathetic
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy) |
04-08-2021, 02:05 PM | #43 |
Rep 184
In my town there have been a lot of catalytic converters cut off of parked cars lately. It's super extra pathetic because the raw cat is worth so much less than the OEM exhaust is to the owner. At least wheels sell for close to the actual value.
04-08-2021, 04:31 PM | #44 |
Rep 3,654
